FileVault problems on macOS Tahoe Hackintosh
This issue will be fixed in the next betas, but in the meantime you can use this solution.
1- Uncheck EnableJumpstart in config.plist / UEFI / APFS
2- Use apfs_aligned.efi from macOS Sequoia / Download bellow
apfs_aligned.efi.zip
Credits: mhaeuser
  • Like 2
Didn't help. I still can't login into Filevaulted Tahoe.
1. i5-13400, MSI PRO B760M-P DDR4, BIOS 1E, MSI RX570, ALC897 (VoodooHDA), Tahoe 26.3.1, Sequoia 15.7.4, ArchLinux 6.18, Clover 5171
2. ASUS X200CA, Pentium 2117U, 4GB, HD2500 (Software OpenGL), Mojave 10.14.6, ArchLinux , Clover5162
3. Huananzhi X79M-PRO, Xeon E5-2650v2, RX570, ALC887, RTL8111F, macOS 12.6, 10.14.6, Win10, multiboot by Clover 5150
4. GA 965P-S1, E6300 Conroe, Radeon HD5570, ALC888, OS⌘ 10.11.6 (15G22010), Clover 4928. Still working.
I haven't tested it with clover, it works with opencore and after logging into the system I disabled the FV.
The real problem is I can't enter password until ecrypting is finished.
If you have fast SSD and while you changed APFS the encryption process will finished.
