Hello users of this amazing forum!
I am a long time reader and I've always admired the talent of the moderators here, we've come a long way... I've successfully set up a dual boot between windows 8.1 and OS X 10.10.4, using Clover. I've an ASUS X550LDV with the following specs:
Intel core i7(haswell)
Intel HD4400
Nvidia geforce 820m
Realtek ALC233
I've managed to get everything working properly, full qe/ci, ethernet, sound, headphones, touchpad, usb, brightness, fn keys.
The only thing I've left to do is patch my dsdt so that the Nvidia card is disabled with OS X, to save some battery and lower the temperature.
It's been 6 months of trial and error on this computer cause I've never been good at ACPI language or DSDT patching.
I would appreciate a lot if anyone would take the DSDT I've attached and Disable NVIDIA.
Thanks so much
ioreg.zip
patched-dsdt+ssdt0.zip
Hey Bro
All working like before, perfect hackintosh that's running better than my girlfriend's Macbook Pro 2012
The NVIDIA card is in the same state I think, because it still show up as a screen
Using your DSDT and SSDT led me to a better performance overall.
I attach the image of my system information,in the graphics department.
Thanks a lot for your efforts.
801139489_Capturadepantalla2015-07-26alas13_08_46.thumb.png.e1c07b82a86c8f600202350a2418aa77.png
no idea about ..
should try to google about ur note and model
artur-pt
The SSDT you sent me contained a lot of errors.. Not the DSDT though
Is that the reason maybe why the changes you made didn't disable the card??
Thank you!!
the errors come from decompile it
anyway i just end this issue .. when u find a solution .. u can post here
