continuity camera not working on wireless
Hello dear forum users, As I said in the title, my continuity camera does not work for some reason, and when I try it wired, it works once, when I turn it off and reconnect it, it stays on the black screen and there is no signal to the iphone, I use the fenvi fv-hb1200 card, I did usbmap, I will specify my system information below, I am waiting for your help.
(airdrop, handoff, airplay, import from iphone, scan documents, bluetooth and wifi work smoothly)
Amd ryzen 5 3600
Asus rog strix Rx 590
DDR4 3000mhz ram
Fenvi fv-hb1200
as an extra I sent my config file, I am open to all advice about my system
config.plist.zip
These cards is native. Do u have a AirportBrcmFixup?
Its good idea use it
