Need help Efi Asus tuf gaming b550m plus - ryzen 5600x - rx 6650xt -
Hello everyone. First of all thanks for the help. I've been trying for weeks to install on my computer
Ryzen 5600x
Rx6650xt
ssd
I need an efi to install Sonoma.
Can you help me?
Thank you very much
EFI.zip
Edited by Nikotetfe
<plist version="1.0">
<dict>
    <key>DeviceProperties</key>
    <dict>
        <key>Add</key>
        <dict>
            <key>PciRoot(0x0)/Pci(0x1,0x2)/Pci(0x0,0x1)</key>
            <dict>
                <key>compatible</key>
                <string>pci8086,a182</string>
            </dict>
            <key>PciRoot(0x0)/Pci(0x1,0x2)/Pci(0x0,0x2)/Pci(0x4,0x0)</key>
            <dict>
                <key>device-id</key>
                <data>BqgAAA==</data>
                <key>vendor-id</key>
                <data>TRQAAA==</data>
            </dict>
            <key>PciRoot(0x0)/Pci(0x3,0x1)/Pci(0x0,0x0)/Pci(0x0,0x0)/Pci(0x0,0x0)</key>
            <dict>
                <data>AQAAAA==</data>
                <string>pci1002,73EF</string>
                <data>7O8AAAA=</data>
                <data>gQAAAA==</data>
                <key>model</key>
                <string>AMD Radeon RX 6650 XT</string>
            </dict>
        </dict>
        <key>Delete</key>
        <dict/>
    </dict>
</dict>
</plist>
