Hi I have installed a new hard drive for Sequoia,all is installed fine for the os.
I have the old hard drive with Monterey for testing purposes ,which was the old drive from Sequoia with the EFI.
Monterey does not go past 0.8.8 for the opencore OCAT.
Sequoia is at 1.3.0 for opencore OCAT. I use the Sequoia to update the configlist from that EFI on the Monterey drive.
My question is can the EFI folder stay on the drive that MOnterey is installed on ,or do I need to switch it over to  Sequoia drive?
How is that done ?
U can use EFI from any SSD. Use only one for all systems.
  • Thanks 1
