Same EFI works in USB but doesn't work when I use IMG file in Ventoy
I format My USB Flash drive then burn mac OS on it, and boot to USB works
Same installer with same EFI folder but:
1- create GPT dmg which create 2 Partition (EFI, Installer Partition)
2- burn installer using createinstallmedia (Done)
3- convert dmg to img to support ventoy
When I boot to ventoy then select image boot picker shown then I select Installer after a little of time this error appears to me
I after this error I map USB again using windows+usbtoolbox then USBMSC error disappear, but amfi error still here
Then I disable wifi and bluetooth from BIOS settings itlwm and intelfrimware lines disappear, but amfi error still here
Then I disable SIP from mac OS recovery but doesn't work
Then I add "amfi=0x80" (SIP Currently Disabled) but doesn't work
Then I remove it and add "amfi_get_out_of_my_way=0x1" (SIP Currently Disabled) but doesn't work
Then I add two previous boot args together (SIP Currently Disabled) but doesn't work
What is solution
Same EFI on USB works, but doesn't work in img disk
should I add specific driver or Kext?
This is my EFI folder EFI(OpenCore NO ACPI), I use OpenCorePkg but same error appear
Everything is up to date only change to EFI drivers I add certificate to every file to support secure boot If I use same files without modifications same error appears
Edited by مجهول الهوية
