Tenho um notebook Avell B155Max (Clevo W650SJ )
Configuração:
Tipo de processador Móvel QuadCore Intel Core i7-4810MQ, 3300 MHz (33 x 100)
Nome da placa-mãe Clevo W65/67SJ
Chipset da placa-mãe Intel Lynx Point HM86, Intel Haswell
Tipo de BIOS AMI (19/08/2014)
Distribuidor BIOS - DMI American Megatrends Inc.
Adaptador gráfico Intel(R) HD Graphics 4600 (1 GB)
Controlador SATA AHCI da família de chipsets Intel(R) série 8
Adaptador de rede do controlador da família Realtek PCIe GbE (10.0 [VERSÃO DE TESTE])
DIMM1: Korea Uhbele International Group 8 GB DDR3-1866 DDR3 SDRAM (11-11-11-30 a 838 MHz) (10-10-10-27 a 761 MHz) (9-9-9-24 a 685 MHz) ( 8-8-8-22 a 609 MHz) (7-7-7-19 a 533 MHz) (6-6-6-16 a 457 MHz)
Disco rígido SSD de 1 TB (931 GB)
I have tried several tutorials, but I have not been successful. I would like to know if there is a specific tutorial for these configurations? Or which version is specific to my configuration. On my last attempt I tried to install with the Ventura system image, for a long time I thought it would work but it froze on one of the screens, with the message: "** In Memory Panic Stackshot Succeeded ** Bytes Traced 4000 (Uncompressed 8960) ** MACH Reboot
I hope you can help me, Thanks!
Imag 1.zip
Edited by Éder Corrêa de Oliveira
-NoteBook Haswell Download HERE
Acho que o último com suporte é o Monterey. Depois disso só na gambiarra do OCLP.
