Stuck when upgrade from Monterey to Ventura
Hello,
I currently have a working hackintosh under Monterey with this EFI folder but when I try to boot from the Ventura installer I get this error :
00:000 00:000 AAPL: #[EB.H.IS|!] Err(0xE) <- RT.GV boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
05:742 05:742 AAPL: #[EB.H.IS|!] Err(0xE) <- RT.GV boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
06:056 00:314 AAPL: #[EB|H:IS] 0
06:358 00:301 AAPL: #[EB|LOG:INIT] 2024-07-30T12:46:44
06:666 00:307 AAPL: #[EB|VERSION] <"bootbase.efi 577.140.2~22 (Official), built 2023-10-28T12:22:32-0700">
06:768 00:101 AAPL: #[EB|BUILD] <"BUILD-INFO[411]:{"DisplayName":"bootbase.efi","DisplayVersion":"577.140.2~22","RecordUuid":"45E4A878-54DB-42E3-BF98-E1AA0D42588C","BuildTime":"2023-10-28T12:22:32-0700","ProjectName":"efiboot","ProductName":"bootbase.efi","SourceVersion":"577.140.2","BuildVersion":"22","BuildConfiguration":"Release","BuildType":"Official","Compiler":"clang-1403.0.22.11","SdkVersion":"13.6","SdkBuild":"22G417","TargetArchitectures":"x86_64"}">
06:788 00:019 AAPL: #[EB.CFG.DEV|!] Err(0xE) <- RT.GV booter-strict-xmlparser 7C436110-AB2A-4BBB-A880-FE41995C9F82
06:807 00:019 AAPL: #[EB|CFG:DEV] r5 0x0 0x0
06:827 00:019 AAPL: #[EB|H:IS] 0
06:853 00:025 AAPL: #[EB|WL:MODE] 0
06:873 00:019 AAPL: #[EB|CFG:ARG] boot-save-log 0x0000000000000002 (0x0000000000000002 < 0xFFFFFFFFFFFFFFFF) default
06:901 00:028 AAPL: #[EB|CFG:ARG] wake-save-log 0x0000000000000002 (0x0000000000000002 < 0x0000000000000002) default
06:921 00:019 AAPL: #[EB|CFG:ARG] console       0x0000000000000001 (0x0000000000000001 < 0x0000000000000001) default
06:940 00:019 AAPL: #[EB|CFG:ARG] serial        0x0000000000000001 (0x0000000000000001 < 0x0000000000000000) default
06:965 00:024 AAPL: #[EB|CFG:ARG] preoslog      0x0000000000000001 (0x0000000000000001 < 0xFFFFFFFFFFFFFFFF) default
06:984 00:019 AAPL: #[EB|CFG:ARG] timestamps    0x0000000000000000 (0x0000000000000000 < 0xFFFFFFFFFFFFFFFF) default
07:004 00:019 AAPL: #[EB|CFG:ARG] log-level     0x0000000000000001 (0x0000000000000001 & 0x0000000000000021) default
07:024 00:019 AAPL: #[EB|CFG:ARG] breakpoint    0x0000000000000000 (0x0000000000000000 & 0x0000000000000000) default
07:051 00:027 AAPL: #[EB|CFG:ARG] kc-read-size  0x0000000000100000 (0x0000000000100000 < 0xFFFFFFFFFFFFFFFF) default
07:070 00:019 AAPL: #[EB|CFG:ARG] force-error   0x0000000000000000 (0x0000000000000000 & 0x0000000000000000) default
07:090 00:019 AAPL: #[EB|H:IS] 0
07:110 00:019 AAPL: #[EB|WL] 0 0 0x01 0x01   0 0x00
07:129 00:019 AAPL: #[EB|BRD:NV] Mac-27AD2F918AE68F61
07:155 00:025 AAPL: #[EB|B:VAw]
07:175 00:019 AAPL: #[EB|B:IAw]
07:194 00:019 AAPL: #[EB|WL] 0 0 0x01 0x01   2 0x00
07:214 00:019 AAPL: #[EB.BST.IDT|+]
07:235 00:020 AAPL: #[EB.BST.IDT|-]
07:256 00:021 AAPL: #[EB|WL] 0 0 0x01 0x01   3 0x00
07:276 00:019 AAPL: #[EB|WL] 0 0 0x01 0x01   4 0x00
07:295 00:019 AAPL: #[EB|BRD:NV] Mac-27AD2F918AE68F61
07:315 00:019 AAPL: #[EB|WL] 0 0 0x01 0x01   5 0x00
07:334 00:019 AAPL: #[EB.H.CHK|BM] 0x0000000000000000
07:355 00:020 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
07:375 00:019 AAPL: #[EB|WL] 0 0 0x01 0x01  23 0x0E
07:394 00:019 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
07:414 00:019 AAPL: #[EB|WL] 0 0 0x01 0x01  24 0x0E
07:434 00:020 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-image 7C436110-AB2A-4BBB-A880-FE41995C9F82
07:454 00:019 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
07:474 00:019 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
07:493 00:019 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-image 7C436110-AB2A-4BBB-A880-FE41995C9F82
07:513 00:019 AAPL: #[EB|H:NOT]
07:544 00:031 AAPL: #[EB|SB:P] 0x0
07:580 00:035 AAPL: #[EB|LIMG:DP] Acpi(PNP0A03,0)/Pci(1|2)/Pci(0|0)/Usb(3, 0)/HD(Part2,Sig0CB58266-2538-4B3A-AF44-DAB93A1A1A68)
07:600 00:019 AAPL: #[EB|LIMG:FP] \System\Library\CoreServices\boot.efi
07:619 00:019 AAPL: #[EB|LIMG:OPT]
07:640 00:020 AAPL: #[EB|RPS] 0 0 0
07:664 00:023 AAPL: #[EB.OPT.LXF|F] <"\\System\\Library\\CoreServices\\com.apple.Boot.plist">
07:683 00:019 AAPL: #[EB.LD.LF|IN] 0 1 <"\\System\\Library\\CoreServices\\com.apple.Boot.plist"> <"0">
07:703 00:019 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"\\System\\Library\\CoreServices\\com.apple.Boot.plist">
07:723 00:019 AAPL: #[EB.OPT.LXF|LF!] Err(0xE)
07:742 00:019 AAPL: #[EB.OPT.LXF|F] <"Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist">
07:766 00:023 AAPL: #[EB.LD.LF|IN] 0 1 <"Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist"> <"0">
07:787 00:021 AAPL: #[EB|KF] <"root-dmg=file:///BaseSystem/BaseSystem.dmg">
07:817 00:029 AAPL: #[EB|MBA:CL] <"">
07:837 00:019 AAPL: #[EB|MBA:NV] <"keepsyms=1 npci=0x2000 alcid=11 agdpmod=pikera -v slide=124">
07:859 00:022 AAPL: #[EB|MBA:KF] <"root-dmg=file:///BaseSystem/BaseSystem.dmg">
07:879 00:019 AAPL: #[EB|MBA:OUT] <"keepsyms=1 npci=0x2000 alcid=11 agdpmod=pikera -v slide=124 root-dmg=file:///BaseSystem/BaseSystem.dmg">
07:899 00:019 AAPL: #[EB|LOG:VERBOSE] 2024-07-30T12:46:46
07:918 00:019 AAPL: #[EB.CSR.S|VAR] 0x00000FEF
07:938 00:019 AAPL: #[EB|OPT:BM] 0x2
07:962 00:023 AAPL: #[EB.OPT.LXF|F] <"\\System\\Library\\CoreServices\\PlatformSupport.plist">
07:981 00:019 AAPL: #[EB.LD.LF|IN] 0 1 <"\\System\\Library\\CoreServices\\PlatformSupport.plist"> <"0">
08:002 00:020 AAPL: #[EB|P:CPR] N
08:021 00:019 AAPL: #[EB|P:MPI] N
08:051 00:029 AAPL: #[EB|P:BPI] N
08:074 00:022 AAPL: #[EB.OPT.RKS|!] Err(0xE) <- BS.LocP EDB4A040-6D8A-11EC-8FAD-3E22FB93ADCF
08:094 00:020 AAPL: #[EB|KMR] 373841920
08:113 00:019 AAPL: #[EB.CS.CSKSD|+]
08:133 00:019 AAPL: #[EB.CS.CSKSD|!] Err(0xE) <- RT.GV boot-info-payload 8D63D4FE-BD3C-4AAD-881D-86FD974BC1DF
08:155 00:022 AAPL: #[EB.G.CS|-?] Ok(0)
08:188 00:032 AAPL: #[EB.LD.LF|IN] 0 1 <"<null string>"> <"1">
08:218 00:029 AAPL: #[EB.B.SBS|SZ] 723512
08:242 00:024 AAPL: #[EB|B:SHA] <c33af8ea725fa4ca7d5533f2d47e89874c6255ff>
08:263 00:020 AAPL: #[EB.WL.PWLFNV|!] Err(0xE) <- RT.GV wake-failure 7C436110-AB2A-4BBB-A880-FE41995C9F82
08:284 00:021 AAPL: #[EB.WL.DT|!] Err(0xE) <- EB.WL.PWLFNV
08:304 00:019 AAPL: #[EB.WL.PWLFRTC|NONE]
08:324 00:020 AAPL: #[EB.WL.DT|!] Err(0xE) <- EB.WL.PWLFRTC
08:345 00:020 AAPL: #[EB.LD.LKC|D] <"System\Library\KernelCollections\BootKernelExtensions.kc.development">
08:369 00:024 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"System\\Library\\KernelCollections\\BootKernelExtensions.kc.development">
08:391 00:022 AAPL: #[EB.LD.LKC|R.2] <"System\Library\KernelCollections\BootKernelExtensions.kc">
09:513 01:121 AAPL: #[EB.LD.LKFS|-?] Ok(0)
09:537 00:023 AAPL: #[EB.LD.LKC|-?] Ok(0)
09:560 00:023 AAPL: #[EB|BST:REV1]
09:580 00:019 AAPL: #[EB|CSR:OUT] 0x00000FEF
09:602 00:021 AAPL: #[EB.BST.FBS|+]
09:622 00:019 AAPL: #[EB.BST.FBS|ADSZ] 0
09:641 00:019 AAPL: #[EB.BST.FBS|KSSZ] 0
09:671 00:029 AAPL: #[EB|SB:SBGMFNS] x86legacyap.im4m
09:693 00:022 AAPL: #[EB|RH:PF] usr\standalone\OS.dmg.root_hash
09:714 00:020 AAPL: #[EB|RH:MF] <"usr\\standalone\\OS.dmg.root_hash.x86legacyap.im4m">
09:734 00:020 AAPL: #[EB.LD.LF|IN] 0 1 <"usr\\standalone\\OS.dmg.root_hash"> <"0">
09:755 00:020 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"usr\\standalone\\OS.dmg.root_hash">
09:775 00:019 AAPL: #[EB.RH.LRH|P!] Err(0xE) <- EB.LD.LF
09:798 00:023 AAPL: #[EB.BST.FBS|!] Err(0xE) <- EB.RH.LRH
09:818 00:019 AAPL: #[EB|LOG:DT] 2024-07-30T12:46:48
09:839 00:020 AAPL: #[EB|LOG:EXITBS:START] 2024-07-30T12:46:48
Edited by mbanned
edit link
