help! i was getting errors on my sequoia!
When i try to install it i get mem panic or a mem panic reboot.
Zip my efi @Mald0n if ure avaible cuz i cant do efis.
EFI.zip.001.zip
part 2 (pls dont accept as spam i did to 2mb/each)
EFI.zip.002.zip
p3EFI.zip.003.zip
EFI.zip.004.zip
oh
i will give it
its openable only with 7zip
make sure u downloaded it
Damn its not extracting all. i give efi:
(do not forget to all kernel patches to patches and add NPCI command if u dont have above 4g decode)
https://drive.google.com/file/d/1T3femQla2JS5XKDMaDSmV6JJ-IIWE0qd/view (if u have an external pc has an AMD)
https://drive.google.com/file/d/1E-IjmqZzCQJwtLWYum6UtaPcACirzwGI/view (i was had to do cause i cant think and test the zip)
Using miuiturkiye & Olarila.com & osxinfo forums. (there is more i use shh, i live in turkey)
doesnt work
