wieniu26 Posted September 19, 2011 Posted September 19, 2011 I have a Asus laptop and the motherboard G51jx from mobo G60JX. The problem with the system locked up. Please help. Wifi does not work, audio, Memory Cards (mmc, SD...). sorry for my English Y550 had earlier and there was no problem. ASUS G51JX-X5 Intel Core i7 720QM 6GB 500GB 15.6IN FHD GeForce GTS360M HM55, Intel 5 Series Chipset, ALC663, AR8131, AR9285, G60JX.zip ASUS G51JX-X5 10.7.3 Lion Intel Core i7 720QM 6GB 500GB 15.6IN FHD GeForce GTS360M HM55, Intel 5 Series Chipset, ALC663, AR8131, AR9285,
Administrators MaLd0n Posted September 20, 2011 Administrators Posted September 20, 2011 dsdt.wieniu26.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
wieniu26 Posted September 24, 2011 Author Posted September 24, 2011 Thank you very much Shutdown is OK. bravo sleeping (flashing, blinking backlight keyboard) - no sleep wakes up, the problem with the screen, Can I fix it? From the top thank you very much P.S I had an error [pci configuration begin] I changed AppleACPIPlatform and IOPCIFamily Snow Leopard 10.6.6 and it is OK, now Sleep Ok Hotkeys OK NO Audio (voodoohda = KP) please help ASUS G51JX-X5 10.7.3 Lion Intel Core i7 720QM 6GB 500GB 15.6IN FHD GeForce GTS360M HM55, Intel 5 Series Chipset, ALC663, AR8131, AR9285,
rene Posted September 24, 2011 Posted September 24, 2011 A “fix” for [PCI Configuration begin] bug best fix is adding kernel boot flag: npci=0×2000 -v (voodoohda = KP) > remove appleHDA from /S/L/E Or use AppleHDAdisabler: http://Olarila.com/forum/download/file.php?id=281 GA-Z77X-UD5H i7-3770K | 8GB | Gigabyte GTX660 2GB | SAMSUNG PRO 256GB; no DSDT; 10.8.4/10.9 DP8 GA-Z68X-UD3H-B3 | i7-2600K@3.4GHz | 8GB | HD6870 | WD 2TB SATA3 | DP2 GA-P35C-DS3R | Intel Pentium E6500 | 8GB DDR3 | XFX HD 5770 | 10.9 DP8
wieniu26 Posted September 24, 2011 Author Posted September 24, 2011 I removed AppleHDA and is KP npci=0×2000 -v, arch=386 does not work ASUS G51JX-X5 10.7.3 Lion Intel Core i7 720QM 6GB 500GB 15.6IN FHD GeForce GTS360M HM55, Intel 5 Series Chipset, ALC663, AR8131, AR9285,
rene Posted September 24, 2011 Posted September 24, 2011 Did you run kext utility to rebuild caches? and it is: npci=0×2000 arch=i386 -v Mind the i386 and NOT 386 GA-Z77X-UD5H i7-3770K | 8GB | Gigabyte GTX660 2GB | SAMSUNG PRO 256GB; no DSDT; 10.8.4/10.9 DP8 GA-Z68X-UD3H-B3 | i7-2600K@3.4GHz | 8GB | HD6870 | WD 2TB SATA3 | DP2 GA-P35C-DS3R | Intel Pentium E6500 | 8GB DDR3 | XFX HD 5770 | 10.9 DP8
wieniu26 Posted September 24, 2011 Author Posted September 24, 2011 yes yes i386 always PCI Configuration begin Only change AppleACPIPlatform and IOPCIFamily from Snow Leopard 10.6.6 and NO PCI Configuration... hurra But stops "Waiting for DSMOS" ASUS G51JX-X5 10.7.3 Lion Intel Core i7 720QM 6GB 500GB 15.6IN FHD GeForce GTS360M HM55, Intel 5 Series Chipset, ALC663, AR8131, AR9285,
rene Posted September 24, 2011 Posted September 24, 2011 Are you using FakeSMC in /Extra/Extensions? Try it in /System/Library/Extensions Boot with (or add your own boot flags): -f -v or -x -v And use Extra folder from Mald0n, read his topic. GA-Z77X-UD5H i7-3770K | 8GB | Gigabyte GTX660 2GB | SAMSUNG PRO 256GB; no DSDT; 10.8.4/10.9 DP8 GA-Z68X-UD3H-B3 | i7-2600K@3.4GHz | 8GB | HD6870 | WD 2TB SATA3 | DP2 GA-P35C-DS3R | Intel Pentium E6500 | 8GB DDR3 | XFX HD 5770 | 10.9 DP8
wieniu26 Posted September 25, 2011 Author Posted September 25, 2011 I have a lion-installing flash drive http://Olarila.com/forum/viewtopic.php?f=17&t=134 , My chameleon 2 -1552 I changed /system/library/Extensions - AppleACPIPlatform and IOPCIFamily from Snow Leopard 10.6.6 and now there is NO [PCI Configuration begin] Now stops at waiting for dsmos dsmos.kext removal does not help my Extra... ASUS G51JX-X5 10.7.3 Lion Intel Core i7 720QM 6GB 500GB 15.6IN FHD GeForce GTS360M HM55, Intel 5 Series Chipset, ALC663, AR8131, AR9285,
artur-pt Posted September 25, 2011 Posted September 25, 2011 I have a lion-installing flash drive http://Olarila.com/forum/viewtopic.php?f=17&t=134 , My chameleon 2 -1552 I changed /system/library/Extensions - AppleACPIPlatform and IOPCIFamily from Snow Leopard 10.6.6 and now there is NO [PCI Configuration begin] Now stops at waiting for dsmos dsmos.kext removal does not help my Extra... hi, try to use all kext from e/e in s/l/e and in boot use -f lion use kernelcache to force read all kext from s/l/e PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
wieniu26 Posted February 3, 2012 Author Posted February 3, 2012 hi After updating to 10.7.3 is not working wi-fi AR9285, please help ASUS G51JX-X5 10.7.3 Lion Intel Core i7 720QM 6GB 500GB 15.6IN FHD GeForce GTS360M HM55, Intel 5 Series Chipset, ALC663, AR8131, AR9285,
artur-pt Posted February 3, 2012 Posted February 3, 2012 hello use io80211 from 10.7.2 good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
wieniu26 Posted April 4, 2012 Author Posted April 4, 2012 Thank you works ASUS G51JX-X5 10.7.3 Lion Intel Core i7 720QM 6GB 500GB 15.6IN FHD GeForce GTS360M HM55, Intel 5 Series Chipset, ALC663, AR8131, AR9285,
