Hi Guys please help me to install olarila Bigsur image on my spec:
I7-3770
giga b75md3v
16gb ddr3 1600
xfx rx 580 8gb
Storage: Kingstone SSD 120gb SATA
I did the following
-Sata = AHCI mode
-Secure Boot = Disable if need
According to the tutorial, it installs with the efi file for ivy bridge and the mod efi version, but it gives the following error : OC: Failed to load configuration
By the way, I have already managed to install Niresh Catalina 10.15, but I need higher versions and they are not installed.
Edited by sasan gh
Im talking about that
My bro Do you mean that my motherboard giga b75md3v does not support higher than Catalina?
But I want to install Big Sur or Monterey on my system. I mentioned the system specifications above
Edited by sasan gh
