Building a Hackintosh - The Ultimate Guide with step by step
-Problems with Paypal HERE
-Installation Guide HERE
-Hackintosh EFI folders HERE
-Hackintosh USB Remap HERE
-Guides and Tutorials HERE
Some Basic Information
-Bios/UEFI configuration check HERE
-If you have only IGPU use -igfxvesa bootarg for easy installation
-Reset NVRAM one time - OpenCore use entry "Reset Nvram" / Clover use F11 key on boot screen
a) If you used SSDT instead DSDT uncheck RebaseRegions in Acpi tab
b) You can request one full ACPI solution HERE and Premium Users HERE
c) After installation you need remove unnecessary files like unused Lan kexts
d) Remove agdpmod=pikera bootarg if you have RX550, RX560, RX570 and RX580
e) If your LAN card don't need dk.e1000=0 and e1000=0, remove these bootargs
f) Users with IGPU need change SMBIOS and create video patch
Step 1 - Downloading Olarila Vanilla Images or Create one Vanilla USB Installer
1a) Olarila Images (Windows, Mac or Linux) HERE
1b) How to create USB Installer (Mac) HERE
Step 2 - Burning Olarila Images with Balena Etcher with Windows, macOS or Linux
2a) Download Link HERE
Step 3 - Downloading correct EFI folder for your hardware with Clover or OpenCore
3a) OpenCore and Clover HERE
3b) OpenCore MOD HERE
Step 4 - Copying EFI folder to USB EFI partition with macOS or Windows HERE
Step 5 - Formatting SSD on Installer
5a) On Disk Utility Change "View" options to "Show All Devices"
5b) Selecting and formatting SSD. Use GUID and APFS
Step 6 - Copying EFI folder to SSD EFI partition after Installation HERE
Step 7 - Starting a real fine tune with full ACPI solution. About Premium and Donators users check HERE
Step 8 - USB Port Mapping HERE
Step 9 - Audio Solution HERE
Step 10 - Dual Boot with OpenCore and Full ACPI Solution HERE
Step 11 - How to update OpenCore bootloader HERE
Step 12 - How to generate SMBIOS and Serial on Hackintosh HERE
Step 13 - Mobile Intel HD Graphics HERE
Step 14 - Run Olarila Repair one time HERE
Step 15 - Olarila Guides and Tutorials HERE. More than a hundred tutorials for your Vanilla.
Credits:
We're all here to have fun and learn from each other! That's all Folks!
