1. I am facing Issues with the Connector Type when I open the Hackintool app and check the connectors it shows my display is connected via DP port instead of HDMI and then I manually selected HDMI and generated the patch and restarted but It again shows DP is there a way I can fix it
When I use the Patch tab in Hackitnool and use apply current patches it switches to HDMI but if I untick apply current patches it shows again DP Port
2. The average boot time is around 1 minute or so please is it a good time to boot considering I use SSD?
Edited by Dhaval Thakkar
TEXT
Thanks sir for your reply
I Tried but still no luck if open Hackintool without patches ticked it shows it as DP Port only and secondly I am facing issues with sleep in Hackintosh if before I get the message on display that its no connection found going to stand by mode if I press enter multiple some time it boots back or sometimes the cpu and keyboard + mouse are active and can be confirmed due to LED but the display won't turn on could there be any suggestions I had one restart in sleep and had panic attack had recovered a log if could be useful
Screenshot 2024-07-03 at 4.14.08 AM.zip config.plist.zip EFI Screenshot.zip
Reboot Kernel Panic.zip
reattached correct file
