Easy way to add missing device in Hackintosh with ACPI
-Problems with Paypal HERE
-Installation Guide HERE
-Hackintosh EFI folders HERE
-Hackintosh USB Remap HERE
Download Ioreg Explorer by Apple HERE
Download MaciASL by phpdev32 HERE
Let's check one good example on AMD build with missing NVME device. Check image bellow.
The correct thing would be _SB.PCI0.GPP9.SSD0, but somehow it seems to me that the Devs forgot to inject device
The solution is easy. We just need inject correct Device (NAME) and correct Name (_ADR, Zero) in this case.
The name can be random with 4 letters or numbers. The first character must be a letter and not a number.
Examples Name (_ADR:
@0 = Name (_ADR, Zero)
@8,1Name (_ADR, 0x00080001)
@1E,5Name (_ADR, 0x001E0005)
Check this SSDT MaLd0n-SSD.aml.zip
Bonus: We can inject device-id and vendor-id in this case to fix "Generic" SSD on system profiler
Let's check other example
Check missing devices and correct Name (_ADR on Ioreg. Check image bellow
Let's inject one device
@8,1 = Name (_ADR, 0x00080001) we just need create device
Quote
Scope (\_SB.PC00)
        Device (MAC1)
            Name (_ADR, 0x00080001)  // _ADR: Address
            Method (_STA, 0, NotSerialized)  // _STA: Status
                If (_OSI ("Darwin"))
                    Return (0x0F)
                Else
                    Return (Zero)
SSDT devices example SSDT-Devices.aml.zip
We're all here to have fun and learn from each other! That's all Folks!
  • Like 3
Great sir very helpful for this generic to Apple ssd controller but one problem I have two nvme it’s show only one nvme Apple Ssd controller and second one show generic controller
Use device properties for that
https://www.olarila.com/topic/39804-how-to-fix-generic-ssd-controller-on-nvme-device-on-hackintosh
Just use this topic if u need create device, if device is missing on ACPI/Ioreg.
:guitar
Thank you!!! Enjoy!!!
