How to fix Generic SSD Controller on NVME device on Hackintosh
-Problems with Paypal HERE
-Installation Guide HERE
-Hackintosh EFI folders HERE
-Hackintosh USB Remap HERE
Let's fix the problem on image bellow
1- Download gfxutil HERE Credits: acidanthera
Open Ioreg Explorer from Apple and check correct device. Download HEREin this case is @6 _SB.PC00.PEG0.PEGP
Run this tool and check correct device propertie NVME. In this case is PciRoot(0x0)/Pci(0x6,0x0)/Pci(0x0,0x0)
2- Apply the patch bellow on Device Properties / Add in your config.plist
Apple SSD Controller
Quote
<key>PciRoot(0x0)/Pci(0x6,0x0)/Pci(0x0,0x0)</key>
            <dict>
                <key>#pci-aspm-default</key>
                <data>AgAAAA==</data>
                <key>device-id</key>
                <data>BqgAAA==</data>
                <key>vendor-id</key>
                <data>TRQAAA==</data>
            </dict>
Result
We're all here to have fun and learn from each other! That's all Folks!
a little help here i use your tutorial and still have generic ssd controller what's the problem?
Asus Vivobook X512DA Ventura 13.5 (ventura works like a charm)
Lenovo ideapad Z710 on sequoia 15.7
Desktop: Asus Z97-C|CPU intel i7 4770K|Nvidia GT 720 2GB|Sequoia 15.6.1| OC 1.0.6
Iphone 14 128GB ios 26
If dont work this patch is applied in wrong adr
ok thank you
U just need apply patch in correct device.
