Help Needed to Configure MSI GE72 6QD for Monterey Installation
Hello everyone,
I've spent 3 months and restarted my computer hundreds of times, but now I've run out of options and need your help.
Here are my computer's specifications:
  • MSI GE72 6QD
  • Intel® Skylake i7 6700HQ
  • Intel® HM170
  • DDR4-2133, 16GB
  • 17.3" Full HD (1920 x 1080), IPS level panel (optional)
  • GeForce® GTX 960M 2GB GDDR5
  • NVMe M.2 SSD by PCIe Gen3
  • Bluetooth v4.0
  • 1x USB 3.1 Type-C
  • Wifi bcm94352z
I installed Monterey (Opencore), but after passing the -v command lines, it gets stuck at the Apple logo as shown in the picture.
I am sending the EFI folder and error log in hopes that you can help me configure it correctly. I am new to Hackintosh, so there are many things I don't understand.
Thank you very much, and I wish you all good health.
Link EFI folder
https://www.dropbox.com/scl/fi/5j3bizxn4p06f3byqwhfh/efilog.zip?rlkey=woxeui5xs583qe30ez0j8hp94&st=4u3l6kvs&dl=0
image -v  https://www.dropbox.com/scl/fi/da6pgglpmgdjeptpwz23n/6ec3e910318291dcc893.jpg?rlkey=51ycregalkgsr5n6mgbvg49yx&st=fp184i5k&dl=0
image stuck logo apple  https://www.dropbox.com/scl/fi/3n4io4kd2wlmmoca09rty/d60698d54047e019b956.jpg?rlkey=0peelmemhy6qzgwtlu8dgp768&st=o3epg7bc&dl=0
config.plist.zip
00:000 00:000 OC: Enable VMX - Write Protected
06:385 06:385 OCM: Failed to start image - Already started
06:465 00:079 BS: Failed to start OpenCore image - Already started
06:550 00:085 BS: Failed to load OpenCore from disk - Already started
06:636 00:086 OC: Boot failed - Already started
06:902 00:265 OCB: StartImage failed - Already started
12:988 06:085 AAPL: #[EB.H.IS|!] Err(0xE) <- RT.GV boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
13:073 00:085 AAPL: #[EB.H.IS|!] Err(0xE) <- RT.GV boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
13:173 00:099 AAPL: #[EB|H:IS] 0
13:267 00:094 AAPL: #[EB|LOG:INIT] 2024-06-02T16:40:15
13:351 00:084 AAPL: #[EB|VERSION] <"bootbase.efi 540.120.3~37 (Official), built 2023-08-17T08:16:50-0700">
13:436 00:084 AAPL: #[EB|BUILD] <"BUILD-INFO[308]:{"DisplayName":"bootbase.efi","DisplayVersion":"540.120.3~37","RecordUuid":"F16325DC-0C41-4324-9FEC-61D8AE53CD48","BuildTime":"2023-08-17T08:16:50-0700","ProjectName":"efiboot","ProductName":"bootbase.efi","SourceVersion":"540.120.3","BuildVersion":"37","BuildConfiguration":"Release","BuildType":"Official"}">
13:520 00:084 AAPL: #[EB.CFG.DEV|!] Err(0xE) <- RT.GV booter-strict-xmlparser 7C436110-AB2A-4BBB-A880-FE41995C9F82
13:606 00:085 AAPL: #[EB|CFG:DEV] r5 0x0 0x0
13:692 00:086 AAPL: #[EB|H:IS] 0
13:781 00:088 AAPL: #[EB|WL:MODE] 0
13:869 00:088 AAPL: #[EB|CFG:ARG] boot-save-log 0x0000000000000002 (0x0000000000000002 < 0xFFFFFFFFFFFFFFFF) default
13:959 00:089 AAPL: #[EB|CFG:ARG] wake-save-log 0x0000000000000002 (0x0000000000000002 < 0x0000000000000002) default
14:049 00:089 AAPL: #[EB|CFG:ARG] console       0x0000000000000001 (0x0000000000000001 < 0x0000000000000001) default
14:142 00:093 AAPL: #[EB|CFG:ARG] serial        0x0000000000000001 (0x0000000000000001 < 0x0000000000000000) default
14:229 00:086 AAPL: #[EB|CFG:ARG] preoslog      0x0000000000000001 (0x0000000000000001 < 0xFFFFFFFFFFFFFFFF) default
14:313 00:084 AAPL: #[EB|CFG:ARG] timestamps    0x0000000000000000 (0x0000000000000000 < 0xFFFFFFFFFFFFFFFF) default
14:398 00:085 AAPL: #[EB|CFG:ARG] log-level     0x0000000000000001 (0x0000000000000001 & 0x0000000000000021) default
14:485 00:086 AAPL: #[EB|CFG:ARG] breakpoint    0x0000000000000000 (0x0000000000000000 & 0x0000000000000000) default
14:572 00:087 AAPL: #[EB|CFG:ARG] kc-read-size  0x0000000000100000 (0x0000000000100000 < 0xFFFFFFFFFFFFFFFF) default
14:660 00:088 AAPL: #[EB|H:IS] 0
14:750 00:089 AAPL: #[EB|WL] 0 0 0x01 0x01   0 0x00
14:840 00:090 AAPL: #[EB|BRD:NV] Mac-A5C67F76ED83108C
14:930 00:090 AAPL: #[EB|B:VAw]
15:033 00:103 AAPL: #[EB|B:IAw]
15:121 00:088 AAPL: #[EB|WL] 0 0 0x01 0x01   2 0x00
15:206 00:085 AAPL: #[EB.BST.IDT|+]
15:292 00:085 AAPL: #[EB|BM] X86LEGACYAP
15:379 00:086 AAPL: #[EB.BST.IDT|-]
15:466 00:087 AAPL: #[EB|WL] 0 0 0x01 0x01   3 0x00
15:555 00:088 AAPL: #[EB|WL] 0 0 0x01 0x01   4 0x00
15:645 00:089 AAPL: #[EB|BRD:NV] Mac-A5C67F76ED83108C
15:735 00:090 AAPL: #[EB|WL] 0 0 0x01 0x01   5 0x00
15:826 00:090 AAPL: #[EB.H.CHK|BM] 0x0000000000000000
15:919 00:093 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
16:019 00:100 AAPL: #[EB|WL] 0 0 0x01 0x01  23 0x0E
16:101 00:081 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
16:183 00:082 AAPL: #[EB|WL] 0 0 0x01 0x01  24 0x0E
16:266 00:083 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-image 7C436110-AB2A-4BBB-A880-FE41995C9F82
16:351 00:085 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
16:438 00:086 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
16:524 00:086 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-image 7C436110-AB2A-4BBB-A880-FE41995C9F82
16:612 00:087 AAPL: #[EB|H:NOT]
16:700 00:088 AAPL: #[EB|SB:P] 0x1
16:789 00:088 AAPL: #[EB.B.MN|BM:+SB]
16:885 00:095 AAPL: #[EB|LIMG:DP] Acpi(PNP0A03,0)/Pci(14|0)/Usb(7, 0)/HD(Part2,SigE077433C-787D-4985-B5E8-FF3B5FF40D81)
16:970 00:085 AAPL: #[EB|LIMG:FP] \System\Library\CoreServices\boot.efi
17:053 00:082 AAPL: #[EB|LIMG:OPT]
17:139 00:085 AAPL: #[EB|RPS] 0 0 0
17:231 00:092 AAPL: #[EB.OPT.LXF|F] <"\\System\\Library\\CoreServices\\com.apple.Boot.plist">
17:314 00:082 AAPL: #[EB.LD.LF|IN] 0 1 <"\\System\\Library\\CoreServices\\com.apple.Boot.plist"> <"0">
17:403 00:088 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"\\System\\Library\\CoreServices\\com.apple.Boot.plist">
17:492 00:089 AAPL: #[EB.OPT.LXF|LF!] Err(0xE)
17:581 00:089 AAPL: #[EB.OPT.LXF|F] <"Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist">
17:671 00:090 AAPL: #[EB.LD.LF|IN] 0 1 <"Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist"> <"0">
17:780 00:108 AAPL: #[EB|KF] <"root-dmg=file:///BaseSystem/BaseSystem.dmg">
17:862 00:081 AAPL: #[EB|MBA:CL] <"">
17:946 00:084 AAPL: #[EB|MBA:NV] <"-v  alcid=11 -wegnoegpu keepsyms=1 debug=0x100">
18:031 00:085 AAPL: #[EB|MBA:KF] <"root-dmg=file:///BaseSystem/BaseSystem.dmg">
18:117 00:085 AAPL: #[EB|MBA:OUT] <"-v alcid=11 -wegnoegpu keepsyms=1 debug=0x100 root-dmg=file:///BaseSystem/BaseSystem.dmg chunklist-security-epoch=0 -chunklist-no-rev2-dev">
18:204 00:087 AAPL: #[EB|LOG:VERBOSE] 2024-06-02T16:40:20
18:292 00:088 AAPL: #[EB|OPT:BM] 0x200082
18:382 00:089 AAPL: #[EB.OPT.LXF|F] <"\\System\\Library\\CoreServices\\PlatformSupport.plist">
18:471 00:089 AAPL: #[EB.LD.LF|IN] 0 1 <"\\System\\Library\\CoreServices\\PlatformSupport.plist"> <"0">
18:569 00:098 AAPL: #[EB|P:CPR] N
18:662 00:092 AAPL: #[EB|P:MPI] N
18:749 00:087 AAPL: #[EB|P:BPI] N
18:833 00:083 AAPL: #[EB|KMR] 501080064
18:919 00:085 AAPL: #[EB.CS.CSKSD|+]
19:005 00:086 AAPL: #[EB.CS.CSKSD|!] Err(0xE) <- RT.GV boot-info-payload 8D63D4FE-BD3C-4AAD-881D-86FD974BC1DF
19:093 00:087 AAPL: #[EB.G.CS|-?] Ok(0)
19:181 00:088 AAPL: #[EB.LD.LF|IN] 0 1 <"<null string>"> <"1">
19:298 00:116 AAPL: #[EB.B.SBS|SZ] 723512
19:391 00:093 AAPL: #[EB|B:SHA] <92357579250a33bb8cb838cf6531d8754043e473>
19:483 00:092 AAPL: #[EB.WL.PWLFNV|!] Err(0xE) <- RT.GV wake-failure 7C436110-AB2A-4BBB-A880-FE41995C9F82
19:575 00:091 AAPL: #[EB.WL.DT|!] Err(0xE) <- EB.WL.PWLFNV
19:676 00:100 AAPL: #[EB.WL.PWLFRTC|NONE]
19:761 00:085 AAPL: #[EB.WL.DT|!] Err(0xE) <- EB.WL.PWLFRTC
19:848 00:086 AAPL: #[EB.LD.LKC|D] <"System\Library\KernelCollections\BootKernelExtensions.kc.development">
19:935 00:087 AAPL: #[EB.LD.LF|IN] 0 1 <"System\\Library\\KernelCollections\\BootKernelExtensions.kc.development"> <"0">
20:024 00:088 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"System\\Library\\KernelCollections\\BootKernelExtensions.kc.development">
20:113 00:089 AAPL: #[EB.LD.LKC|R.2] <"System\Library\KernelCollections\BootKernelExtensions.kc">
20:203 00:090 AAPL: #[EB.LD.LF|IN] 0 1 <"System\\Library\\KernelCollections\\BootKernelExtensions.kc"> <"0">
25:385 05:182 AAPL: #[EB|SB:P] 0x1
25:478 00:093 AAPL: #[EB|SB:SBGMFNS] x86legacyap.im4m
25:567 00:088 AAPL: #[EB|SB:MF] System\\Library\\KernelCollections\\BootKernelExtensions.kc.x86legacyap.im4m
25:667 00:099 AAPL: #[EB.LD.LF|IN] 0 1 <"System\\Library\\KernelCollections\\BootKernelExtensions.kc.x86legacyap.im4m"> <"0">
25:960 00:292 AAPL: #[EB|SB:MKRN]
26:048 00:088 AAPL: #[EB.LD.LKFS|-?] Ok(0)
26:132 00:083 AAPL: #[EB.LD.LKC|-?] Ok(0)
26:218 00:085 AAPL: #[EB|BST:REV1]
26:303 00:085 AAPL: #[EB|CSR:IN] 0x00000067
26:391 00:087 AAPL: #[EB|CSR:OUT] 0x00000067
26:486 00:095 AAPL: #[EB.BST.FBS|+]
26:570 00:084 AAPL: #[EB|GIP:PHS.1] Boot 1
26:660 00:089 AAPL: #[EB.BST.FBS|ADSZ] 0
26:756 00:096 AAPL: #[EB.BST.FBS|KSSZ] 0
26:842 00:086 AAPL: #[EB|SB:SBGMFNS] x86legacyap.im4m
26:926 00:083 AAPL: #[EB|RH:PF] usr\standalone\OS.dmg.root_hash
27:011 00:084 AAPL: #[EB|RH:MF] <"usr\\standalone\\OS.dmg.root_hash.x86legacyap.im4m">
27:096 00:085 AAPL: #[EB.LD.LF|IN] 0 1 <"usr\\standalone\\OS.dmg.root_hash"> <"0">
27:183 00:086 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"usr\\standalone\\OS.dmg.root_hash">
27:270 00:087 AAPL: #[EB.RH.LRH|P!] Err(0xE) <- EB.LD.LF
27:358 00:087 AAPL: #[EB.BST.FBS|!] Err(0xE) <- EB.RH.LRH
27:448 00:090 AAPL: #[EB|LOG:DT] 2024-06-02T16:40:30
27:537 00:089 AAPL: #[EB|LOG:EXITBS:START] 2024-06-02T16:40:30
Thank you, MaLd0n, for responding to my post.
I have downloaded the EFI folder you provided and used the command script:
-v igfxonln=1 igfxagdc=0 -wegnoegpu debug=0x100 keepsyms=1 -igfxvesa
However, it still gets stuck right after the -v command lines, as shown in the video I recorded.
What should I do next? Thank you.
Msi stuck Monterey (youtube.com)
Dont change nothing with my EFI folder
Just add -igfxvesa and disable video patch on device properties
-Last Bios/UEFI Version
