Greeting,
I am building Hackintosh using Opencore Sonoma, but I have a few issues. 1. wifi doesent work. 2. Graphis looks choppy ( I am using 2 X 35inch WQHD monitors) 3. The sidecar doesn't work. 4. Airdrop doesn't work. 5. USB ports are not correctly mapped. 6. Audio works but cannot be controlled from the keyboard.
I tried to fix the Wi-Fi with the Opencore Mordern wireless patch, but every time I did that, the system failed to reboot and got stuck on an ACPI error.
Configuration:
Gigabyte Z370 AROUS wifi gaming motherboard
Intel i3 8100
AMD Sapphire RX570 8 GB
Fenvi T919 - BCM94360CD
32 GB DDR4 2133 MHZ
NVME boot drive.
Can you please provide proper EFI folder?
Send me iMac-Pro.zip
Edited by dipen26
EFI.zip
-Last Bios UEFI Version
Run Root Patch on OCLP after reboot
Save new ioreg https://olarila.com/files/Utils/IORegistryExplorer.app.zip
U need enable IGPU on bios
After copying the EFI folder and NVRam reset, I used OCLP to patch. After the reboot I got stuck at “AMF1: '/System/Library/PrivateFraneworks/I080211.framework/Versions/R/I080211*: local signing public key not initialized
IMG_1734.zip
I had same issue before too. I tried many times but every time I use OCLP, I get stuck on the same error.
Edited by dipen26
Last oclp version?
Sonoma 14.3?
Latest version of OCLP and 14.3
I manually restarted and it is stuck at start:512: successfully initialized AHCI controller
Strange
Bios/uefi in full default just csm disable?
So I was able to resolve that issue. It happened due to an issue with UEFI boot, but now I am back on again, but can you guide me on how to save IOREG?
Volume control still doesn't work from the keyboard.
