Installed Ventura - problem with display, wifi, sound
Hello team,
I have an ASUS ROG Zephyrus GX701LWX and I managed to install macOS Ventura on it, but no sound, no graphics (integrated), no Wi-Fi.
Here is my EFI folder:
https://we.tl/t-KdXMsv4jMQ
Thanks in advance to anyone who can help me.
If you need any more information, I will be happy to share it.
What Hardware Specs
14 hours ago, MaLd0n said:
What Hardware Specs
Specs are:
Intel® Core™ i7-10875H Processor 2.3 GHz (16M Cache, up to 5.1 GHz, 8 cores)
NVIDIA® GeForce® RTX 2070 SUPER™
8GB GDDR6
16GB DDR4 - 2933MHz
1TB PCIe® 3.0 NVMe™ M.2 Performance SSD
1x 3.5mm Combo Audio Jack
1x HDMI 2.0b
2x USB 3.2 Gen 1 Type-A
1x USB 3.2 Gen 2 Type-A
1x USB 3.2 Gen 2 Type-C support DisplayPort™ / G-SYNC
1x Thunderbolt™ 3 support DisplayPort™ / power delivery / G-SYNC
Realtek ALC897
Wi-Fi 6(802.11ax) (Dual band) 2*2 + Bluetooth® 5.1 Wireless Card (*Bluetooth® version may change with OS version different.) -RangeBoost
On 12/4/2023 at 1:59 PM, MaLd0n said:
I added this Apple kext, still the video doesn't work.
Also added this wifi itlwm_v2.2.0_stable.kext.zip , still blocked.
Can you take a look at my EFI and check if everything is ok?
https://file.io/LV8RtGW66ARa
Also here is a screenshot from hackintool:
slike.zip
Edited by Иван Р.
15 hours ago, Иван Р. said:
I already did that. But I didn't use new whatevergreen.kext, because then I can't boot into the system. It keeps crashing and rebooting.
@MaLd0n
I'm sorry, the problem was because it was boot only with dGPU. Now booting from Intel graphics, and working with the latest whatevergreen.kext and all other kext are the latest.
Now I have problem with Intel UHD 630 7MB.
Do you have a solution?
I tried with several different AAPL, ig-platform-id and device-id, but it still won't work
Edited by Иван Р.
I solved it, everything is ok.
Everything works except bluetooth and sound on the speakers.
The sound on the headset works and the microphone works.
Tried with several different alcid, but they don't help.
