B550M Aorus Elite AX Random Freezing
I have built a new ryzen hackintosh and installed Monterey on it using Olarila vanilla images for monterey. I had a custom SSDT .aml file for RX 6650 XT and added it to my EFI from this thread here: https://www.olarila.com/topic/31182-upgraded-rx-5500-xt-to-6650-xt-no-hardware-acceleration-10mb-graphics/.        I added this SSDT file and installed Monterey but my graphics had no acceleration and only displayed 10mb in about this mac so I switched Whatevergreen for NootRX.kext which fixed acceleration. The problem is I get random freezing whenever I open programs, move the mouse or click it. It just displays the spinning beach ball. What could cause this @MaLd0n ? I have uploaded my EFI here since it is larger than the file size limit: https://github.com/jake99x3/ryzentosh/blob/main/EFI.zip
 Specs:
 Mobo: Gigabyte b550m aorus elite ax
 CPU: Ryzen 5800x
 GPU: 6650 XT 8GB
 16gb ram
Edited by jake99x3
Test this efi folder
https://easyupload.io/dq807q
