Laptop: PANASONIC Toughbook CF-MX4
CPU: i5-5300U (vPro)
GPU: Intell HD Graphics 5500
OS: 12.7.1
OC: 0.9.6
Hi guys, Im trying for several days to fix graphics acceleration for my machine, but it just dont wanna work.
Followed tutorials and add framebuffers, so far tried only few combinations of device-id & ig-platform-id (usually suggested default one 02001616, but tried some combination of different device-id last hours.. no success) I always ended up with: Intel HD Graphics 5500 7 MB (ofc. reset the NVRAM)
In BIOS I don`t have anything related to DVMT ? ..to that case. I always ended up with 7 MB.
Main sources of info, excluded of YT videos:
As I started with hackintosh, 3days ago, so far a wonderfull experience :D I feel like repairing luxury car (thanks to OpenCore)
Successfully patched DSDT , IRQs, finaly Audio is working enough for my use (Realtek ALC269, alcid=138), WiFi only using HeliPort.app but this is somehow ok (Wireless 7265).
In general, I think that I have "normal" EFI for me... I hope ?  ?
Other things on my list to be fixed, that are NOT WORKING at the moment are:
  • Brightness control
  • *mby battery management* battery goes down quite fast IMHO
  • Native WiFi ?
Included scrapped EFI folder for my setup :-)
And Thanks for Your Help .
EFI.zip
post entire efi folder
Check if work
https://easyupload.io/z8qy43
I recover originál EFI using linux. Thankfully its working.
 Will look at it again with OCAuxiliaryTools
Should I update the .kext first ?? I mean its still showing newer versions in OpenCore Configurator but old one in
OCAuxiliaryTools .... im confused
UPDATE:
so i manage to check your versions of kext files and keep their version, confog.plist check was OK.
BUT i got different error now:
Refusing new kext ru.usrsse2.SMCBatteryManager, v1.3.2; a prelinked copy with a different executable UUID is already present.
— NOT WORKING
brokem graphics see below
https://ibb.co/47tVgv1
Enable csm on bios
U need remove some kext on system folder, use only on bootloader kexts folder
WoW BIG THANKS
I disabled SMCthings so I wont need to fix EFI manualy and  disabled CMS, and graphics is working. ? Also brightness. All I need
even native WiFi but when I connect it restart my pc with panic again ? will stick with itlwm now .. . i dont know
https://ibb.co/10yVbzc
Sorry to bother you again.
Sleep is also not working either way.
Button + Lid wake up
Edited by theokeist
Use itlwm instead AirportItlwm if cause kp
Im not sure how to repair the Sleep / Wake up function. In my case when i either close the lid or click on Sleep than display turn black ofc but in both cases im unable to turn on again I have to restart pc.
Followed the Post Install guide and no diference.
Just black screen with some “line of graphics” literaly, once a time
Kill prws abd check if work
Quote
 <dict>
                    <key>Base</key>
                    <string></string>
                    <key>BaseSkip</key>
                    <integer>0</integer>
                    <key>Comment</key>
                    <string>_PRW to XPRW</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <true/>
                    <key>Find</key>
                    <data>X1BSVw==</data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data></data>
                    <key>OemTableId</key>
                    <data></data>
                    <key>Replace</key>
                    <data>WFBSVw==</data>
                    <key>ReplaceMask</key>
                    <data></data>
                    <key>Skip</key>
                    <key>TableLength</key>
                    <key>TableSignature</key>
                    <data></data>
                </dict>
Our .aml have all u need
Post full efi folder here
No idea what happens
Config looks correct just enable ssdt hpet if u renamed device
