I'm very confused why is it not working when they are the exact same laptops? Pls help
Hi, i have the exact same laptop that Jane has, i used her EFI along with a offline full image of Ventura 13.5 and its not working. I'm very confused why is it not working when they are the exact same laptops?
Here is the post I'm talking about  :
in this post Jane who has the exact same laptop as mine Successfully installed Ventura Hackintosh using this EFI : https://www.mediafire.com/file/8sgbp8d64e5uc15/EFI.zip/file
So I downloaded the EFI and tried the same but in my case as soon as I go to the OpenCore Boot and click on install Ventura, I see Apple logo for about 5 seconds then the screen goes black, then the laptop fans start running at max speed and in about 10 second after the laptop shuts down. Why is this happening?
so i just had to update kexts and it will work?
I did that I updated it properly and haven't made any changes to it its the exact same EFI except now I've updated the OC and Kexts like you said and now the fans don't go wild but still it's back to the old issue
I click the install Ventura option> apple logo comes and loads like ~10%> then laptop restarts
Here is the EFI(OC+Kexts updated using OCAT): https://drive.google.com/drive/folders/1gT6Epsh_ARsIZ9Q6hZh45qNzufKk5Sip?usp=sharing
(the EFI folder is inside the EFi Updated folder cause I have multiple EFIs in Google Drive)
Pls help I don't understand why is it not working on my laptop even though they're the same
Edited by Shobhit
