Installer EFI - https://drive.google.com/file/d/1H_rZlUFKVGKJJ2T69mC5AApn_PIZ_P-e/view?usp=sharing
Post Install EFI - https://drive.google.com/file/d/1YquaPNJrEgOAyKPHM-RslEM7n3xQXodP/view?usp=sharing
Hi All,
I have a Surface Book 3 running Sonoma with about 95percent working. What isn't working is the 2nd battery, bluetooth and the camera.
I have seen issues in the past where some people with a different hard drive will struggle and so if that's you then I am sorry.
Use the Installer EFI with your USB pen drive and the Post Install EFI on your Hard Drive when installation is complete.
You will need to full delete your laptop hdd and start fresh.
NEW EFI - https://drive.google.com/file/d/1AJKYdHIYE_moF4J9cQtmgGVh8chxgL57/view?usp=sharing
Okay so I was having some overheating issues on the base of the laptop and so I ran ACPIExtractAll and have applied them in this EFI. This has fixed all my issues, however if your laptop is different you may want to use the Post Install EFI at the top and then get your own ACPI tables, but you're welcome to use mine.
Good Luck
Edited by MetalChris87
  • Like 3
On 9/2/2024 at 10:29 AM, lxcvip said:
I have the 13.5" versionSurface Book 3 EFI
链接https://pan.baidu.com/s/1vT75pGUz0vNUT5EV4GP_HA?pwd=yjef 提取码: YJEF
Hi, I have a similarly configured surface book 3 as you do, but my install keeps failing, is it because downgrading the UEFI is required? I sometimes get stuck at BatteryInfo or HIDDriver and then “still waiting for root device”, sorry I'm such a Newbie at this.
No need to downgrade UEFI. Disable the DGPU option in the BIOS, use my EFI configuration file, and you can quickly reach the installation interface! Link: https://pan.baidu.com/s/1vT75pGUz0vNUT5EV4GP_HA?pwd=yjef Extraction code: yjef
Edited by lxcvip
Bro can you please share the EFI folders you sent in the first post
because in the give links file is not available
please it would be a great help , if you have updated EFI folder with everything working please do share bro
Why not
On 26/03/2025 at 07:31, MaLd0n said:
Por que não
I can follow the instructions in this thread, because they are talking about the Surface Book 3 and mine is the Laptop 3 model, I don't know if there is a difference.
Or, do I need to follow another thread of yours?
Z97 Maximus VII Formula  i7 4790K  RX580 8GB  32Gb 1866Mhz  Clover em UEFI
Need expert help with your Hackintosh?
Get professional Olarila support for:
Support us - Donate HERE
