Administrators MaLd0n Posted September 30, 2024 Author Administrators Posted September 30, 2024 6 hours ago, fabriktwo said: Eu quero fazer o seguinte, quero pagar pra deixar tudo da maneira que eu quero Veja aqui. Só me adicionar lá que a gente conversa sobre isso. https://olarila.com/topic/40850-consultoria-profissional-para-o-seu-hackintosh-desde-2006/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
moishiteru Posted October 7, 2024 Posted October 7, 2024 no luck to get working my Broadcom BCM94352HMB can you check my refi folder and config.plist https://easyupload.io/xhk96f thank you Asus Vivobook X512DA Ventura 13.5 (ventura works like a charm) Lenovo ideapad Z710 on sequoia 15.7 Desktop: Asus Z97-C|CPU intel i7 4770K|Nvidia GT 720 2GB|Sequoia 15.6.1| OC 1.0.6 Iphone 14 128GB ios 26
Administrators MaLd0n Posted October 7, 2024 Author Administrators Posted October 7, 2024 Check procedure on first post. Ur card need device-id. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
moishiteru Posted October 7, 2024 Posted October 7, 2024 4 hours ago, MaLd0n said: Check procedure on first post. Ur card need device-id. you mean spoof device-id??? I did it but not work and OCLP does not detect for patch "modern wireless" really weird... can you check my config.plist if I put the patch correctly? thank you Asus Vivobook X512DA Ventura 13.5 (ventura works like a charm) Lenovo ideapad Z710 on sequoia 15.7 Desktop: Asus Z97-C|CPU intel i7 4770K|Nvidia GT 720 2GB|Sequoia 15.6.1| OC 1.0.6 Iphone 14 128GB ios 26
Siddhart Kamath Posted October 18, 2024 Posted October 18, 2024 I followed all the steps mentioned above and only the bluetooth works. WiFi is still not detecting. My specs are as follows, CPU - Intel Corei9 10900KF MB - Gigabyte Z590UD PCiE - Fenvi FV-T919 1
Administrators MaLd0n Posted October 18, 2024 Author Administrators Posted October 18, 2024 Check procedure again. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Siddhart Kamath Posted October 19, 2024 Posted October 19, 2024 Just for reference, here's my EFI folder. I tried everything on the above list that you've mentioned and no luck just with WiFi. Everything else works perfectly fine.config.plist.zip 1
Administrators MaLd0n Posted October 19, 2024 Author Administrators Posted October 19, 2024 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
th3condor70 Posted October 21, 2024 Posted October 21, 2024 MaLd0n Worksalso forFenvi 1200 on Sequoia? i wasableto works with sonoma. but i have not tryed with sequoia yet ifnot, what the best broadcom chip forsequoia? T 919 ?
Administrators MaLd0n Posted October 21, 2024 Author Administrators Posted October 21, 2024 Yes. Work. All broadcom with native support. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
th3condor70 Posted October 28, 2024 Posted October 28, 2024 Nao consigo fazer funcionar o Wifi. Fenvi A1200, Bluetooth funciona, e tmb airport. Mas o Wifi fica inativo. nao tem como ativar a icona. poderia dar uma olhada ao meu config por favor? Placa Z490 Vision D ._config.zip
Administrators MaLd0n Posted October 28, 2024 Author Administrators Posted October 28, 2024 Segue o primeiro post desse tópico. Funciona perfeitamente. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
chrisc Posted November 16, 2024 Posted November 16, 2024 (edited) Hello, I have the same I updated OC, I am on a very fresh installation of sequoia 15.1 on hackintosh (H110M-K, RX580) as soon as I update in the kext the file: IOSkywalkFamily.kext I have a kernel panic https://gyazo.com/1aa5f992d6f52b560caa950df61059db (Screen KERNEL PANIC) https://xxg.fr/AuAqN9CS (EFI.ZIP) Edited November 16, 2024 by chrisc
Administrators MaLd0n Posted November 16, 2024 Author Administrators Posted November 16, 2024 Instructions on first page just work fine. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
chrisc Posted November 16, 2024 Posted November 16, 2024 (edited) I did as indicated in the tutorial, so I no longer have kernel panic, I have the wifi on but no network is displayed https://gyazo.com/8f2d4b32aeda96c8cac396f4fdd71225 Edited November 16, 2024 by chrisc 1
Administrators MaLd0n Posted November 16, 2024 Author Administrators Posted November 16, 2024 No run oclp root patcher -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
chrisc Posted November 16, 2024 Posted November 16, 2024 (edited) Ok I just launched OpenCore Legacy patcher and Post install and it works Edited November 16, 2024 by chrisc
Fatic Posted December 4, 2024 Posted December 4, 2024 Can you help enable for my wifi broadcom dev id 14e4-4365 subsystem id 062117AA. Thanks before https://www.mediafire.com/file/f8e46bis8ocfxcg/EFI+Z40-70.zip/file
Administrators MaLd0n Posted December 4, 2024 Author Administrators Posted December 4, 2024 3 hours ago, Fatic said: 14e4-4365 Inject 43a0 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
clytoneto Posted January 6, 2025 Posted January 6, 2025 Não sei colocar o Block por patch, onde inserido o patch? 1
