Loyd Posted June 28, 2014 Posted June 28, 2014 Very strange Despite my intense struggle I did not manage to save the info.plist when I add the code snippet for mic (see below)! I'm using plistedit Pro <key>NodesToPatch</key> <array> <dict> <key>Codec</key> <integer>0</integer> <key>Config</key> <string>0x99a30950</string> <key>Node</key> <integer>25</integer> </dict> </array> Here is my VoodooHDA, can you check please? VoodooHDA.kext.zip thanks for your time
pernacabeluda Posted June 28, 2014 Posted June 28, 2014 Try this Info.plist.zip Check my previous reply about other possible fix for the mic issue. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Loyd Posted June 28, 2014 Posted June 28, 2014 Thank you for the plist and your suggestions for the Mic. I will start to test the settings and will get back to news soon. Sincerely
sachka Posted July 12, 2014 Posted July 12, 2014 Hi guys, I've been reading throughout the thread for a couple of days, I installed VoodooHDA 2.8.5 after failing to get AppleHDA.kext to work 100% (mic / hdmi won't work) But I still have some issues, - Auto Detect or simply switching to headphone when plugging it in won't work (it worked on AppleHDA), - In the list of devices I don't have external mic jack option (black) - HDMI audio although showing up in settings, is not working, here is my getDump: Found a device of class VoodooHDADevice: IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/HDEF@1B/VoodooHDADevice Probing codec #0... HDA Codec #0: Conexant CX20585 HDA Codec ID: 0x14f15069 Vendor: 0x14f1 Device: 0x5069 Revision: 0x03 Stepping: 0x02 PCI Subvendor: 0x20981b0a startNode=1 endNode=2 Found audio FG nid=1 startNode=16 endNode=38 total=22 Processing audio FG cad=0 nid=1... Powering up... Parsing audio FG... GPIO: 0x40000004 NumGPIO=4 NumGPO=0 NumGPI=0 GPIWake=0 GPIUnsol=1 nid 25 0x04211040 as 4 seq 0 Headphones Jack 1/8 Right External Black misc 0 nid 26 0x90a70120 as 2 seq 0 Microphone Fixed Analog N/A Internal Unknown misc 0 NoPresenceDetect nid 27 0x04a11030 as 3 seq 0 Microphone Jack 1/8 Right External Black misc 0 nid 28 0x400001f0 as 15 seq 0 Line-out None Unknown N/A External Unknown misc 0 NoPresenceDetect nid 29 0x400001f0 as 15 seq 0 Line-out None Unknown N/A External Unknown misc 0 NoPresenceDetect nid 30 0x400001f0 as 15 seq 0 Line-out None Unknown N/A External Unknown misc 0 NoPresenceDetect nid 31 0x90170110 as 1 seq 0 Speaker Fixed Analog N/A Internal Unknown misc 0 NoPresenceDetect nid 32 0x400001f0 as 15 seq 0 Line-out None Unknown N/A External Unknown misc 0 NoPresenceDetect nid 34 0x400001f0 as 15 seq 0 Line-out None Unknown N/A External Unknown misc 0 NoPresenceDetect nid 35 0x400001f0 as 15 seq 0 Line-out None Unknown N/A External Unknown misc 0 NoPresenceDetect Parsing vendor patch... Nodes patching. Codec = 0 NumNodes = 0 VHDevice NID=16 Config=00000000 (audio output ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=17 Config=00000000 (audio output ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=18 Config=00000000 (audio output ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=19 Config=00000000 (beep widget ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=20 Config=00000000 (audio input ) Cap=00000000 Ctrl=00000000 -- Conns: 0=23 1=24 2=35 3=36 VHDevice NID=21 Config=00000000 (audio input ) Cap=00000000 Ctrl=00000000 -- Conns: 0=23 1=24 2=35 3=36 VHDevice NID=22 Config=00000000 (audio input ) Cap=00000000 Ctrl=00000000 -- Conns: 0=23 1=24 2=35 3=36 VHDevice NID=23 Config=00000000 (audio selector) Cap=00000000 Ctrl=00000000 -- Conns: 0=26 1=27 2=29 3=30 VHDevice NID=24 Config=00000000 (audio selector) Cap=00000000 Ctrl=00000000 -- Conns: 0=26 1=27 2=29 3=30 VHDevice NID=25 Config=04211040 (pin: Headphone) Cap=0000001c Ctrl=000000c0 -- Conns: 0=16 1=17 VHDevice NID=26 Config=90a70120 (pin: Microphon) Cap=00001324 Ctrl=00000024 -- Conns: VHDevice NID=27 Config=04a11030 (pin: Microphon) Cap=00011334 Ctrl=00000000 -- Conns: 0=16 1=17 VHDevice NID=28 Config=400001f0 (pin: Line-out ) Cap=00000014 Ctrl=00000000 -- Conns: 0=16 1=17 VHDevice NID=29 Config=400001f0 (pin: Line-out ) Cap=00010034 Ctrl=00000000 -- Conns: 0=16 1=17 VHDevice NID=30 Config=400001f0 (pin: Line-out ) Cap=00000024 Ctrl=00000000 -- Conns: VHDevice NID=31 Config=90170110 (pin: Speaker () Cap=00000010 Ctrl=00000040 -- Conns: 0=16 1=17 VHDevice NID=32 Config=400001f0 (pin: Line-out ) Cap=00000010 Ctrl=00000000 -- Conns: 0=18 VHDevice NID=33 Config=00000000 (audio output ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=34 Config=400001f0 (pin: Line-out ) Cap=00000010 Ctrl=00000000 -- Conns: 0=33 VHDevice NID=35 Config=400001f0 (pin: Line-out ) Cap=00000020 Ctrl=00000000 -- Conns: VHDevice NID=36 Config=00000000 (audio mixer ) Cap=00000000 Ctrl=00000000 -- Conns: 0=16 1=17 VHDevice NID=37 Config=00000000 (vendor widget ) Cap=00000000 Ctrl=00000000 -- Conns: Disabling nonaudio... Disabling useless... Disabling nid 20 connection 2 due to disabled child widget. Disabling nid 21 connection 2 due to disabled child widget. Disabling nid 22 connection 2 due to disabled child widget. Disabling nid 23 connection 2 due to disabled child widget. Disabling nid 23 connection 3 due to disabled child widget. Disabling nid 24 connection 2 due to disabled child widget. Disabling nid 24 connection 3 due to disabled child widget. Patched pins configuration: nid 25 0x04211040 as 4 seq 0 Headphones Jack 1/8 Right External Black misc 0 nid 26 0x90a70120 as 2 seq 0 Microphone Fixed Analog N/A Internal Unknown misc 0 NoPresenceDetect nid 27 0x04a11030 as 3 seq 0 Microphone Jack 1/8 Right External Black misc 0 nid 28 0x400001f0 as 15 seq 0 Line-out None Unknown N/A External Unknown misc 0 NoPresenceDetect [DISABLED] nid 29 0x400001f0 as 15 seq 0 Line-out None Unknown N/A External Unknown misc 0 NoPresenceDetect [DISABLED] nid 30 0x400001f0 as 15 seq 0 Line-out None Unknown N/A External Unknown misc 0 NoPresenceDetect [DISABLED] nid 31 0x90170110 as 1 seq 0 Speaker Fixed Analog N/A Internal Unknown misc 0 NoPresenceDetect nid 32 0x400001f0 as 15 seq 0 Line-out None Unknown N/A External Unknown misc 0 NoPresenceDetect [DISABLED] nid 34 0x400001f0 as 15 seq 0 Line-out None Unknown N/A External Unknown misc 0 NoPresenceDetect [DISABLED] nid 35 0x400001f0 as 15 seq 0 Line-out None Unknown N/A External Unknown misc 0 NoPresenceDetect [DISABLED] Parsing pin associations... 4 associations found: Association 0 (1) out: Pin nid=31 seq=0 Redir type=-1 jack=-1 def=0 Association 1 (2) in: Pin nid=26 seq=0 Redir type=-1 jack=-1 def=0 Association 2 (3) in: Pin nid=27 seq=0 Redir type=-1 jack=0 def=0 Association 3 (4) out: Pin nid=25 seq=0 Redir type=-1 jack=0 def=0 Building AFG tree... Tracing association 0 (1) Tracing pin 31 with min nid 0 tracing via nid 31 tracing via nid 16 nid 16 returned 16 tracing via nid 17 nid 17 returned 17 nid 31 returned 16 Pin 31 traced to DAC 16 Association 0 (1) trace succeeded Tracing association 1 (2) Tracing pin 26 to ADC 20 tracing via nid 26 tracing via nid 23 tracing via nid 20 nid 20 returned 1 tracing via nid 21 nid 21 returned 0 tracing via nid 22 nid 22 returned 0 nid 23 returned 1 tracing via nid 24 tracing via nid 20 nid 20 returned 1 tracing via nid 21 nid 21 returned 0 tracing via nid 22 nid 22 returned 0 nid 24 returned 1 nid 26 returned 1 Pin 26 traced to ADC 20 Association 1 (2) trace succeeded Tracing association 2 (3) Tracing pin 27 to ADC 21 tracing via nid 27 tracing via nid 23 nid 23 busy by association 1 tracing via nid 24 nid 24 busy by association 1 nid 27 returned 0 Unable to trace pin 27 to ADC 21, undo traces Tracing pin 27 to ADC 22 tracing via nid 27 tracing via nid 23 nid 23 busy by association 1 tracing via nid 24 nid 24 busy by association 1 nid 27 returned 0 Unable to trace pin 27 to ADC 22, undo traces Association 2 (3) trace failed Tracing association 3 (4) Tracing pin 25 with min nid 0 tracing via nid 25 tracing via nid 16 nid 16 busy by association 0 tracing via nid 17 nid 17 returned 17 nid 25 returned 17 Pin 25 traced to DAC 17 Association 3 (4) trace succeeded Tracing input monitor Tracing other input monitors Tracing nid 26 to out tracing via nid 26 tracing via nid 23 nid 23 busy by input association 1 tracing via nid 24 nid 24 busy by input association 1 nid 26 returned 0 Tracing beeper Tracing nid 19 to out tracing via nid 19 nid 19 returned 0 Disabling unassociated widgets... Disabling nonselected inputs... Disabling useless... Disabling nid 20 connection 3 due to disabled child widget. Disabling nid 23 connection 1 due to disabled child widget. Disabling nid 24 connection 1 due to disabled child widget. Disabling crossassociated connections... Disabling useless... Binding associations to channels... Assigning names to signal sources... Parsing Ctls... Assigning mixers to the tree... Preparing pin controls... AFG commit... Creating PCM devices... pcmAttach: HDA Conexant CX20585 PCM #0 Analog at cad 0 nid 1 +--------------------------------------+ | DUMPING PCM Playback/Record Channels | +--------------------------------------+ Playback: Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz DAC: 16 Record: Stream cap: 0x00000001 PCM PCM cap: 0x000e0160 16 20 24 bits, 44 48 96 KHz ADC: 20 +-------------------------------+ | DUMPING Playback/Record Paths | +-------------------------------+ Playback: nid=31 [pin: Speaker (Analog)] | + <- nid=16 [audio output] [src: pcm] bindSeq=00000001 Record: nid=20 [audio input] | + <- nid=23 [audio selector] [src: monitor] bindSeq=00000001 | + <- nid=26 [pin: Microphone (Analog)] [src: monitor] bindSeq=00000001 + <- nid=24 [audio selector] [src: monitor] bindSeq=00000001 | + <- nid=26 [pin: Microphone (Analog)] [src: monitor] bindSeq=00000001 +-------------------------+ | DUMPING Volume Controls | +-------------------------+ Master Volume (OSS: vol) | +- control 1 (nid 16 out): dir - out oss: vol, pcm -74/+0dB (75 steps) + mute PCM Volume (OSS: pcm) | +- control 1 (nid 16 out): dir - out oss: vol, pcm -74/+0dB (75 steps) + mute Microphone2 Volume (OSS: monitor) | +- control 5 (nid 23 out): dir - in oss: monitor +0/+40dB (5 steps) +- control 6 (nid 24 out): dir - in oss: rec, monitor +0/+40dB (5 steps) Speaker/Beep Volume (OSS: speaker) | +- control 3 (nid 19 out): dir - none oss: speaker -28/+0dB (8 steps) Recording Level (OSS: rec) | +- control 4 (nid 20 in 0): dir - in oss: rec -74/+6dB (81 steps) + mute +- control 6 (nid 24 out): dir - in oss: rec, monitor +0/+40dB (5 steps) OSS mixer initialization... Recsel (line, mic, cd, monitor): nid 23 source 0 select Recsel (line, mic, cd, monitor): nid 24 source 0 select Registering PCM channels... pcmAttach: HDA Conexant CX20585 PCM #1 Analog at cad 0 nid 1 +--------------------------------------+ | DUMPING PCM Playback/Record Channels | +--------------------------------------+ Playback: Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz DAC: 17 +-------------------------------+ | DUMPING Playback/Record Paths | +-------------------------------+ Playback: nid=25 [pin: Headphones (Black Right)] | + <- nid=17 [audio output] [src: pcm] bindSeq=00000001 +-------------------------+ | DUMPING Volume Controls | +-------------------------+ Master Volume (OSS: vol) | +- control 2 (nid 17 out): dir - out oss: vol, pcm -74/+0dB (75 steps) + mute PCM Volume (OSS: pcm) | +- control 2 (nid 17 out): dir - out oss: vol, pcm -74/+0dB (75 steps) + mute OSS mixer initialization... Registering PCM channels... FG config/quirks: forcestereo ivref50 ivref80 ivref100 ivref HP switch init... +-------------------+ | DUMPING HDA NODES | +-------------------+ Default Parameter ----------------- Stream cap: 0x00000001 PCM PCM cap: 0x000e0160 16 20 24 bits, 44 48 96 KHz IN amp: 0x00000000 OUT amp: 0x00000000 nid: 16 Name: audio output Widget cap: 0x00000c1d LRSWAP PWR STEREO Association: 0 (0x00000001) OSS: pcm (pcm) Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz Output amp: 0x80034a4a mute=1 step=74 size=3 offset=74 Output val: [0x38 0x38] nid: 17 Name: audio output Widget cap: 0x00000c1d LRSWAP PWR STEREO Association: 3 (0x00000001) OSS: pcm (pcm) Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz Output amp: 0x80034a4a mute=1 step=74 size=3 offset=74 Output val: [0x38 0x38] nid: 18 [DISABLED] Name: audio output Widget cap: 0x00000611 PWR DIGITAL STEREO Stream cap: 0x00000005 AC3 PCM PCM cap: 0x000e0160 16 20 24 bits, 44 48 96 KHz nid: 19 Name: beep widget Widget cap: 0x0070000c Association: -2 (0x00000000) OSS: speaker (speaker) Output amp: 0x000f0707 mute=0 step=7 size=15 offset=7 Output val: [0x06 0x00] nid: 20 Name: audio input Widget cap: 0x00100d1b LRSWAP PWR STEREO Association: 1 (0x00000001) Stream cap: 0x00000001 PCM PCM cap: 0x000e0160 16 20 24 bits, 44 48 96 KHz Input amp: 0x8003504a mute=1 step=80 size=3 offset=74 Input val: [0x3C 0x3C] [0x4A 0x4A] [0x4A 0x4A] [0x4A 0x4A] connections: 4 enabled 2 | + <- nid=23 [audio selector] (selected) + <- nid=24 [audio selector] + [DISABLED] <- nid=35 [pin: Line-out (None)] [DISABLED] + [DISABLED] <- nid=36 [audio mixer] [DISABLED] nid: 21 [DISABLED] Name: audio input Widget cap: 0x00100d1b LRSWAP PWR STEREO Stream cap: 0x00000001 PCM PCM cap: 0x000e0160 16 20 24 bits, 44 48 96 KHz Input amp: 0x8003504a mute=1 step=80 size=3 offset=74 Input val: [0x4A 0x4A] [0x4A 0x4A] [0x4A 0x4A] [0x4A 0x4A] connections: 4 enabled 3 | + <- nid=23 [audio selector] (selected) + <- nid=24 [audio selector] + [DISABLED] <- nid=35 [pin: Line-out (None)] [DISABLED] + <- nid=36 [audio mixer] [DISABLED] nid: 22 [DISABLED] Name: audio input Widget cap: 0x00100d1b LRSWAP PWR STEREO Stream cap: 0x00000001 PCM PCM cap: 0x000e0160 16 20 24 bits, 44 48 96 KHz Input amp: 0x8003504a mute=1 step=80 size=3 offset=74 Input val: [0x4A 0x4A] [0x4A 0x4A] [0x4A 0x4A] [0x4A 0x4A] connections: 4 enabled 3 | + <- nid=23 [audio selector] (selected) + <- nid=24 [audio selector] + [DISABLED] <- nid=35 [pin: Line-out (None)] [DISABLED] + <- nid=36 [audio mixer] [DISABLED] nid: 23 Name: audio selector Widget cap: 0x0030050d PWR STEREO Association: 1 (0x00000001) OSS: monitor Output amp: 0x00270400 mute=0 step=4 size=39 offset=0 Output val: [0x03 0x03] connections: 4 enabled 1 | + <- nid=26 [pin: Microphone (Analog)] (selected) + [DISABLED] <- nid=27 [pin: Microphone (Black Right)] [DISABLED] + [DISABLED] <- nid=29 [pin: Line-out (None)] [DISABLED] + [DISABLED] <- nid=30 [pin: Line-out (None)] [DISABLED] nid: 24 Name: audio selector Widget cap: 0x0030050d PWR STEREO Association: 1 (0x00000001) OSS: monitor Output amp: 0x00270400 mute=0 step=4 size=39 offset=0 Output val: [0x02 0x02] connections: 4 enabled 1 | + <- nid=26 [pin: Microphone (Analog)] (selected) + [DISABLED] <- nid=27 [pin: Microphone (Black Right)] [DISABLED] + [DISABLED] <- nid=29 [pin: Line-out (None)] [DISABLED] + [DISABLED] <- nid=30 [pin: Line-out (None)] [DISABLED] nid: 25 Name: pin: Headphones (Black Right) Widget cap: 0x00400581 PWR UNSOL STEREO Association: 3 (0x00000001) Pin cap: 0x0000001c PDC HP OUT Pin config: 0x04211040 Pin control: 0x000000c0 HP OUT connections: 2 enabled 1 | + [DISABLED] <- nid=16 [audio output] + <- nid=17 [audio output] (selected) nid: 26 Name: pin: Microphone (Analog) Widget cap: 0x00400481 PWR UNSOL STEREO Association: 1 (0x00000001) OSS: monitor (monitor) Pin cap: 0x00001324 PDC IN VREF[ 50 80 HIZ ] Pin config: 0x90a70120 Pin control: 0x00000024 IN VREFs nid: 27 [DISABLED] Name: pin: Microphone (Black Right) Widget cap: 0x00400581 PWR UNSOL STEREO Pin cap: 0x00011334 PDC OUT IN VREF[ 50 80 HIZ ] EAPD Pin config: 0x04a11030 Pin control: 0x00000000 EAPD: 0x00000002 connections: 2 enabled 2 | + <- nid=16 [audio output] (selected) + <- nid=17 [audio output] nid: 28 [DISABLED] Name: pin: Line-out (None) Widget cap: 0x00400581 PWR UNSOL STEREO Pin cap: 0x00000014 PDC OUT Pin config: 0x400001f0 Pin control: 0x00000000 connections: 2 enabled 2 | + <- nid=16 [audio output] (selected) + <- nid=17 [audio output] nid: 29 [DISABLED] Name: pin: Line-out (None) Widget cap: 0x00400581 PWR UNSOL STEREO Pin cap: 0x00010034 PDC OUT IN EAPD Pin config: 0x400001f0 Pin control: 0x00000000 EAPD: 0x00000002 connections: 2 enabled 2 | + <- nid=16 [audio output] (selected) + <- nid=17 [audio output] nid: 30 [DISABLED] Name: pin: Line-out (None) Widget cap: 0x00400481 PWR UNSOL STEREO Pin cap: 0x00000024 PDC IN Pin config: 0x400001f0 Pin control: 0x00000000 nid: 31 Name: pin: Speaker (Analog) Widget cap: 0x00400501 PWR STEREO Association: 0 (0x00000001) Pin cap: 0x00000010 OUT Pin config: 0x90170110 Pin control: 0x00000040 OUT connections: 2 enabled 1 | + <- nid=16 [audio output] (selected) + [DISABLED] <- nid=17 [audio output] nid: 32 [DISABLED] Name: pin: Line-out (None) Widget cap: 0x00400781 PWR DIGITAL UNSOL STEREO Pin cap: 0x00000010 OUT Pin config: 0x400001f0 Pin control: 0x00000000 connections: 1 enabled 1 | + <- nid=18 [audio output] [DISABLED] nid: 33 [DISABLED] Name: audio output Widget cap: 0x00000611 PWR DIGITAL STEREO Stream cap: 0x00000005 AC3 PCM PCM cap: 0x000e0160 16 20 24 bits, 44 48 96 KHz nid: 34 [DISABLED] Name: pin: Line-out (None) Widget cap: 0x00400781 PWR DIGITAL UNSOL STEREO Pin cap: 0x00000010 OUT Pin config: 0x400001f0 Pin control: 0x00000000 connections: 1 enabled 1 | + <- nid=33 [audio output] [DISABLED] nid: 35 [DISABLED] Name: pin: Line-out (None) Widget cap: 0x0040040b PWR STEREO Pin cap: 0x00000020 IN Pin config: 0x400001f0 Pin control: 0x00000000 Input amp: 0x002f0400 mute=0 step=4 size=47 offset=0 Input val: nid: 36 [DISABLED] Name: audio mixer Widget cap: 0x0020050b PWR STEREO Input amp: 0x80034a4a mute=1 step=74 size=3 offset=74 Input val: [0x80 0x80] [0x00 0x00] connections: 2 enabled 2 | + <- nid=16 [audio output] + <- nid=17 [audio output] nid: 37 [DISABLED] Name: vendor widget Widget cap: 0x00f00000 Probing codec #3... HDA Codec #3: Intel Cougar Point HDMI HDA Codec ID: 0x80862805 Vendor: 0x8086 Device: 0x2805 Revision: 0x00 Stepping: 0x00 PCI Subvendor: 0x20981b0a startNode=1 endNode=2 Found audio FG nid=1 startNode=2 endNode=9 total=7 Processing audio FG cad=3 nid=1... Powering up... Parsing audio FG... GPIO: 0x00000000 NumGPIO=0 NumGPO=0 NumGPI=0 GPIWake=0 GPIUnsol=0 nid 5 0x58560010 as 1 seq 0 Digital-out None Digital Special Internal Unknown misc 0 nid 6 0x58560020 as 2 seq 0 Digital-out None Digital Special Internal Unknown misc 0 nid 7 0x18560030 as 3 seq 0 Digital-out Jack Digital Special Internal Unknown misc 0 Parsing vendor patch... Nodes patching. Codec = 3 NumNodes = 0 VHDevice NID= 2 Config=00000000 (audio output ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID= 3 Config=00000000 (audio output ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID= 4 Config=00000000 (audio output ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID= 5 Config=58560010 (pin: Digital-o) Cap=09000094 Ctrl=00000040 -- Conns: 0=2 VHDevice NID= 6 Config=58560020 (pin: Digital-o) Cap=09000094 Ctrl=00000040 -- Conns: 0=3 VHDevice NID= 7 Config=18560030 (pin: Digital-o) Cap=09000094 Ctrl=00000040 -- Conns: 0=4 VHDevice NID= 8 Config=00000000 (vendor widget ) Cap=00000000 Ctrl=00000000 -- Conns: Disabling nonaudio... Disabling useless... Patched pins configuration: nid 5 0x58560010 as 1 seq 0 Digital-out None Digital Special Internal Unknown misc 0 [DISABLED] nid 6 0x58560020 as 2 seq 0 Digital-out None Digital Special Internal Unknown misc 0 [DISABLED] nid 7 0x18560030 as 3 seq 0 Digital-out Jack Digital Special Internal Unknown misc 0 Parsing pin associations... 1 associations found: Association 0 (3) out: Pin nid=7 seq=0 Redir type=-1 jack=0 def=0 Building AFG tree... Tracing association 0 (3) Tracing pin 7 with min nid 0 tracing via nid 7 tracing via nid 4 nid 4 returned 4 nid 7 returned 4 Pin 7 traced to DAC 4 Association 0 (3) trace succeeded Tracing input monitor Tracing other input monitors Tracing beeper Disabling unassociated widgets... Disabling nonselected inputs... Disabling useless... Disabling crossassociated connections... Disabling useless... Binding associations to channels... Assigning names to signal sources... Parsing Ctls... Assigning mixers to the tree... Preparing pin controls... AFG commit... Creating PCM devices... pcmAttach: HDA Intel Cougar Point HDMI PCM #0 DisplayPort at cad 3 nid 1 +--------------------------------------+ | DUMPING PCM Playback/Record Channels | +--------------------------------------+ Playback: Stream cap: 0x00000005 AC3 PCM PCM cap: 0x001e07f0 16 20 24 32 bits, 32 44 48 88 96 176 192 KHz DAC: 4 +-------------------------------+ | DUMPING Playback/Record Paths | +-------------------------------+ Playback: nid=7 [pin: Digital-out (HDMI)] | + <- nid=4 [audio output] [src: pcm] bindSeq=00000001 +-------------------------+ | DUMPING Volume Controls | +-------------------------+ Master Volume (OSS: vol) | +- control 1 (nid 7 out): dir - out oss: vol, pcm mute PCM Volume (OSS: pcm) | +- control 1 (nid 7 out): dir - out oss: vol, pcm mute OSS mixer initialization... Registering PCM channels... FG config/quirks: forcestereo ivref50 ivref80 ivref100 ivref HP switch init... +-------------------+ | DUMPING HDA NODES | +-------------------+ Default Parameter ----------------- IN amp: 0x00000000 OUT amp: 0x00000000 nid: 2 [DISABLED] Name: audio output Widget cap: 0x00006611 PWR DIGITAL 8CH Stream cap: 0x00000005 AC3 PCM PCM cap: 0x001e07f0 16 20 24 32 bits, 32 44 48 88 96 176 192 KHz nid: 3 [DISABLED] Name: audio output Widget cap: 0x00006611 PWR DIGITAL 8CH Stream cap: 0x00000005 AC3 PCM PCM cap: 0x001e07f0 16 20 24 32 bits, 32 44 48 88 96 176 192 KHz nid: 4 Name: audio output Widget cap: 0x00006611 PWR DIGITAL 8CH Association: 0 (0x00000001) OSS: pcm (pcm) Stream cap: 0x00000005 AC3 PCM PCM cap: 0x001e07f0 16 20 24 32 bits, 32 44 48 88 96 176 192 KHz nid: 5 [DISABLED] Name: pin: Digital-out (HDMI) Widget cap: 0x0040778d PWR DIGITAL UNSOL 8CH Pin cap: 0x09000094 PDC OUT HDMI DP HBR Pin config: 0x58560010 Pin control: 0x00000000 Output amp: 0x80000000 mute=1 step=0 size=0 offset=0 Output val: [0x00 0x80] connections: 1 enabled 1 | + <- nid=2 [audio output] [DISABLED] nid: 6 [DISABLED] Name: pin: Digital-out (HDMI) Widget cap: 0x0040778d PWR DIGITAL UNSOL 8CH Pin cap: 0x09000094 PDC OUT HDMI DP HBR Pin config: 0x58560020 Pin control: 0x00000000 Output amp: 0x80000000 mute=1 step=0 size=0 offset=0 Output val: [0x00 0x80] connections: 1 enabled 1 | + <- nid=3 [audio output] [DISABLED] nid: 7 Name: pin: Digital-out (HDMI) Widget cap: 0x0040778d PWR DIGITAL UNSOL 8CH Association: 0 (0x00000001) Pin cap: 0x09000094 PDC OUT HDMI DP HBR Pin config: 0x18560030 Pin control: 0x00000040 OUT Output amp: 0x80000000 mute=1 step=0 size=0 offset=0 Output val: [0x00 0x00] connections: 1 enabled 1 | + <- nid=4 [audio output] nid: 8 [DISABLED] Name: vendor widget Widget cap: 0x00f00000 I hope you guys can help me! Thanks in advance.
artur-pt Posted July 13, 2014 Posted July 13, 2014 hello have u try this one ? http://Olarila.com/files/10.9/Audio/AppleHDA_10.9.4/Laptop/AppleHDA-2.6.3f4-CX20585.zip see the readme file inside good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
sachka Posted July 13, 2014 Posted July 13, 2014 hello have u try this one ? http://Olarila.com/files/10.9/Audio/AppleHDA_10.9.4/Laptop/AppleHDA-2.6.3f4-CX20585.zip see the readme file inside good hack Yes, that kext won't work unless I edit my DSDT with layout3 (0x03) I edit DSDT to (0x03) and it works but NO HDMI NO MIC NO EXTERNAL MIC with VoodooHDA everything works but autoswitch is broken no detection of jacks and no hdmi controls
artur-pt Posted July 13, 2014 Posted July 13, 2014 hello what hdmi controls u want ? hdmi don't have any controls ... the autoswitch .. can be a problem .. is only that ur problems ? good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
sachka Posted July 13, 2014 Posted July 13, 2014 Well I cannot control volume, I actually don't know if it works, it's detected but no sound and no control. Detection is a problem yes :/ very annoying since it is a laptop and you know it's usually connected to external speakers or headphones
holyfield Posted November 14, 2014 Posted November 14, 2014 I'm confused, how do I get the conf for subwoofer? HDA Codec #0: IDT 92HD71B7 HDA Codec ID: 0x111d76b2 Vendor: 0x111d Device: 0x76b2 Revision: 0x03 Stepping: 0x02 PCI Subvendor: 0x30f4103c startNode=1 endNode=2 Found audio FG nid=1 startNode=10 endNode=41 total=31 Processing audio FG cad=0 nid=1... Powering up... Parsing audio FG... GPIO: 0xc0000008 NumGPIO=8 NumGPO=0 NumGPI=0 GPIWake=1 GPIUnsol=1 nid 10 0x0221401f as 1 seq 15 Headphones Jack 1/8 Front External Green misc 0 nid 11 0x02a19020 as 2 seq 0 Microphone Jack 1/8 Front External Pink misc 0 nid 12 0x40f100f0 as 15 seq 0 Other None 1/8 N/A External Unknown misc 0 nid 13 0x90171110 as 1 seq 0 Speaker Fixed Analog N/A Internal Black misc 0 NoPresenceDetect nid 14 0x40f100f2 as 15 seq 2 Other None 1/8 N/A External Unknown misc 0 nid 15 0x40f100f7 as 15 seq 7 Other None 1/8 N/A External Unknown misc 0 nid 20 0x40f100f3 as 15 seq 3 Other None 1/8 N/A External Unknown misc 0 nid 24 0x85a61150 as 5 seq 0 Microphone Fixed Digital Top External Black misc 0 NoPresenceDetect nid 25 0x40f100f4 as 15 seq 4 Other None 1/8 N/A External Unknown misc 0 nid 30 0x014411a0 as 10 seq 0 SPDIF-out Jack RCA Rear External Black misc 0 NoPresenceDetect nid 31 0x40f100f5 as 15 seq 5 Other None 1/8 N/A External Unknown misc 0 nid 32 0x40f100f6 as 15 seq 6 Other None 1/8 N/A External Unknown misc 0 nid 39 0x40f100f8 as 15 seq 8 Other None 1/8 N/A External Unknown misc 0 Parsing vendor patch... Nodes patching. Codec = 0 NumNodes = 0 VHDevice NID=10 Config=0221401f (pin: Headphone) Cap=0000001c Ctrl=00000000 -- Conns: 0=16 1=17 2=23 VHDevice NID=11 Config=02a19020 (pin: Microphon) Cap=00001724 Ctrl=00000000 -- Conns: VHDevice NID=12 Config=40f100f0 (pin: Other (No) Cap=00001724 Ctrl=00000000 -- Conns: VHDevice NID=13 Config=90171110 (pin: Speaker () Cap=00000014 Ctrl=00000000 -- Conns: 0=16 1=17 2=23 VHDevice NID=14 Config=40f100f2 (pin: Other (No) Cap=00001724 Ctrl=00000000 -- Conns: VHDevice NID=15 Config=40f100f7 (pin: Other (No) Cap=00000014 Ctrl=00000000 -- Conns: 0=16 1=17 2=23 VHDevice NID=16 Config=00000000 (audio output ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=17 Config=00000000 (audio output ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=18 Config=00000000 (audio input ) Cap=00000000 Ctrl=00000000 -- Conns: 0=28 VHDevice NID=19 Config=00000000 (audio input ) Cap=00000000 Ctrl=00000000 -- Conns: 0=29 VHDevice NID=20 Config=40f100f3 (pin: Other (No) Cap=00000010 Ctrl=00000000 -- Conns: 0=22 VHDevice NID=21 Config=00000000 (audio selector) Cap=00000000 Ctrl=00000000 -- Conns: 0=16 1=17 2=23 VHDevice NID=22 Config=00000000 (audio mixer ) Cap=00000000 Ctrl=00000000 -- Conns: 0=21 VHDevice NID=23 Config=00000000 (audio mixer ) Cap=00000000 Ctrl=00000000 -- Conns: 0=16 1=17 2=39 3=26 4=27 VHDevice NID=24 Config=85a61150 (pin: Microphon) Cap=00000020 Ctrl=00000000 -- Conns: VHDevice NID=25 Config=40f100f4 (pin: Other (No) Cap=00000020 Ctrl=00000000 -- Conns: VHDevice NID=26 Config=00000000 (audio selector) Cap=00000000 Ctrl=00000000 -- Conns: 0=11 1=12 2=14 VHDevice NID=27 Config=00000000 (audio selector) Cap=00000000 Ctrl=00000000 -- Conns: 0=11 1=12 2=14 VHDevice NID=28 Config=00000000 (audio selector) Cap=00000000 Ctrl=00000000 -- Conns: 0=26 1=23 2=24 3=25 VHDevice NID=29 Config=00000000 (audio selector) Cap=00000000 Ctrl=00000000 -- Conns: 0=27 1=23 2=24 3=25 VHDevice NID=30 Config=014411a0 (pin: SPDIF-out) Cap=00000010 Ctrl=00000000 -- Conns: 0=36 VHDevice NID=31 Config=40f100f5 (pin: Other (No) Cap=00010010 Ctrl=00000000 -- Conns: 0=36 1=37 VHDevice NID=32 Config=40f100f6 (pin: Other (No) Cap=00000010 Ctrl=00000000 -- Conns: 0=37 VHDevice NID=33 Config=00000000 (audio output ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=34 Config=00000000 (audio output ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=35 Config=00000000 (vendor widget ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=36 Config=00000000 (audio selector) Cap=00000000 Ctrl=00000000 -- Conns: 0=33 1=28 2=29 VHDevice NID=37 Config=00000000 (audio selector) Cap=00000000 Ctrl=00000000 -- Conns: 0=34 1=28 2=29 VHDevice NID=38 Config=00000000 (beep widget ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=39 Config=40f100f8 (pin: Other (No) Cap=00000020 Ctrl=00000000 -- Conns: VHDevice NID=40 Config=00000000 (volume widget ) Cap=00000000 Ctrl=00000000 -- Conns: 0=16 1=17
melkor Posted December 6, 2014 Posted December 6, 2014 Hi, mine is Acer 4738G with Yosemite installed. Everything else is fine except for the sound card. I can hear the sound only for a few seconds. If I changed some settings in Audio MIDI Setup, the sound would arise again, but just for a few seconds. I use VoodooHDA 2.8.7, and this laptop has two sound card: ALC272(8086:3b56) and ATI HDMI(1002:aa68). I've tried both in Info.plist, but nothing turned better. Could you give me some advice? Thanks in advance.
Loyd Posted January 22, 2015 Posted January 22, 2015 Hi guys, First off all thanks again for this topic ! I installed some weeks ago VoodooHDA 2.8.7 which is a big change compared to the old VoodooHDA that I used before! Thank you again for the good work! My first purpose of installing 2.8.7 version was to get the internal mic. I managed to activated it using the solution provided by pernacabeluda by adding this nid : <key>NodesToPatch</key> <array> <dict> <key>Codec</key> <integer>0</integer> <key>Config</key> <string>0x99a30950</string> <key>Node</key> <integer>25</integer> </dict> </array> The internal mic is now recognized, but I'm facing two problems not included in those listed in the first post: The first is that, when using skype for example with the internal mic, there is a constant background noise heard by the person with whom I speak. When using other communication software (Telephone by Alexey Kuznetsov), the person with whom I speak can't even understand me due to the very bad quality of the sound received when I use internal mic. The second one, related the first one may be, is that I don't have all the setting in the prefpane for the internal mic, like the input Gain and PCM for example (please see the image) So as I said before, may be the two problems are connected. So may be the fact that being able to activate all the required settings will allows me to get a correct sound from my internal mic. Could you please guide me on how to do that ? (may be by activating other nodes ?) Here are the specifics of my sound card: ALC663 info Codec: Realtek ALC663 Address: 0 Vendor Id: 0x10ec0663 Subsystem Id: 0x104315a7 Revision Id: 0x100002 and this is what I get with getdump: Found a device of class VoodooHDADevice: IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/HDAC@1B/VoodooHDADevice Probing codec #0... HDA Codec #0: Realtek ALC663 HDA Codec ID: 0x10ec0663 Vendor: 0x10ec Device: 0x0663 Revision: 0x00 Stepping: 0x01 PCI Subvendor: 0x14c31043 startNode=1 endNode=2 Found audio FG nid=1 startNode=2 endNode=36 total=34 Processing audio FG cad=0 nid=1... Powering up... Parsing audio FG... GPIO: 0x40000002 NumGPIO=2 NumGPO=0 NumGPI=0 GPIWake=0 GPIUnsol=1 nid 17 0x411111f0 as 15 seq 0 Speaker None 1/8 Rear External Black misc 0 NoPresenceDetect nid 18 0x411111f0 as 15 seq 0 Speaker None 1/8 Rear External Black misc 0 NoPresenceDetect nid 19 0x411111f0 as 15 seq 0 Speaker None 1/8 Rear External Black misc 0 NoPresenceDetect nid 20 0x99130110 as 1 seq 0 Speaker Fixed ATAPI Special Internal Unknown misc 0 NoPresenceDetect nid 21 0x0121401f as 1 seq 15 Headphones Jack 1/8 Rear External Green misc 0 nid 22 0x411111f0 as 15 seq 0 Speaker None 1/8 Rear External Black misc 0 NoPresenceDetect nid 23 0x411111f0 as 15 seq 0 Speaker None 1/8 Rear External Black misc 0 NoPresenceDetect nid 24 0x01a19840 as 4 seq 0 Microphone Jack 1/8 Rear External Pink misc 4 nid 25 0x99a3094f as 4 seq 15 Microphone Fixed ATAPI Special Internal Unknown misc 4 NoPresenceDetect nid 26 0x411111f0 as 15 seq 0 Speaker None 1/8 Rear External Black misc 0 NoPresenceDetect nid 27 0x411111f0 as 15 seq 0 Speaker None 1/8 Rear External Black misc 0 NoPresenceDetect Patching widget caps nid=29 0x00400400 -> 0x00700400 nid 30 0x99430130 as 3 seq 0 SPDIF-out Fixed ATAPI Special Internal Unknown misc 0 NoPresenceDetect nid 33 0x01211020 as 2 seq 0 Headphones Jack 1/8 Rear External Black misc 0 Parsing vendor patch... Nodes patching. Codec = 0 NumNodes = 1 VHDevice NID= 2 Config=00000000 (audio output ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID= 3 Config=00000000 (audio output ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID= 4 Config=00000000 (audio output ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID= 5 Config=00000000 (vendor widget ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID= 6 Config=00000000 (audio output ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID= 7 Config=00000000 (vendor widget ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID= 8 Config=00000000 (audio input ) Cap=00000000 Ctrl=00000000 -- Conns: 0=35 VHDevice NID= 9 Config=00000000 (audio input ) Cap=00000000 Ctrl=00000000 -- Conns: 0=34 VHDevice NID=10 Config=00000000 (vendor widget ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=11 Config=00000000 (audio mixer ) Cap=00000000 Ctrl=00000000 -- Conns: 0=24 1=25 2=26 3=27 4=29 5=20 6=21 7=22 VHDevice NID=12 Config=00000000 (audio mixer ) Cap=00000000 Ctrl=00000000 -- Conns: 0=2 1=11 VHDevice NID=13 Config=00000000 (audio mixer ) Cap=00000000 Ctrl=00000000 -- Conns: 0=3 1=11 VHDevice NID=14 Config=00000000 (audio mixer ) Cap=00000000 Ctrl=00000000 -- Conns: 0=4 1=11 VHDevice NID=15 Config=00000000 (audio mixer ) Cap=00000000 Ctrl=00000000 -- Conns: 0=2 1=11 VHDevice NID=16 Config=00000000 (audio output ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=17 Config=411111f0 (pin: Speaker () Cap=00000010 Ctrl=00000040 -- Conns: 0=16 VHDevice NID=18 Config=411111f0 (pin: Speaker () Cap=00000020 Ctrl=00000000 -- Conns: VHDevice NID=19 Config=411111f0 (pin: Speaker () Cap=00000020 Ctrl=00000000 -- Conns: VHDevice NID=20 Config=99130110 (pin: Speaker () Cap=0001003c Ctrl=00000020 -- Conns: 0=12 1=13 VHDevice NID=21 Config=0121401f (pin: Headphone) Cap=0001003c Ctrl=00000020 -- Conns: 0=12 1=13 VHDevice NID=22 Config=411111f0 (pin: Speaker () Cap=00000034 Ctrl=00000020 -- Conns: 0=14 VHDevice NID=23 Config=411111f0 (pin: Speaker () Cap=00000010 Ctrl=00000000 -- Conns: 0=15 VHDevice NID=24 Config=01a19840 (pin: Microphon) Cap=00001734 Ctrl=00000020 -- Conns: 0=14 VHDevice NID=25 Config=99a30950 (pin: Microphon) Cap=0000173c Ctrl=00000020 -- Conns: 0=12 1=13 2=14 VHDevice NID=26 Config=411111f0 (pin: Speaker () Cap=00001734 Ctrl=00000020 -- Conns: 0=13 VHDevice NID=27 Config=411111f0 (pin: Speaker () Cap=0000173c Ctrl=00000020 -- Conns: 0=12 1=13 2=14 VHDevice NID=28 Config=00000000 (vendor widget ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=29 Config=00000000 (beep widget ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=30 Config=99430130 (pin: SPDIF-out) Cap=00000014 Ctrl=00000040 -- Conns: 0=6 VHDevice NID=31 Config=00000000 (vendor widget ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=32 Config=00000000 (vendor widget ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=33 Config=01211020 (pin: Headphone) Cap=0000001c Ctrl=00000000 -- Conns: 0=12 1=13 2=14 VHDevice NID=34 Config=00000000 (audio mixer ) Cap=00000000 Ctrl=00000000 -- Conns: 0=24 1=25 2=26 3=27 4=29 5=20 6=21 7=22 8=11 9=18 VHDevice NID=35 Config=00000000 (audio mixer ) Cap=00000000 Ctrl=00000000 -- Conns: 0=24 1=25 2=26 3=27 4=29 5=20 6=21 7=22 8=11 9=19 Disabling nonaudio... Disabling useless... Disabling nid 11 connection 2 due to disabled child widget. Disabling nid 11 connection 3 due to disabled child widget. Disabling nid 11 connection 7 due to disabled child widget. Disabling nid 15 due to all it's consumers disabled. Disabling nid 34 connection 2 due to disabled child widget. Disabling nid 34 connection 3 due to disabled child widget. Disabling nid 34 connection 7 due to disabled child widget. Disabling nid 34 connection 9 due to disabled child widget. Disabling nid 35 connection 2 due to disabled child widget. Disabling nid 35 connection 3 due to disabled child widget. Disabling nid 35 connection 7 due to disabled child widget. Disabling nid 35 connection 9 due to disabled child widget. Patched pins configuration: nid 17 0x411111f0 as 15 seq 0 Speaker None 1/8 Rear External Black misc 0 NoPresenceDetect [DISABLED] nid 18 0x411111f0 as 15 seq 0 Speaker None 1/8 Rear External Black misc 0 NoPresenceDetect [DISABLED] nid 19 0x411111f0 as 15 seq 0 Speaker None 1/8 Rear External Black misc 0 NoPresenceDetect [DISABLED] nid 20 0x99130110 as 1 seq 0 Speaker Fixed ATAPI Special Internal Unknown misc 0 NoPresenceDetect nid 21 0x0121401f as 1 seq 15 Headphones Jack 1/8 Rear External Green misc 0 nid 22 0x411111f0 as 15 seq 0 Speaker None 1/8 Rear External Black misc 0 NoPresenceDetect [DISABLED] nid 23 0x411111f0 as 15 seq 0 Speaker None 1/8 Rear External Black misc 0 NoPresenceDetect [DISABLED] nid 24 0x01a19840 as 4 seq 0 Microphone Jack 1/8 Rear External Pink misc 4 nid 25 0x99a30950 as 5 seq 0 Microphone Fixed ATAPI Special Internal Unknown misc 4 NoPresenceDetect nid 26 0x411111f0 as 15 seq 0 Speaker None 1/8 Rear External Black misc 0 NoPresenceDetect [DISABLED] nid 27 0x411111f0 as 15 seq 0 Speaker None 1/8 Rear External Black misc 0 NoPresenceDetect [DISABLED] nid 30 0x99430130 as 3 seq 0 SPDIF-out Fixed ATAPI Special Internal Unknown misc 0 NoPresenceDetect nid 33 0x01211020 as 2 seq 0 Headphones Jack 1/8 Rear External Black misc 0 Parsing pin associations... 5 associations found: Association 0 (1) out: Pin nid=20 seq=0 Pin nid=21 seq=15 Redir type=0 jack=15 def=0 Association 1 (2) out: Pin nid=33 seq=0 Redir type=-1 jack=0 def=0 Association 2 (3) out: Pin nid=30 seq=0 Redir type=-1 jack=-1 def=0 Association 3 (4) in: Pin nid=24 seq=0 Redir type=-1 jack=0 def=0 Association 4 (5) in: Pin nid=25 seq=0 Redir type=-1 jack=-1 def=0 Building AFG tree... Tracing association 0 (1) Tracing pin 20 with min nid 0 nid 2 returned 2 nid 12 returned 2 nid 3 returned 3 nid 13 returned 3 nid 20 returned 2 Pin 20 traced to DAC 2 Tracing pin 21 with min nid 0 and hpredir 0 nid 2 returned 2 nid 12 returned 2 nid 21 returned 2 Pin 21 traced to DAC 2 and hpredir 0 Association 0 (1) trace succeeded Tracing association 1 (2) Tracing pin 33 with min nid 0 nid 12 busy by association 0 nid 3 returned 3 nid 20 busy by association 0 nid 21 busy by association 0 nid 13 returned 3 nid 4 returned 4 nid 20 busy by association 0 nid 21 busy by association 0 nid 14 returned 4 nid 33 returned 3 Pin 33 traced to DAC 3 Association 1 (2) trace succeeded Tracing association 2 (3) Tracing pin 30 with min nid 0 nid 6 returned 6 nid 30 returned 6 Pin 30 traced to DAC 6 Association 2 (3) trace succeeded Tracing association 3 (4) Tracing pin 24 to ADC 8 tracing via nid 24 tracing via nid 11 tracing via nid 12 nid 12 busy by association 0 tracing via nid 13 nid 13 busy by association 1 tracing via nid 14 tracing via nid 24 nid 24 returned 0 tracing via nid 25 nid 25 returned 0 tracing via nid 33 nid 33 busy by association 1 nid 14 returned 0 tracing via nid 34 tracing via nid 9 nid 9 returned 0 nid 34 returned 0 tracing via nid 35 tracing via nid 8 nid 8 returned 1 nid 35 returned 1 nid 11 returned 1 tracing via nid 34 tracing via nid 9 nid 9 returned 0 nid 34 returned 0 tracing via nid 35 tracing via nid 8 nid 8 returned 1 nid 35 returned 1 nid 24 returned 1 Pin 24 traced to ADC 8 Association 3 (4) trace succeeded Tracing association 4 (5) Tracing pin 25 to ADC 9 tracing via nid 25 tracing via nid 11 nid 11 busy by association 3 tracing via nid 34 tracing via nid 9 nid 9 returned 1 nid 34 returned 1 tracing via nid 35 nid 35 busy by association 3 nid 25 returned 1 Pin 25 traced to ADC 9 Association 4 (5) trace succeeded Tracing input monitor Tracing nid 11 to out tracing via nid 11 tracing via nid 12 nid 12 found output association 0 tracing via nid 13 nid 13 found output association 1 tracing via nid 14 tracing via nid 24 nid 24 busy by input association 3 tracing via nid 25 nid 25 busy by input association 4 tracing via nid 33 nid 33 found output association 1 nid 14 returned 1 tracing via nid 34 nid 34 busy by input association 4 tracing via nid 35 nid 35 busy by input association 3 nid 11 returned 1 nid 11 is input monitor Tracing nid 34 to out tracing via nid 34 tracing via nid 9 nid 9 busy by input association 4 nid 34 returned 0 Tracing nid 35 to out tracing via nid 35 tracing via nid 8 nid 8 busy by input association 3 nid 35 returned 0 Tracing other input monitors Tracing nid 24 to out tracing via nid 24 tracing via nid 11 nid 11 busy by input association 3 tracing via nid 34 nid 34 busy by input association 4 tracing via nid 35 nid 35 busy by input association 3 nid 24 returned 0 Tracing nid 25 to out tracing via nid 25 tracing via nid 11 nid 11 busy by input association 3 tracing via nid 34 nid 34 busy by input association 4 tracing via nid 35 nid 35 busy by input association 3 nid 25 returned 0 Tracing beeper Tracing nid 29 to out tracing via nid 29 tracing via nid 11 nid 11 busy by input association 3 tracing via nid 34 nid 34 busy by input association 4 tracing via nid 35 nid 35 busy by input association 3 nid 29 returned 0 Disabling unassociated widgets... Disabling nonselected inputs... Disabling useless... Disabling nid 14 connection 0 due to disabled child widget. Disabling nid 14 due to all it's consumers disabled. Disabling crossassociated connections... Disabling connection input mixer nid 34 conn 8 to monitor 11. Disabling connection input mixer nid 35 conn 8 to monitor 11. Disabling useless... Binding associations to channels... Assigning names to signal sources... Parsing Ctls... Ctl overflow! Assigning mixers to the tree... Preparing pin controls... AFG commit... Creating PCM devices... pcmAttach: HDA Realtek ALC663 PCM #0 Analog at cad 0 nid 1 +--------------------------------------+ | DUMPING PCM Playback/Record Channels | +--------------------------------------+ Playback: Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz DAC: 2 Record: Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz ADC: 8 +-------------------------------+ | DUMPING Playback/Record Paths | +-------------------------------+ Playback: nid=20 [pin: Speaker (ATAPI)] | + <- nid=12 [audio mixer] bindSeq=00008001 | + <- nid=2 [audio output] [src: pcm] bindSeq=00008001 + <- nid=11 [audio mixer] bindSeq=00000001 | + <- nid=24 [pin: Microphone (Pink Rear)] [src: mic] bindSeq=00000001 + <- nid=25 [pin: Microphone (ATAPI)] [src: monitor] bindSeq=00000001 + <- nid=29 [beep widget] nid=21 [pin: Headphones (Green Rear)] | + <- nid=12 [audio mixer] bindSeq=00008001 | + <- nid=2 [audio output] [src: pcm] bindSeq=00008001 + <- nid=11 [audio mixer] bindSeq=00000001 | + <- nid=24 [pin: Microphone (Pink Rear)] [src: mic] bindSeq=00000001 + <- nid=25 [pin: Microphone (ATAPI)] [src: monitor] bindSeq=00000001 + <- nid=29 [beep widget] Record: nid=8 [audio input] | + <- nid=35 [audio mixer] [src: mix] bindSeq=00000001 | + <- nid=24 [pin: Microphone (Pink Rear)] [src: mic] bindSeq=00000001 + <- nid=25 [pin: Microphone (ATAPI)] [src: monitor] bindSeq=00000001 + <- nid=29 [beep widget] Input Mix: nid=34 [audio mixer] | + <- nid=24 [pin: Microphone (Pink Rear)] [src: mic] bindSeq=00000001 + <- nid=25 [pin: Microphone (ATAPI)] [src: monitor] bindSeq=00000001 + <- nid=29 [beep widget] nid=35 [audio mixer] | + <- nid=24 [pin: Microphone (Pink Rear)] [src: mic] bindSeq=00000001 + <- nid=25 [pin: Microphone (ATAPI)] [src: monitor] bindSeq=00000001 + <- nid=29 [beep widget] +-------------------------+ | DUMPING Volume Controls | +-------------------------+ Master Volume (OSS: vol) | +- control 1 (nid 2 out): dir - out oss: vol, pcm -64/+0dB (65 steps) +- control 10 (nid 12 in 0): dir - out oss: vol, pcm mute +- control 11 (nid 12 in 1): dir - out oss: vol, igain mute +- control 14 (nid 20 out): dir - out oss: vol mute +- control 15 (nid 21 out): dir - out oss: vol mute PCM Volume (OSS: pcm) | +- control 1 (nid 2 out): dir - out oss: vol, pcm -64/+0dB (65 steps) +- control 10 (nid 12 in 0): dir - out oss: vol, pcm mute Microphone Volume (OSS: mic) | +- control 17 (nid 24 in 0): dir - in oss: mic +0/+30dB (4 steps) +- control 27 (nid 35 in 0): dir - in oss: mic, rec mute Microphone2 Volume (OSS: monitor) | +- control 28 (nid 35 in 1): dir - in oss: rec, monitor mute Speaker/Beep Volume (OSS: speaker) | +- control 7 (nid 11 in 4): dir - in oss: speaker, igain -34/+12dB (32 steps) + mute +- control 29 (nid 35 in 4): dir - in oss: speaker, rec mute Recording Level (OSS: rec) | +- control 3 (nid 8 in 0): dir - in oss: mix, rec -16/+30dB (32 steps) + mute +- control 27 (nid 35 in 0): dir - in oss: mic, rec mute +- control 28 (nid 35 in 1): dir - in oss: rec, monitor mute +- control 29 (nid 35 in 4): dir - in oss: speaker, rec mute Input Mix Level (OSS: mix) | +- control 3 (nid 8 in 0): dir - in oss: mix, rec -16/+30dB (32 steps) + mute Input Monitoring Level (OSS: igain) | +- control 5 (nid 11 in 0): dir - in oss: igain -34/+12dB (32 steps) + mute +- control 6 (nid 11 in 1): dir - in oss: igain -34/+12dB (32 steps) + mute +- control 7 (nid 11 in 4): dir - in oss: speaker, igain -34/+12dB (32 steps) + mute +- control 11 (nid 12 in 1): dir - out oss: vol, igain mute OSS mixer initialization... Registering PCM channels... pcmAttach: HDA Realtek ALC663 PCM #1 Analog at cad 0 nid 1 +--------------------------------------+ | DUMPING PCM Playback/Record Channels | +--------------------------------------+ Playback: Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz DAC: 3 Record: Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz ADC: 9 +-------------------------------+ | DUMPING Playback/Record Paths | +-------------------------------+ Playback: nid=33 [pin: Headphones (Black Rear)] | + <- nid=13 [audio mixer] bindSeq=00000001 | + <- nid=3 [audio output] [src: pcm] bindSeq=00000001 + <- nid=11 [audio mixer] bindSeq=00000001 | + <- nid=24 [pin: Microphone (Pink Rear)] [src: mic] bindSeq=00000001 + <- nid=25 [pin: Microphone (ATAPI)] [src: monitor] bindSeq=00000001 + <- nid=29 [beep widget] Record: nid=9 [audio input] | + <- nid=34 [audio mixer] [src: mix] bindSeq=00000001 | + <- nid=24 [pin: Microphone (Pink Rear)] [src: mic] bindSeq=00000001 + <- nid=25 [pin: Microphone (ATAPI)] [src: monitor] bindSeq=00000001 + <- nid=29 [beep widget] +-------------------------+ | DUMPING Volume Controls | +-------------------------+ Master Volume (OSS: vol) | +- control 2 (nid 3 out): dir - out oss: vol, pcm -64/+0dB (65 steps) +- control 12 (nid 13 in 0): dir - out oss: vol, pcm mute +- control 13 (nid 13 in 1): dir - out oss: vol, igain mute +- control 20 (nid 33 out): dir - out oss: vol mute PCM Volume (OSS: pcm) | +- control 2 (nid 3 out): dir - out oss: vol, pcm -64/+0dB (65 steps) +- control 12 (nid 13 in 0): dir - out oss: vol, pcm mute Microphone Volume (OSS: mic) | +- control 21 (nid 34 in 0): dir - in oss: mic, rec mute Microphone2 Volume (OSS: monitor) | +- control 19 (nid 25 in 0): dir - in oss: monitor +0/+30dB (4 steps) +- control 22 (nid 34 in 1): dir - in oss: rec, monitor mute Speaker/Beep Volume (OSS: speaker) | +- control 23 (nid 34 in 4): dir - in oss: speaker, rec mute Recording Level (OSS: rec) | +- control 4 (nid 9 in 0): dir - in oss: mix, rec -16/+30dB (32 steps) + mute +- control 21 (nid 34 in 0): dir - in oss: mic, rec mute +- control 22 (nid 34 in 1): dir - in oss: rec, monitor mute +- control 23 (nid 34 in 4): dir - in oss: speaker, rec mute Input Mix Level (OSS: mix) | +- control 4 (nid 9 in 0): dir - in oss: mix, rec -16/+30dB (32 steps) + mute Input Monitoring Level (OSS: igain) | +- control 13 (nid 13 in 1): dir - out oss: vol, igain mute OSS mixer initialization... Registering PCM channels... pcmAttach: HDA Realtek ALC663 PCM #2 Digital at cad 0 nid 1 +--------------------------------------+ | DUMPING PCM Playback/Record Channels | +--------------------------------------+ Playback: Stream cap: 0x00000005 AC3 PCM PCM cap: 0x000e05e0 16 20 24 bits, 44 48 88 96 192 KHz DAC: 6 +-------------------------------+ | DUMPING Playback/Record Paths | +-------------------------------+ Playback: nid=30 [pin: SPDIF-out (ATAPI)] | + <- nid=6 [audio output] [src: pcm] bindSeq=00000001 +-------------------------+ | DUMPING Volume Controls | +-------------------------+ OSS mixer initialization... Registering PCM channels... FG config/quirks: forcestereo ivref50 ivref80 ivref100 ivref HP switch init... +-------------------+ | DUMPING HDA NODES | +-------------------+ Default Parameter ----------------- Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz IN amp: 0x00000000 OUT amp: 0x00000000 nid: 2 Name: audio output Widget cap: 0x0000041d PWR STEREO Association: 0 (0x00008001) OSS: pcm (pcm) Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz Output amp: 0x00034040 mute=0 step=64 size=3 offset=64 Output val: [0x2E 0x2E] nid: 3 Name: audio output Widget cap: 0x0000041d PWR STEREO Association: 1 (0x00000001) OSS: pcm (pcm) Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz Output amp: 0x00034040 mute=0 step=64 size=3 offset=64 Output val: [0x2E 0x2E] nid: 4 [DISABLED] Name: audio output Widget cap: 0x0000041d PWR STEREO Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz Output amp: 0x00034040 mute=0 step=64 size=3 offset=64 Output val: [0x40 0x40] nid: 5 [DISABLED] Name: vendor widget Widget cap: 0x00f00000 nid: 6 Name: audio output Widget cap: 0x00000611 PWR DIGITAL STEREO Association: 2 (0x00000001) OSS: pcm (pcm) Stream cap: 0x00000001 PCM PCM cap: 0x000e05e0 16 20 24 bits, 44 48 88 96 192 KHz nid: 7 [DISABLED] Name: vendor widget Widget cap: 0x00f00000 nid: 8 Name: audio input Widget cap: 0x0010051b PWR STEREO Association: 3 (0x00000001) Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz Input amp: 0x80051f0b mute=1 step=31 size=5 offset=11 Input val: [0x80 0x80] connections: 1 enabled 1 | + <- nid=35 [audio mixer] nid: 9 Name: audio input Widget cap: 0x0010051b PWR STEREO Association: 4 (0x00000001) Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz Input amp: 0x80051f0b mute=1 step=31 size=5 offset=11 Input val: [0x80 0x80] connections: 1 enabled 1 | + <- nid=34 [audio mixer] nid: 10 [DISABLED] Name: vendor widget Widget cap: 0x00f00000 nid: 11 Name: audio mixer Widget cap: 0x0020010b STEREO Association: 3 (0x00000001) OSS: (igain) Input amp: 0x80051f17 mute=1 step=31 size=5 offset=23 Input val: [0x03 0x03] [0x03 0x03] [0x97 0x97] [0x97 0x97] [0x03 0x03] [0x17 0x17] [0x17 0x17] [0x97 0x97] connections: 8 enabled 3 | + <- nid=24 [pin: Microphone (Pink Rear)] + <- nid=25 [pin: Microphone (ATAPI)] + [DISABLED] <- nid=26 [pin: Speaker (None)] [DISABLED] + [DISABLED] <- nid=27 [pin: Speaker (None)] [DISABLED] + <- nid=29 [beep widget] + [DISABLED] <- nid=20 [pin: Speaker (ATAPI)] + [DISABLED] <- nid=21 [pin: Headphones (Green Rear)] + [DISABLED] <- nid=22 [pin: Speaker (None)] [DISABLED] nid: 12 Name: audio mixer Widget cap: 0x0020010b STEREO Association: 0 (0x00008001) OSS: (igain) Input amp: 0x80000000 mute=1 step=0 size=0 offset=0 Input val: [0x00 0x00] [0x00 0x00] connections: 2 enabled 2 | + <- nid=2 [audio output] + <- nid=11 [audio mixer] nid: 13 Name: audio mixer Widget cap: 0x0020010b STEREO Association: 1 (0x00000001) OSS: (igain) Input amp: 0x80000000 mute=1 step=0 size=0 offset=0 Input val: [0x00 0x00] [0x00 0x00] connections: 2 enabled 2 | + <- nid=3 [audio output] + <- nid=11 [audio mixer] nid: 14 [DISABLED] Name: audio mixer Widget cap: 0x0020010b STEREO Association: -2 (0x00000000) Input amp: 0x80000000 mute=1 step=0 size=0 offset=0 Input val: [0x00 0x00] [0x80 0x80] connections: 2 enabled 1 | + [DISABLED] <- nid=4 [audio output] [DISABLED] + <- nid=11 [audio mixer] nid: 15 [DISABLED] Name: audio mixer Widget cap: 0x0020010a Input amp: 0x80000000 mute=1 step=0 size=0 offset=0 Input val: [0x00 0x00] [0x80 0x80] connections: 2 enabled 2 | + <- nid=2 [audio output] + <- nid=11 [audio mixer] nid: 16 [DISABLED] Name: audio output Widget cap: 0x00000611 PWR DIGITAL STEREO Stream cap: 0x00000001 PCM PCM cap: 0x000e05e0 16 20 24 bits, 44 48 88 96 192 KHz nid: 17 [DISABLED] Name: pin: Speaker (None) Widget cap: 0x00400700 PWR DIGITAL Pin cap: 0x00000010 OUT Pin config: 0x411111f0 Pin control: 0x00000000 connections: 1 enabled 1 | + <- nid=16 [audio output] [DISABLED] nid: 18 [DISABLED] Name: pin: Speaker (None) Widget cap: 0x00400401 PWR STEREO Pin cap: 0x00000020 IN Pin config: 0x411111f0 Pin control: 0x00000000 nid: 19 [DISABLED] Name: pin: Speaker (None) Widget cap: 0x00400401 PWR STEREO Pin cap: 0x00000020 IN Pin config: 0x411111f0 Pin control: 0x00000000 nid: 20 Name: pin: Speaker (ATAPI) Widget cap: 0x0040058d PWR UNSOL STEREO Association: 0 (0x00000001) Pin cap: 0x0001003c PDC HP OUT IN EAPD Pin config: 0x99130110 Pin control: 0x00000040 OUT EAPD: 0x00000002 Output amp: 0x80000000 mute=1 step=0 size=0 offset=0 Output val: [0x00 0x00] connections: 2 enabled 1 | + <- nid=12 [audio mixer] (selected) + [DISABLED] <- nid=13 [audio mixer] nid: 21 Name: pin: Headphones (Green Rear) Widget cap: 0x0040058d PWR UNSOL STEREO Association: 0 (0x00008000) Pin cap: 0x0001003c PDC HP OUT IN EAPD Pin config: 0x0121401f Pin control: 0x000000c0 HP OUT EAPD: 0x00000002 Output amp: 0x80000000 mute=1 step=0 size=0 offset=0 Output val: [0x00 0x00] connections: 2 enabled 1 | + <- nid=12 [audio mixer] (selected) + [DISABLED] <- nid=13 [audio mixer] nid: 22 [DISABLED] Name: pin: Speaker (None) Widget cap: 0x0040058d PWR UNSOL STEREO Pin cap: 0x00000034 PDC OUT IN Pin config: 0x411111f0 Pin control: 0x00000000 Output amp: 0x80000000 mute=1 step=0 size=0 offset=0 Output val: [0x80 0x80] connections: 1 enabled 1 | + <- nid=14 [audio mixer] [DISABLED] nid: 23 [DISABLED] Name: pin: Speaker (None) Widget cap: 0x0040050c PWR Pin cap: 0x00000010 OUT Pin config: 0x411111f0 Pin control: 0x00000000 Output amp: 0x80000000 mute=1 step=0 size=0 offset=0 Output val: [0x80 0x80] connections: 1 enabled 1 | + <- nid=15 [audio mixer] [DISABLED] nid: 24 Name: pin: Microphone (Pink Rear) Widget cap: 0x0040058f PWR UNSOL STEREO Association: 3 (0x00000001) OSS: mic (mic) Pin cap: 0x00001734 PDC OUT IN VREF[ 50 80 GROUND HIZ ] Pin config: 0x01a19840 Pin control: 0x00000024 IN VREFs Output amp: 0x80000000 mute=1 step=0 size=0 offset=0 Output val: [0x00 0x00] Input amp: 0x00270300 mute=0 step=3 size=39 offset=0 Input val: [0x00 0x00] connections: 1 enabled 0 | + [DISABLED] <- nid=14 [audio mixer] [DISABLED] nid: 25 Name: pin: Microphone (ATAPI) Widget cap: 0x0040058f PWR UNSOL STEREO Association: 4 (0x00000001) OSS: monitor (monitor) Pin cap: 0x0000173c PDC HP OUT IN VREF[ 50 80 GROUND HIZ ] Pin config: 0x99a30950 Pin control: 0x00000024 IN VREFs Output amp: 0x80000000 mute=1 step=0 size=0 offset=0 Output val: [0x00 0x00] Input amp: 0x00270300 mute=0 step=3 size=39 offset=0 Input val: [0x02 0x02] [0x00 0x00] [0x00 0x00] connections: 3 enabled 0 | + [DISABLED] <- nid=12 [audio mixer] (selected) + [DISABLED] <- nid=13 [audio mixer] + [DISABLED] <- nid=14 [audio mixer] [DISABLED] nid: 26 [DISABLED] Name: pin: Speaker (None) Widget cap: 0x0040058f PWR UNSOL STEREO Pin cap: 0x00001734 PDC OUT IN VREF[ 50 80 GROUND HIZ ] Pin config: 0x411111f0 Pin control: 0x00000000 Output amp: 0x80000000 mute=1 step=0 size=0 offset=0 Output val: [0x80 0x80] Input amp: 0x00270300 mute=0 step=3 size=39 offset=0 Input val: [0x00 0x00] connections: 1 enabled 1 | + <- nid=13 [audio mixer] nid: 27 [DISABLED] Name: pin: Speaker (None) Widget cap: 0x0040058f PWR UNSOL STEREO Pin cap: 0x0000173c PDC HP OUT IN VREF[ 50 80 GROUND HIZ ] Pin config: 0x411111f0 Pin control: 0x00000000 Output amp: 0x80000000 mute=1 step=0 size=0 offset=0 Output val: [0x80 0x80] Input amp: 0x00270300 mute=0 step=3 size=39 offset=0 Input val: [0x00 0x00] [0x00 0x00] [0x00 0x00] connections: 3 enabled 3 | + <- nid=12 [audio mixer] (selected) + <- nid=13 [audio mixer] + <- nid=14 [audio mixer] [DISABLED] nid: 28 [DISABLED] Name: vendor widget Widget cap: 0x00f00000 nid: 29 Name: beep widget Widget cap: 0x00700400 PWR Association: -2 (0x00000000) OSS: speaker (speaker) nid: 30 Name: pin: SPDIF-out (ATAPI) Widget cap: 0x00400780 PWR DIGITAL UNSOL Association: 2 (0x00000001) Pin cap: 0x00000014 PDC OUT Pin config: 0x99430130 Pin control: 0x00000040 OUT connections: 1 enabled 1 | + <- nid=6 [audio output] nid: 31 [DISABLED] Name: vendor widget Widget cap: 0x00f00000 nid: 32 [DISABLED] Name: vendor widget Widget cap: 0x00f00040 PROC nid: 33 Name: pin: Headphones (Black Rear) Widget cap: 0x0040058d PWR UNSOL STEREO Association: 1 (0x00000001) Pin cap: 0x0000001c PDC HP OUT Pin config: 0x01211020 Pin control: 0x000000c0 HP OUT Output amp: 0x80000000 mute=1 step=0 size=0 offset=0 Output val: [0x00 0x00] connections: 3 enabled 1 | + [DISABLED] <- nid=12 [audio mixer] + <- nid=13 [audio mixer] (selected) + [DISABLED] <- nid=14 [audio mixer] [DISABLED] nid: 34 Name: audio mixer Widget cap: 0x0020010b STEREO Association: 4 (0x00000001) OSS: mix (mix) Input amp: 0x80000000 mute=1 step=0 size=0 offset=0 Input val: [0x00 0x00] [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x00 0x00] [0x00 0x00] [0x00 0x00] [0x80 0x80] [0x00 0x00] [0x80 0x80] connections: 10 enabled 3 | + <- nid=24 [pin: Microphone (Pink Rear)] + <- nid=25 [pin: Microphone (ATAPI)] + [DISABLED] <- nid=26 [pin: Speaker (None)] [DISABLED] + [DISABLED] <- nid=27 [pin: Speaker (None)] [DISABLED] + <- nid=29 [beep widget] + [DISABLED] <- nid=20 [pin: Speaker (ATAPI)] + [DISABLED] <- nid=21 [pin: Headphones (Green Rear)] + [DISABLED] <- nid=22 [pin: Speaker (None)] [DISABLED] + [DISABLED] <- nid=11 [audio mixer] + [DISABLED] <- nid=18 [pin: Speaker (None)] [DISABLED] nid: 35 Name: audio mixer Widget cap: 0x0020010b STEREO Association: 3 (0x00000001) OSS: mix (mix) Input amp: 0x80000000 mute=1 step=0 size=0 offset=0 Input val: [0x00 0x00] [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x00 0x00] [0x00 0x00] [0x00 0x00] [0x80 0x80] [0x00 0x00] [0x80 0x80] connections: 10 enabled 3 | + <- nid=24 [pin: Microphone (Pink Rear)] + <- nid=25 [pin: Microphone (ATAPI)] + [DISABLED] <- nid=26 [pin: Speaker (None)] [DISABLED] + [DISABLED] <- nid=27 [pin: Speaker (None)] [DISABLED] + <- nid=29 [beep widget] + [DISABLED] <- nid=20 [pin: Speaker (ATAPI)] + [DISABLED] <- nid=21 [pin: Headphones (Green Rear)] + [DISABLED] <- nid=22 [pin: Speaker (None)] [DISABLED] + [DISABLED] <- nid=11 [audio mixer] + [DISABLED] <- nid=19 [pin: Speaker (None)] [DISABLED] Probing codec #1... HDA Codec #1: Lucent/Agere Systems (Unknown) HDA Codec ID: 0x11c11040 Vendor: 0x11c1 Device: 0x1040 Revision: 0x02 Stepping: 0x00 PCI Subvendor: 0x14c31043 startNode=1 endNode=2 Found modem FG nid=1 startNode=2 endNode=127 total=125 Processing modem FG cad=1 nid=1... Powering down... Probing codec #2... HDA Codec #2: NVidia MCP78 HDMI HDA Codec ID: 0x10de0006 Vendor: 0x10de Device: 0x0006 Revision: 0x00 Stepping: 0x00 PCI Subvendor: 0x14c31043 startNode=1 endNode=2 Found audio FG nid=1 startNode=4 endNode=14 total=10 Processing audio FG cad=2 nid=1... Powering up... Parsing audio FG... GPIO: 0x00000000 NumGPIO=0 NumGPO=0 NumGPI=0 GPIWake=0 GPIUnsol=0 nid 5 0x18560110 as 1 seq 0 Digital-out Jack Digital Special Internal Unknown misc 0 NoPresenceDetect nid 7 0x58560121 as 2 seq 1 Digital-out None Digital Special Internal Unknown misc 0 NoPresenceDetect nid 9 0x58560122 as 2 seq 2 Digital-out None Digital Special Internal Unknown misc 0 NoPresenceDetect nid 11 0x58560123 as 2 seq 3 Digital-out None Digital Special Internal Unknown misc 0 NoPresenceDetect nid 13 0x58560124 as 2 seq 4 Digital-out None Digital Special Internal Unknown misc 0 NoPresenceDetect Parsing vendor patch... Nodes patching. Codec = 2 NumNodes = 1 VHDevice NID= 4 Config=00000000 (audio output ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID= 5 Config=18560110 (pin: Digital-o) Cap=00000014 Ctrl=00000000 -- Conns: 0=4 VHDevice NID= 6 Config=00000000 (audio output ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID= 7 Config=58560121 (pin: Digital-o) Cap=00000014 Ctrl=00000000 -- Conns: 0=6 VHDevice NID= 8 Config=00000000 (audio output ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID= 9 Config=58560122 (pin: Digital-o) Cap=00000014 Ctrl=00000000 -- Conns: 0=8 VHDevice NID=10 Config=00000000 (audio output ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=11 Config=58560123 (pin: Digital-o) Cap=00000014 Ctrl=00000000 -- Conns: 0=10 VHDevice NID=12 Config=00000000 (audio output ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=13 Config=58560124 (pin: Digital-o) Cap=00000014 Ctrl=00000000 -- Conns: 0=12 Disabling nonaudio... Disabling useless... Patched pins configuration: nid 5 0x18560110 as 1 seq 0 Digital-out Jack Digital Special Internal Unknown misc 0 NoPresenceDetect nid 7 0x58560121 as 2 seq 1 Digital-out None Digital Special Internal Unknown misc 0 NoPresenceDetect [DISABLED] nid 9 0x58560122 as 2 seq 2 Digital-out None Digital Special Internal Unknown misc 0 NoPresenceDetect [DISABLED] nid 11 0x58560123 as 2 seq 3 Digital-out None Digital Special Internal Unknown misc 0 NoPresenceDetect [DISABLED] nid 13 0x58560124 as 2 seq 4 Digital-out None Digital Special Internal Unknown misc 0 NoPresenceDetect [DISABLED] Parsing pin associations... 1 associations found: Association 0 (1) out: Pin nid=5 seq=0 Redir type=-1 jack=-1 def=0 Building AFG tree... Tracing association 0 (1) Tracing pin 5 with min nid 0 nid 4 returned 4 nid 5 returned 4 Pin 5 traced to DAC 4 Association 0 (1) trace succeeded Tracing input monitor Tracing other input monitors Tracing beeper Disabling unassociated widgets... Disabling nonselected inputs... Disabling useless... Disabling crossassociated connections... Disabling useless... Binding associations to channels... Assigning names to signal sources... Parsing Ctls... Assigning mixers to the tree... Preparing pin controls... AFG commit... Creating PCM devices... pcmAttach: HDA NVidia MCP78 HDMI PCM #0 Digital at cad 2 nid 1 +--------------------------------------+ | DUMPING PCM Playback/Record Channels | +--------------------------------------+ Playback: Stream cap: 0x00000005 AC3 PCM PCM cap: 0x000f00c0 8 16 20 24 bits, 48 88 KHz DAC: 4 +-------------------------------+ | DUMPING Playback/Record Paths | +-------------------------------+ Playback: nid=5 [pin: Digital-out (HDMI)] | + <- nid=4 [audio output] [src: pcm] bindSeq=00000001 +-------------------------+ | DUMPING Volume Controls | +-------------------------+ OSS mixer initialization... Registering PCM channels... FG config/quirks: forcestereo ivref50 ivref80 ivref100 ivref HP switch init... +-------------------+ | DUMPING HDA NODES | +-------------------+ Default Parameter ----------------- IN amp: 0x00000000 OUT amp: 0x00000000 nid: 4 Name: audio output Widget cap: 0x00000211 DIGITAL STEREO Association: 0 (0x00000001) OSS: pcm (pcm) Stream cap: 0x00000001 PCM PCM cap: 0x000f00c0 8 16 20 24 bits, 48 88 KHz nid: 5 Name: pin: Digital-out (HDMI) Widget cap: 0x00400381 DIGITAL UNSOL STEREO Association: 0 (0x00000001) Pin cap: 0x00000014 PDC OUT Pin config: 0x18560110 Pin control: 0x00000040 OUT connections: 1 enabled 1 | + <- nid=4 [audio output] nid: 6 [DISABLED] Name: audio output Widget cap: 0x00000211 DIGITAL STEREO Stream cap: 0x00000001 PCM PCM cap: 0x000f00c0 8 16 20 24 bits, 48 88 KHz nid: 7 [DISABLED] Name: pin: Digital-out (HDMI) Widget cap: 0x00400381 DIGITAL UNSOL STEREO Pin cap: 0x00000014 PDC OUT Pin config: 0x58560121 Pin control: 0x00000000 connections: 1 enabled 1 | + <- nid=6 [audio output] [DISABLED] nid: 8 [DISABLED] Name: audio output Widget cap: 0x00000211 DIGITAL STEREO Stream cap: 0x00000001 PCM PCM cap: 0x000f00c0 8 16 20 24 bits, 48 88 KHz nid: 9 [DISABLED] Name: pin: Digital-out (HDMI) Widget cap: 0x00400381 DIGITAL UNSOL STEREO Pin cap: 0x00000014 PDC OUT Pin config: 0x58560122 Pin control: 0x00000000 connections: 1 enabled 1 | + <- nid=8 [audio output] [DISABLED] nid: 10 [DISABLED] Name: audio output Widget cap: 0x00000211 DIGITAL STEREO Stream cap: 0x00000001 PCM PCM cap: 0x000f00c0 8 16 20 24 bits, 48 88 KHz nid: 11 [DISABLED] Name: pin: Digital-out (HDMI) Widget cap: 0x00400381 DIGITAL UNSOL STEREO Pin cap: 0x00000014 PDC OUT Pin config: 0x58560123 Pin control: 0x00000000 connections: 1 enabled 1 | + <- nid=10 [audio output] [DISABLED] nid: 12 [DISABLED] Name: audio output Widget cap: 0x00000211 DIGITAL STEREO Stream cap: 0x00000001 PCM PCM cap: 0x000f00c0 8 16 20 24 bits, 48 88 KHz nid: 13 [DISABLED] Name: pin: Digital-out (HDMI) Widget cap: 0x00400381 DIGITAL UNSOL STEREO Pin cap: 0x00000014 PDC OUT Pin config: 0x58560124 Pin control: 0x00000000 connections: 1 enabled 1 | + <- nid=12 [audio output] [DISABLED] Please find also my VoodooHDA plist attached : Info.plist.zip Great thanks in advance for any help on these two points Thank you all for your time ! Wonderful forum !!
blink.shadow Posted January 26, 2015 Posted January 26, 2015 Hi all, I've got an HP Sleekbook 15-el045b. It has an Intel HD 4000 GPU, an Intel HM77 motherboard and an IDT 92HD99BXX audio card. I've successfully installed VoodooHDA which is working nice, except for the HDMI Audio. The HDMI Audio output is correctly detected, but nothing plays on the TV. Attached there are my dumps. Codec#0: http://pastebin.com/A7BBD81r Codec#3: http://pastebin.com/7b4M4p0x
insanelydeepak Posted February 26, 2015 Posted February 26, 2015 Thanks for nice guide how to disable HDMI in voodooHDA , just need to use onboard audio ,its having so many option in pref pane .. also how to disable noise from speakers when no songs is played Thanks you very much
katsyonak Posted September 29, 2015 Posted September 29, 2015 Thanks to everyone that shares their knowledge here I've managed to patch VoodooHDA 2.8.8 and get all the input & output sound controls showing and working on AD2000B (Yosemite 10.10). Thanks!
edubz Posted January 3, 2016 Posted January 3, 2016 I am using voodoo kext but the sound is very tin can in my ear phones If in audio midi I turn 1 of the sliders down I can here better through the headphones but then if i take it out it comes out mono out of my laptop.... also if I have the headphones plugged in I can hear audio leak out of the laptop this also happened on windows until I installed the correct drivers from the acer site... once I get audio working i will have a fully working hackingtosh I downloaded an app called system info and it says I have 2 audio deviced ven ID 8086 Intel Corporation HASWELL AUDIO CONTROLER DEVID 8c20 Multimedia controler Audiodevice ven ID 8086 Intel Corporation Lynx Point HD AUDIO CONTROLER DEVID 0c0c Multimedia controler Audiodevice im I using the correct voodoo or should I use something since im getting sound out of my headphones and speakers maybe its just a small tweak in the settings I need to do
longcoming Posted October 15, 2019 Posted October 15, 2019 Have installed voodooHda. Modified info.plist Problem is when ı play video files,for example on vlc;audio goes off and comes back every three seconds. The second problem ı can't get audio from some videos on youtube. On windows,no problem. Thats why ı wanted native audio,but couldn't make it work.
