We'll pass the info system
Under SoundCard
			<key>IOPCIPrimaryMatch</key>
		<string>0x3a3e8086</string>
Under HDMI
		<string>0x0be510de</string>
Help me,i have usually kernel panic on boot with the last 2.7.3 installer
Have you tried both KP solutions in first post?
I think MixerValues and other options in the existing part should be used for SoundCard. New section should be added for HDMI.
It does not matter, Realtek 269 is the audio codec, you need to specify only the Intel audio ID (PCI device) in the plist.
Use -v (boot verbose) and check where it stops.
Got an interesting one...on my system (an Acer 1420p laptop) if I install the 2.7.3 voodoohda on the Lion developer preview (11a390), then sounds works just fine with no modification of the info.plist (despite the fact that it appears to be referencing the Intel HDMI sound and not the actual soundcard). If I install the release version of Lion, and install the 2.7.3 voodoohda, then I get kernel panics, boot hangs, etc...if I modify info.plist to point to either the main soundcard or both HDMI + soundcard, it will boot fine, but sound still does not work. Same behavior with 2.7.2
Any ideas?
Have you tried with only the soundcard PCI ID in the plist?
Need some help experience a weird problem.
I have a Clevo M570tu with alc662 using voodoohda 2.7.3
Quick rundown
I installed voodoo hda got a kernel panic removed followed instructions from first page added my device and vendor id reinstalled, system booted but no sound.
Read more realized I have HDMI audio also followed example from second post added another device id for my graphics card hdmi out and reinstalled.
Now when I boot i get no kernel panics but when the system boots I can hear my mic and speakers working but lose my video(screen doesn't work)
any one have any idea whats going on or how to fix?
Maybe you used the wrong device ID for HDMI? (video instead of audio)
(Sorry for my English)
I have modified version of VoodooHDA for VIA VT1708S and I tried to edit for HDMI audio. My graphics is Nvidia gts 450 (GF106). There are IDs for GF106 audio: Device ID = 0be9, Ver ID:10de, so thats 0x0be910de. But I think I have made some mistake in a code: VoodooHDA 2.7.3 editada para Via VT1708S .kext.zip
Probably there:
<key>HDMI</key>
	<dict>
		<key>CFBundleIdentifier</key>
		<key>IOClass</key>
		<key>IOMatchCategory</key>
		<string>0x0be910de</string>
		<key>IOProviderClass</key>
		<string>IOPCIDevice</string>
		<key>IOUserClientClass</key>
		<key>VoodooHDACodecHints</key>
		<dict>
			<key>1</key>
			<dict>
				<key>21</key>
				<dict>
					<key>AssocNum</key>
					<integer>1</integer>
					<key>SeqNum</key>
				</dict>
				<key>22</key>
				<dict>
					<key>DevType</key>
					<string>CD</string>
				</dict>
				<key>25</key>
				<dict>
					<key>AssocNum</key>
					<key>DevType</key>
					<string>Line-out</string>
					<key>SeqNum</key>
					<integer>2</integer>
				</dict>
			</dict>
		</dict>
		<key>VoodooHDAHints</key>
		<dict>
			<key>ivref</key>
			<true/>
		</dict>
		<integer>0</integer>
	</dict>
I edited it by this way: http://www.insanelymac.com/forum/index.php?showtopic=260896
Please help!
ok noob question
to do this ' edit Info.plist, replace the key IOPCIClassMatch by IOPCIPrimaryMatch and put the PCI ID of your audio card in string.'
where to find the Info.plist ?
thanks
Hi Oldnapalm,
thanks for the detailed solutions to some of the VoodooHDA problems, this help me much in fine tuning my kext.
Up and until I was using 10.7.3 everything was fine, sound crystal clear but since I have upgraded to 10.7.4 the sound is very distorted. Not sure why but is the same kext I used before.
If anyone knows a solution happy to test.
hey, i have a Intelbras notebook
The config is :
Intel Pentium Dual Core T3200 2.00Ghz
2 Gb Ram
SSD Intel 40gb
Webcam 1.3mp
Card reader
here is the system info
PQAAAGAUqLrChRYtERvQaw8GRkTyWFmE6vpysk1MhZHzkOFF5SgI3AKS6-vG6TJ-1ksHn6dwrgprA4ZqotmeH4B129AAm1T1UHOp1JwYseJwoIPq8zQ1Ym3Daen8.jpg
it don't work the audio, and the wifi, there is any kext to use? when i was using the leopard iPc 10.5.8, the audio was working with the voodoohda 0.2.1 beta, but now it doesn't work anymore ( I'm using the iAtkos 10.7.2 ), when i installed the 2.7.3, its was getting a kernel panic, so, there is a way to make everything working in this config?
tks!
Intel Core i5 3210m 2.5Ghz | 8GB DDR3 1600Mz | Radeon HD 7650m 1Gb DDR3 + Intel HD 4000 | iPhone 4 32Gb | Windows server 1TB | Japanese Gamecube | Nintendo64 | Nintendo DS Phat | Game Boy Advance | Game Boy Color | Global Village Telecom 35Mb
Hello, i'm having problem with Voodoo (I've tried everything on my p67 sabertooth board to get ALC892 working but everything is failture) so my point of this post is, that i swiched to Voodoo everything works great.. but only microphone bugging.. When i speak to other they hear too much noise and that stuff. Also i noticed in Sound/Input that when i listening music my microphone gathering that sound INPC 'even my microphone is turned off. And he capture all alerts and everything. Guessing, maybe that cause the reason of my problem but how to fix it? and yea my dump if u want
Last login: Fri Jun  8 14:26:53 on ttys000
bash:~ dbm$ /Volumes/HDD/Development/Programi/Drivers/VoodooHDA\ 2.7.3\ 2/getdump ; exit;
Found a device of class VoodooHDADevice: IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/HDEF@1B/VoodooHDADevice
Probing codec #0...
HDA Codec #0: Realtek ALC892
HDA Codec ID: 0x10ec0892
      Vendor: 0x10ec
      Device: 0x0892
    Revision: 0x03
    Stepping: 0x02
PCI Subvendor: 0x84361043
startNode=1 endNode=2
Found audio FG nid=1 startNode=2 endNode=39 total=37
Processing audio FG cad=0 nid=1...
Powering up...
Parsing audio FG...
GPIO: 0x40000002 NumGPIO=2 NumGPO=0 NumGPI=0 GPIWake=0 GPIUnsol=1
nid 17 0x99430140 as  4 seq  0     SPDIF-out Fixed jack  3 loc 25 color Unknown misc 1
nid 18 0x411111f0 as 15 seq  0       Speaker  None jack  1 loc  1 color   Black misc 1
nid 20 0x01014010 as  1 seq  0      Line-out  Jack jack  1 loc  1 color   Green misc 0
nid 21 0x01011012 as  1 seq  2      Line-out  Jack jack  1 loc  1 color   Black misc 0
nid 22 0x01016011 as  1 seq  1      Line-out  Jack jack  1 loc  1 color  Orange misc 0
nid 23 0x01012014 as  1 seq  4      Line-out  Jack jack  1 loc  1 color    Grey misc 0
nid 24 0x01a19850 as  5 seq  0    Microphone  Jack jack  1 loc  1 color    Pink misc 8
nid 25 0x02a19960 as  6 seq  0    Microphone  Jack jack  1 loc  2 color    Pink misc 9
nid 26 0x0181305f as  5 seq 15       Line-in  Jack jack  1 loc  1 color    Blue misc 0
nid 27 0x02214120 as  2 seq  0    Headphones  Jack jack  1 loc  2 color   Green misc 1
nid 28 0x411111f0 as 15 seq  0       Speaker  None jack  1 loc  1 color   Black misc 1
nid 29 0x4005e601 as  0 seq  1      Line-out  None jack  5 loc  0 color   White misc 6
nid 30 0x01456130 as  3 seq  0     SPDIF-out  Jack jack  5 loc  1 color  Orange misc 1
nid 31 0x411111f0 as 15 seq  0       Speaker  None jack  1 loc  1 color   Black misc 1
Parsing vendor patch...
VHDevice NID=2 Config=00000000 Type=00000000 Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID=3 Config=00000000 Type=00000000 Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID=4 Config=00000000 Type=00000000 Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID=5 Config=00000000 Type=00000000 Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID=6 Config=00000000 Type=00000000 Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID=7 Config=00000000 Type=0000000f Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID=8 Config=00000000 Type=00000001 Cap=00000000 Ctrl=00000000 -- Conns: 0=35
VHDevice NID=9 Config=00000000 Type=00000001 Cap=00000000 Ctrl=00000000 -- Conns: 0=34
VHDevice NID=10 Config=00000000 Type=00000001 Cap=00000000 Ctrl=00000000 -- Conns: 0=31
VHDevice NID=11 Config=00000000 Type=00000002 Cap=00000000 Ctrl=00000000 -- Conns: 0=24 1=25 2=26 3=27 4=28 5=29 6=20 7=21 8=22 9=23
VHDevice NID=12 Config=00000000 Type=00000002 Cap=00000000 Ctrl=00000000 -- Conns: 0=2 1=11
VHDevice NID=13 Config=00000000 Type=00000002 Cap=00000000 Ctrl=00000000 -- Conns: 0=3 1=11
VHDevice NID=14 Config=00000000 Type=00000002 Cap=00000000 Ctrl=00000000 -- Conns: 0=4 1=11
VHDevice NID=15 Config=00000000 Type=00000002 Cap=00000000 Ctrl=00000000 -- Conns: 0=5 1=11
VHDevice NID=16 Config=00000000 Type=00000000 Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID=17 Config=99430140 Type=00000004 Cap=00000010 Ctrl=00000040 -- Conns: 0=16
VHDevice NID=18 Config=411111f0 Type=00000004 Cap=00000020 Ctrl=00000000 -- Conns:
VHDevice NID=19 Config=00000000 Type=0000000f Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID=20 Config=01014010 Type=00000004 Cap=0001003e Ctrl=00000020 -- Conns: 0=12
VHDevice NID=21 Config=01011012 Type=00000004 Cap=00000036 Ctrl=00000020 -- Conns: 0=13
VHDevice NID=22 Config=01016011 Type=00000004 Cap=00000036 Ctrl=00000020 -- Conns: 0=14
VHDevice NID=23 Config=01012014 Type=00000004 Cap=00000036 Ctrl=00000020 -- Conns: 0=15
VHDevice NID=24 Config=01a19850 Type=00000004 Cap=00003736 Ctrl=00000021 -- Conns: 0=12 1=13 2=14 3=15 4=38
VHDevice NID=25 Config=02a19960 Type=00000004 Cap=0000373e Ctrl=00000020 -- Conns: 0=12 1=13 2=14 3=15 4=38
VHDevice NID=26 Config=0181305f Type=00000004 Cap=00003736 Ctrl=00000020 -- Conns: 0=12 1=13 2=14 3=15 4=38
VHDevice NID=27 Config=02214120 Type=00000004 Cap=0001373e Ctrl=00000020 -- Conns: 0=12 1=13 2=14 3=15 4=38
VHDevice NID=28 Config=411111f0 Type=00000004 Cap=00000024 Ctrl=00000020 -- Conns:
VHDevice NID=29 Config=4005e601 Type=00000004 Cap=00000020 Ctrl=00000020 -- Conns:
VHDevice NID=30 Config=01456130 Type=00000004 Cap=00000010 Ctrl=00000040 -- Conns: 0=6
VHDevice NID=31 Config=411111f0 Type=00000004 Cap=00000020 Ctrl=00000020 -- Conns:
VHDevice NID=32 Config=00000000 Type=0000000f Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID=33 Config=00000000 Type=0000000f Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID=34 Config=00000000 Type=00000002 Cap=00000000 Ctrl=00000000 -- Conns: 0=24 1=25 2=26 3=27 4=28 5=29 6=20 7=21 8=22 9=23 10=11 11=18
VHDevice NID=35 Config=00000000 Type=00000002 Cap=00000000 Ctrl=00000000 -- Conns: 0=24 1=25 2=26 3=27 4=28 5=29 6=20 7=21 8=22 9=23 10=11
VHDevice NID=36 Config=00000000 Type=0000000f Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID=37 Config=00000000 Type=00000000 Cap=00000000 Ctrl=00000000 -- Conns:
VHDevice NID=38 Config=00000000 Type=00000002 Cap=00000000 Ctrl=00000000 -- Conns: 0=37 1=11
Disabling nonaudio...
Disabling useless...
Disabling pin nid 18 due to None connectivity.
Disabling pin nid 28 due to None connectivity.
Disabling pin nid 29 due to None connectivity.
Disabling pin nid 31 due to None connectivity.
Disabling nid 10 connection 0 due to disabled child widget.
Disabling nid 11 connection 4 due to disabled child widget.
Disabling nid 11 connection 5 due to disabled child widget.
Disabling nid 34 connection 4 due to disabled child widget.
Disabling nid 34 connection 5 due to disabled child widget.
Disabling nid 34 connection 11 due to disabled child widget.
Disabling nid 35 connection 4 due to disabled child widget.
Disabling nid 35 connection 5 due to disabled child widget.
Patched pins configuration:
nid 18 0x411111f0 as 15 seq  0       Speaker  None jack  1 loc  1 color   Black misc 1 [DISABLED]
nid 28 0x411111f0 as 15 seq  0       Speaker  None jack  1 loc  1 color   Black misc 1 [DISABLED]
nid 29 0x4005e601 as  0 seq  1      Line-out  None jack  5 loc  0 color   White misc 6 [DISABLED]
nid 31 0x411111f0 as 15 seq  0       Speaker  None jack  1 loc  1 color   Black misc 1 [DISABLED]
Parsing pin associations...
6 associations found:
Association 0 (1) out:
Pin nid=20 seq=0
Pin nid=22 seq=1
Pin nid=21 seq=2
Pin nid=23 seq=4
  Redir type=0 jack=4 def=0
Association 1 (2) out:
Pin nid=27 seq=0
  Redir type=-1 jack=-1 def=0
Association 2 (3) out:
Pin nid=30 seq=0
Association 3 (4) out:
Pin nid=17 seq=0
Association 4 (5) in:
Pin nid=24 seq=0
Pin nid=26 seq=15
  Redir type=0 jack=15 def=0
Association 5 (6) in:
Pin nid=25 seq=0
Building AFG tree...
Tracing association 0 (1)
Tracing pin 20 with min nid 0
 tracing via nid 20
  tracing via nid 12
   tracing via nid 2
   nid 2 returned 2
   tracing via nid 11
    tracing via nid 24
    tracing via nid 25
    tracing via nid 26
    tracing via nid 27
    tracing via nid 20
    tracing via nid 21
    tracing via nid 22
    tracing via nid 23
  nid 12 returned 2
 nid 20 returned 2
Pin 20 traced to DAC 2
Tracing pin 22 with min nid 0
 tracing via nid 22
  tracing via nid 14
   tracing via nid 4
   nid 4 returned 4
   tracing via nid 11
    tracing via nid 24
    tracing via nid 25
    tracing via nid 26
    tracing via nid 27
    tracing via nid 20
    nid 20 busy by seqmask 1
    tracing via nid 21
    tracing via nid 22
    tracing via nid 23
  nid 14 returned 4
 nid 22 returned 4
Pin 22 traced to DAC 4
Tracing pin 21 with min nid 0
 tracing via nid 21
  tracing via nid 13
   tracing via nid 3
   nid 3 returned 3
   tracing via nid 11
    tracing via nid 24
    tracing via nid 25
    tracing via nid 26
    tracing via nid 27
    tracing via nid 20
    tracing via nid 21
    tracing via nid 22
    nid 22 busy by seqmask 2
    tracing via nid 23
  nid 13 returned 3
 nid 21 returned 3
Pin 21 traced to DAC 3
Tracing pin 23 with min nid 0
 tracing via nid 23
  tracing via nid 15
   tracing via nid 5
   nid 5 returned 5
   tracing via nid 11
    tracing via nid 24
    tracing via nid 25
    tracing via nid 26
    tracing via nid 27
    tracing via nid 20
    tracing via nid 21
    nid 21 busy by seqmask 4
    tracing via nid 22
    tracing via nid 23
  nid 15 returned 5
 nid 23 returned 5
Pin 23 traced to DAC 5
Association 0 (1) trace succeeded
Tracing association 1 (2)
Tracing pin 27 with min nid 0
 tracing via nid 27
  tracing via nid 12
  nid 12 busy by association 0
  tracing via nid 13
  nid 13 busy by association 0
  tracing via nid 14
  nid 14 busy by association 0
  tracing via nid 15
  nid 15 busy by association 0
  tracing via nid 38
   tracing via nid 37
   nid 37 returned 37
   tracing via nid 11
    tracing via nid 24
    tracing via nid 25
    tracing via nid 26
    tracing via nid 27
    tracing via nid 20
    nid 20 busy by association 0
    tracing via nid 21
    nid 21 busy by association 0
    tracing via nid 22
    nid 22 busy by association 0
    tracing via nid 23
    nid 23 busy by association 0
  nid 38 returned 37
 nid 27 returned 37
Pin 27 traced to DAC 37
Association 1 (2) trace succeeded
Tracing association 2 (3)
Tracing pin 30 with min nid 0
 tracing via nid 30
  tracing via nid 6
  nid 6 returned 6
 nid 30 returned 6
Pin 30 traced to DAC 6
Association 2 (3) trace succeeded
Tracing association 3 (4)
Tracing pin 17 with min nid 0
 tracing via nid 17
  tracing via nid 16
  nid 16 returned 16
 nid 17 returned 16
Pin 17 traced to DAC 16
Association 3 (4) trace succeeded
Tracing association 4 (5)
Tracing pin 24 to ADC 8
 tracing via nid 24
  tracing via nid 11
   tracing via nid 12
   tracing via nid 13
   tracing via nid 14
   tracing via nid 15
   tracing via nid 34
    tracing via nid 9
    nid 9 returned 0
   nid 34 returned 0
   tracing via nid 35
    tracing via nid 8
    nid 8 returned 1
   nid 35 returned 1
   tracing via nid 38
   nid 38 busy by association 1
  nid 11 returned 1
  tracing via nid 34
   tracing via nid 9
   nid 9 returned 0
  nid 34 returned 0
  tracing via nid 35
   tracing via nid 8
   nid 8 returned 1
  nid 35 returned 1
 nid 24 returned 1
Pin 24 traced to ADC 8
Tracing pin 26 to ADC 8
 tracing via nid 26
  tracing via nid 11
   tracing via nid 12
   tracing via nid 13
   tracing via nid 14
   tracing via nid 15
   tracing via nid 34
    tracing via nid 9
    nid 9 returned 0
   nid 34 returned 0
   tracing via nid 35
    tracing via nid 8
    nid 8 returned 1
   nid 35 returned 1
   tracing via nid 38
  nid 11 returned 1
  tracing via nid 34
   tracing via nid 9
   nid 9 returned 0
  nid 34 returned 0
  tracing via nid 35
   tracing via nid 8
   nid 8 returned 1
  nid 35 returned 1
 nid 26 returned 1
Pin 26 traced to ADC 8
Association 4 (5) trace succeeded
Tracing association 5 (6)
Tracing pin 25 to ADC 9
 tracing via nid 25
  tracing via nid 11
  nid 11 busy by association 4
  tracing via nid 34
   tracing via nid 9
   nid 9 returned 1
  nid 34 returned 1
  tracing via nid 35
  nid 35 busy by association 4
 nid 25 returned 1
Pin 25 traced to ADC 9
Association 5 (6) trace succeeded
Tracing input monitor
Tracing nid 11 to out
 tracing via nid 11
  tracing via nid 12
  nid 12 found output association 0
  tracing via nid 13
  nid 13 found output association 0
  tracing via nid 14
  nid 14 found output association 0
  tracing via nid 15
  nid 15 found output association 0
  tracing via nid 34
  nid 34 busy by input association 5
  tracing via nid 35
  nid 35 busy by input association 4
  tracing via nid 38
  nid 38 found output association 1
 nid 11 returned 1
nid 11 is input monitor
Tracing nid 34 to out
 tracing via nid 34
  tracing via nid 9
  nid 9 busy by input association 5
 nid 34 returned 0
Tracing nid 35 to out
 tracing via nid 35
  tracing via nid 8
  nid 8 busy by input association 4
 nid 35 returned 0
Tracing other input monitors
Tracing nid 24 to out
 tracing via nid 24
  tracing via nid 11
  nid 11 busy by input association 4
  tracing via nid 34
  tracing via nid 35
 nid 24 returned 0
Tracing nid 25 to out
 tracing via nid 25
  tracing via nid 11
  tracing via nid 34
  tracing via nid 35
 nid 25 returned 0
Tracing nid 26 to out
 tracing via nid 26
  tracing via nid 11
  tracing via nid 34
  tracing via nid 35
 nid 26 returned 0
Tracing beeper
Disabling unassociated widgets...
Disabling unassociated nid 7.
Disabling unassociated nid 10.
Disabling unassociated nid 19.
Disabling unassociated nid 32.
Disabling unassociated nid 33.
Disabling unassociated nid 36.
Disabling connection from output pin nid 11 conn 6 cnid 20.
Disabling connection from output pin nid 34 conn 6 cnid 20.
Disabling connection from output pin nid 35 conn 6 cnid 20.
Disabling connection from output pin nid 11 conn 7 cnid 21.
Disabling connection from output pin nid 34 conn 7 cnid 21.
Disabling connection from output pin nid 35 conn 7 cnid 21.
Disabling connection from output pin nid 11 conn 8 cnid 22.
Disabling connection from output pin nid 34 conn 8 cnid 22.
Disabling connection from output pin nid 35 conn 8 cnid 22.
Disabling connection from output pin nid 11 conn 9 cnid 23.
Disabling connection from output pin nid 34 conn 9 cnid 23.
Disabling connection from output pin nid 35 conn 9 cnid 23.
Disabling connection to input pin nid 24 conn 0.
Disabling connection to input pin nid 24 conn 1.
Disabling connection to input pin nid 24 conn 2.
Disabling connection to input pin nid 24 conn 3.
Disabling connection to input pin nid 24 conn 4.
Disabling connection to input pin nid 25 conn 0.
Disabling connection to input pin nid 25 conn 1.
Disabling connection to input pin nid 25 conn 2.
Disabling connection to input pin nid 25 conn 3.
Disabling connection to input pin nid 25 conn 4.
Disabling connection to input pin nid 26 conn 0.
Disabling connection to input pin nid 26 conn 1.
Disabling connection to input pin nid 26 conn 2.
Disabling connection to input pin nid 26 conn 3.
Disabling connection to input pin nid 26 conn 4.
Disabling connection from output pin nid 11 conn 3 cnid 27.
Disabling connection from output pin nid 34 conn 3 cnid 27.
Disabling connection from output pin nid 35 conn 3 cnid 27.
Disabling nonselected inputs...
Disabling unselected connection nid 27 conn 0.
Disabling unselected connection nid 27 conn 1.
Disabling unselected connection nid 27 conn 2.
Disabling unselected connection nid 27 conn 3.
Disabling crossassociated connections...
Binding associations to channels...
Assigning names to signal sources...
Parsing Ctls...
Assigning mixers to the tree...
Preparing pin controls...
AFG commit...
Creating PCM devices...
pcmAttach: HDA Realtek ALC892 PCM #0 Analog at cad 0 nid 1
| DUMPING PCM Playback/Record Channels |
Playback:
    Stream cap: 0x00000001
                PCM
       PCM cap: 0x000e0560
                16 20 24 bits, 44 48 96 192 KHz
           DAC: 2 4 3 5
Record:
                PCM
       PCM cap: 0x000e0560
           ADC: 8
| DUMPING Playback/Record Paths |
Playback:
   nid=20 [pin: Line-out (Green Rear)]
     + <- nid=12 [audio mixer]
   nid=22 [pin: Line-out (Orange Rear)]
     + <- nid=14 [audio mixer]
   nid=21 [pin: Line-out (Black Rear)]
     + <- nid=13 [audio mixer]
   nid=23 [pin: Line-out (Grey Rear)]
     + <- nid=15 [audio mixer]
Record:
   nid=8 [audio input]
     + <- nid=35 [audio mixer] [src: mix] bindSeq=00008001
            + <- nid=24 [pin: Microphone (Pink Rear)] [src: mic] bindSeq=00000001
            + <- nid=25 [pin: Microphone (Pink Front)] [src: monitor] bindSeq=00000001
            + <- nid=26 [pin: Line-in (Blue Rear)] [src: line] bindSeq=00008000
            + <- nid=11 [audio mixer]
Input Mix:
   nid=34 [audio mixer]
| DUMPING Volume Controls |
Master Volume (OSS: vol)
  +- control  1 (nid   2 out):    dir - out oss: vol, pcm -64/+0dB (65 steps)
  +- control  2 (nid   3 out):    dir - out oss: vol, pcm -64/+0dB (65 steps)
  +- control  3 (nid   4 out):    dir - out oss: vol, pcm -64/+0dB (65 steps)
  +- control  4 (nid   5 out):    dir - out oss: vol, pcm -64/+0dB (65 steps)
  +- control 15 (nid  12 in   0): dir - out oss: vol, pcm mute
  +- control 16 (nid  12 in   1): dir - out oss: vol, igain mute
  +- control 17 (nid  13 in   0): dir - out oss: vol, pcm mute
  +- control 18 (nid  13 in   1): dir - out oss: vol, igain mute
  +- control 19 (nid  14 in   0): dir - out oss: vol, pcm mute
  +- control 20 (nid  14 in   1): dir - out oss: vol, igain mute
  +- control 21 (nid  15 in   0): dir - out oss: vol, pcm mute
  +- control 22 (nid  15 in   1): dir - out oss: vol, igain mute
  +- control 23 (nid  20 out):    dir - out oss: vol mute
  +- control 24 (nid  21 out):    dir - out oss: vol mute
  +- control 25 (nid  22 out):    dir - out oss: vol mute
  +- control 26 (nid  23 out):    dir - out oss: vol mute
PCM Volume (OSS: pcm)
Microphone Volume (OSS: mic)
  +- control 28 (nid  24 in   0): dir - in oss: mic +0/+30dB (4 steps)
  +- control 44 (nid  35 in   0): dir - in oss: mic, rec mute
Microphone2 Volume (OSS: monitor)
  +- control 45 (nid  35 in   1): dir - in oss: rec, monitor mute
Line-in Volume (OSS: line)
  +- control 32 (nid  26 in   0): dir - in oss: line +0/+30dB (4 steps)
  +- control 46 (nid  35 in   2): dir - in oss: line, rec mute
Recording Level (OSS: rec)
  +- control  5 (nid   8 in   0): dir - in oss: mix, rec -16/+30dB (47 steps) + mute
  +- control 52 (nid  35 in  10): dir - in oss: rec mute
Input Mix Level (OSS: mix)
Input Monitoring Level (OSS: igain)
  +- control  7 (nid  11 in   0): dir - in oss: igain -34/+12dB (32 steps) + mute
  +- control  8 (nid  11 in   1): dir - in oss: igain -34/+12dB (32 steps) + mute
  +- control  9 (nid  11 in   2): dir - in oss: igain -34/+12dB (32 steps) + mute
OSS mixer initialization...
Registering PCM channels...
pcmAttach: HDA Realtek ALC892 PCM #1 Analog at cad 0 nid 1
Playback:
                PCM
       PCM cap: 0x000e0560
           DAC: 37
Record:
                PCM
       PCM cap: 0x000e0560
           ADC: 9
Playback:
   nid=27 [pin: Headphones (Green Front)]
     + <- nid=38 [audio mixer]
Record:
   nid=9 [audio input]
     + <- nid=34 [audio mixer] [src: mix] bindSeq=00000001
  +- control 33 (nid  27 out):    dir - out oss: vol mute
  +- control 53 (nid  37 out):    dir - out oss: vol, pcm -64/+0dB (65 steps)
  +- control 54 (nid  38 in   0): dir - out oss: vol, pcm mute
  +- control 55 (nid  38 in   1): dir - out oss: vol, igain mute
  +- control 35 (nid  34 in   0): dir - in oss: mic, rec mute
  +- control 30 (nid  25 in   0): dir - in oss: monitor +0/+30dB (4 steps)
  +- control 36 (nid  34 in   1): dir - in oss: rec, monitor mute
  +- control 37 (nid  34 in   2): dir - in oss: line, rec mute
  +- control  6 (nid   9 in   0): dir - in oss: mix, rec -16/+30dB (47 steps) + mute
  +- control 43 (nid  34 in  10): dir - in oss: rec mute
pcmAttach: HDA Realtek ALC892 PCM #2 Digital at cad 0 nid 1
Playback:
    Stream cap: 0x00000005
                AC3 PCM
       PCM cap: 0x000e05f0
                16 20 24 bits, 32 44 48 88 96 192 KHz
           DAC: 6
Playback:
   nid=30 [pin: SPDIF-out (Orange Rear)]
     + <- nid=6 [audio output] [src: pcm] bindSeq=00000001
pcmAttach: HDA Realtek ALC892 PCM #3 Digital at cad 0 nid 1
Playback:
                AC3 PCM
       PCM cap: 0x000e05f0
           DAC: 16
Playback:
   nid=17 [pin: SPDIF-out (ATAPI)]
     + <- nid=16 [audio output] [src: pcm] bindSeq=00000001
FG config/quirks: forcestereo ivref50 ivref80 ivref100 ivref
HP switch init...
| DUMPING HDA NODES |
Default Parameter
                PCM
       PCM cap: 0x000e05f0
        IN amp: 0x00000000
       OUT amp: 0x00000000
           nid: 2
    Widget cap: 0x0000041d
                PWR STEREO
   Association: 0 (0x00000001)
           OSS: pcm (pcm)
                PCM
       PCM cap: 0x000e0560
    Output amp: 0x00034040
                mute=0 step=64 size=3 offset=64
    Output val: [0x31 0x31]
           nid: 3
                PWR STEREO
   Association: 0 (0x00000004)
           OSS: pcm (pcm)
                PCM
       PCM cap: 0x000e0560
           nid: 4
                PWR STEREO
   Association: 0 (0x00000002)
           OSS: pcm (pcm)
                PCM
       PCM cap: 0x000e0560
           nid: 5
                PWR STEREO
   Association: 0 (0x00000010)
           OSS: pcm (pcm)
                PCM
       PCM cap: 0x000e0560
           nid: 6
    Widget cap: 0x00000611
                PWR DIGITAL STEREO
   Association: 2 (0x00000001)
           OSS: pcm (pcm)
                PCM
       PCM cap: 0x000e05f0
           nid: 7 [DISABLED]
    Widget cap: 0x00f00000
           nid: 8
    Widget cap: 0x0010051b
                PWR STEREO
   Association: 4 (0x00008001)
                PCM
       PCM cap: 0x000e0560
     Input amp: 0x80032e10
                mute=1 step=46 size=3 offset=16
     Input val: [0x1F 0x1F]
   connections: 1 enabled 1
           nid: 9
                PWR STEREO
   Association: 5 (0x00000001)
                PCM
       PCM cap: 0x000e0560
           nid: 10 [DISABLED]
    Widget cap: 0x00100711
                PWR DIGITAL STEREO
                PCM
       PCM cap: 0x000e0560
   connections: 1 enabled 0
         + [DISABLED] <- nid=31 [pin: Speaker (None)] [DISABLED]
           nid: 11
    Widget cap: 0x0020010b
                STEREO
           OSS:  (igain)
     Input amp: 0x80051f17
                mute=1 step=31 size=5 offset=23
     Input val: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x17 0x17] [0x80 0x80] [0x80 0x80] [0x17 0x17] [0x17 0x17] [0x17 0x17] [0x17 0x17]
   connections: 10 enabled 3
         + [DISABLED] <- nid=27 [pin: Headphones (Green Front)]
         + [DISABLED] <- nid=28 [pin: Speaker (None)] [DISABLED]
         + [DISABLED] <- nid=29 [pin: Line-out (None)] [DISABLED]
         + [DISABLED] <- nid=20 [pin: Line-out (Green Rear)]
         + [DISABLED] <- nid=21 [pin: Line-out (Black Rear)]
         + [DISABLED] <- nid=22 [pin: Line-out (Orange Rear)]
         + [DISABLED] <- nid=23 [pin: Line-out (Grey Rear)]
           nid: 12
                STEREO
           OSS:  (igain)
     Input amp: 0x80000000
                mute=1 step=0 size=0 offset=0
     Input val: [0x00 0x00] [0x80 0x80]
   connections: 2 enabled 2
         + <- nid=2 [audio output]
           nid: 13
                STEREO
           OSS:  (igain)
         + <- nid=3 [audio output]
           nid: 14
                STEREO
           OSS:  (igain)
         + <- nid=4 [audio output]
           nid: 15
                STEREO
           OSS:  (igain)
         + <- nid=5 [audio output]
           nid: 16
                PWR DIGITAL STEREO
   Association: 3 (0x00000001)
           OSS: pcm (pcm)
                PCM
       PCM cap: 0x000e05f0
           nid: 17
          Name: pin: SPDIF-out (ATAPI)
    Widget cap: 0x00400781
                PWR DIGITAL UNSOL STEREO
       Pin cap: 0x00000010
                OUT
    Pin config: 0x99430140
   Pin control: 0x00000040 OUT
           nid: 18 [DISABLED]
          Name: pin: Speaker (None)
    Widget cap: 0x00400401
                PWR STEREO
       Pin cap: 0x00000020
                IN
    Pin config: 0x411111f0
   Pin control: 0x00000000
           nid: 19 [DISABLED]
           nid: 20
          Name: pin: Line-out (Green Rear)
    Widget cap: 0x0040058d
                PWR UNSOL STEREO
       Pin cap: 0x0001003e
                TRQD PDC HP OUT IN EAPD
    Pin config: 0x01014010
          EAPD: 0x00000002
    Output amp: 0x80000000
    Output val: [0x00 0x00]
           nid: 21
          Name: pin: Line-out (Black Rear)
                PWR UNSOL STEREO
       Pin cap: 0x00000036
                TRQD PDC OUT IN
    Pin config: 0x01011012
           nid: 22
          Name: pin: Line-out (Orange Rear)
                PWR UNSOL STEREO
       Pin cap: 0x00000036
                TRQD PDC OUT IN
    Pin config: 0x01016011
           nid: 23
          Name: pin: Line-out (Grey Rear)
                PWR UNSOL STEREO
       Pin cap: 0x00000036
                TRQD PDC OUT IN
    Pin config: 0x01012014
           nid: 24
          Name: pin: Microphone (Pink Rear)
    Widget cap: 0x0040058f
                PWR UNSOL STEREO
   Association: 4 (0x00000001)
           OSS: mic (mic)
       Pin cap: 0x00003736
                TRQD PDC OUT IN VREF[ 50 80 100 GROUND HIZ ]
    Pin config: 0x01a19850
   Pin control: 0x00000025 IN VREFs
     Input amp: 0x00270300
                mute=0 step=3 size=39 offset=0
     Input val: [0x02 0x02] [0x00 0x00] [0x00 0x00] [0x00 0x00] [0x00 0x00]
   connections: 5 enabled 0
         + [DISABLED] <- nid=12 [audio mixer] (selected)
         + [DISABLED] <- nid=13 [audio mixer]
         + [DISABLED] <- nid=14 [audio mixer]
         + [DISABLED] <- nid=15 [audio mixer]
         + [DISABLED] <- nid=38 [audio mixer]
           nid: 25
          Name: pin: Microphone (Pink Front)
                PWR UNSOL STEREO
           OSS: monitor (monitor)
       Pin cap: 0x0000373e
                TRQD PDC HP OUT IN VREF[ 50 80 100 GROUND HIZ ]
    Pin config: 0x02a19960
           nid: 26
          Name: pin: Line-in (Blue Rear)
                PWR UNSOL STEREO
   Association: 4 (0x00008000)
           OSS: line (line)
       Pin cap: 0x00003736
    Pin config: 0x0181305f
           nid: 27
          Name: pin: Headphones (Green Front)
                PWR UNSOL STEREO
   Association: 1 (0x00000001)
       Pin cap: 0x0001373e
                TRQD PDC HP OUT IN VREF[ 50 80 100 GROUND HIZ ] EAPD
    Pin config: 0x02214120
   Pin control: 0x000000c0 HP OUT
          EAPD: 0x00000002
     Input val: [0x00 0x00] [0x00 0x00] [0x00 0x00] [0x00 0x00] [0x00 0x00]
   connections: 5 enabled 1
         + <- nid=38 [audio mixer] (selected)
           nid: 28 [DISABLED]
    Widget cap: 0x00400481
                PWR UNSOL STEREO
       Pin cap: 0x00000024
                PDC IN
           nid: 29 [DISABLED]
          Name: pin: Line-out (None)
    Widget cap: 0x00400400
                PWR
       Pin cap: 0x00000020
                IN
    Pin config: 0x4005e601
           nid: 30
          Name: pin: SPDIF-out (Orange Rear)
       Pin cap: 0x00000010
                OUT
    Pin config: 0x01456130
           nid: 31 [DISABLED]
    Widget cap: 0x00400681
       Pin cap: 0x00000020
                IN
           nid: 32 [DISABLED]
    Widget cap: 0x00f00040
                PROC
           nid: 33 [DISABLED]
           nid: 34
                STEREO
           OSS: mix (mix)
     Input val: [0x00 0x00] [0x00 0x00] [0x00 0x00] [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x00 0x00] [0x00 0x00] [0x00 0x00] [0x00 0x00] [0x00 0x00] [0x80 0x80]
   connections: 12 enabled 4
         + [DISABLED] <- nid=18 [pin: Speaker (None)] [DISABLED]
           nid: 35
                STEREO
           OSS: mix (mix)
   connections: 11 enabled 4
           nid: 36 [DISABLED]
           nid: 37
                PWR STEREO
           OSS: pcm (pcm)
                PCM
       PCM cap: 0x000e0560
           nid: 38
                STEREO
           OSS:  (igain)
         + <- nid=37 [audio output]
Probing codec #3...
logout
[Process completed]
What values are you using for Mic, iMix and iGain? Maybe you need to turn down some of those values a bit, so that the input bar in sound preferences only moves when you speak close to the mic.
Also, you should patch these nodes (nothing to do with mic problem)
nid 21 0x01011070
nid 22 0x01016080
nid 23 0x01012090
nid 26 0x018130a0
and this only if you want auto-detect between speaker and headphones
nid 27 0x0221401f
nid 21 0x01011070
nid 22 0x01016080
nid 23 0x01012090
nid 26 0x018130a0
nid 27 0x0221401f
Hey cassio.. still didn't managed to get my microphone working nice.. still is bugging .. :| here u go my .kext please if u have time look bait and see where i wrong try to fix it, i lost my mind bro, i tried to get alc892 working for 5days = failed. now with this.. i don't have strength for it :D And i appreciate ur help! if u need more informations just tell, i will attack IOReg too
IOREG LING = https://www.dropbox.com/s/2cttd08td4jrc96/dbm.ioreg
VoodooHDA.kext.zip
Have you tried the NodesToPatch/MixerValues changes I suggested earlier? They are not in the kext you attached.
