artur-pt Posted October 28, 2012 Posted October 28, 2012 hello try to use that 1) intel HDA 5 series/3400 series chipset (ven id 8086, dev id 3b56) and try to see what alc u have ? good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
finaluser Posted October 29, 2012 Posted October 29, 2012 Thanks for the post, really usefull to make my Sound Card work Dell Latitude E6420 Intel 92HDxxx HD Audio (DevID 1c20 VenID 8086) Nvidia HDMI Audio Controller (DevID 0e08 VenID 10de) VoodooHDA 2.7.3 Installed http://code.google.com/p/voodoohda/downloads/list Change DevID VenID on Info.plist, with Intel on first dict section. Intel 92HDxxx VoodooHDA-1 .. IOPCIPrimaryMatch 0x1c208086 Nvidia HDMI VoodooHDA-1 .. IOPCIPrimaryMatch 0x0e0810de On both dict sections VoodooHDAEnableHalfVolumeFix <true/> VoodooHDAEnableMuteFix <true/> VoodooHDAEnableVolumeChangeFix <true/> Note: Don't forget to reload extensions (sudo touch /System/Library/Extensions) and restart On Audio MIDI Setup Change Format to 2ch-16bit Integer (from 2ch-24bit Integer) System Info Tool was used to get DevID/VenID http://www.insanelymac.com/forum/topic/219584-system-info-an-app-to-get-hardware-and-kexts-info/ Regards,
java_lava Posted January 3, 2013 Posted January 3, 2013 Hello everyone I am attempting add the HDMI output to my info.plist on the VodooHDA but the info.plist in the tutorial looks different to my info.plist For example in the tutorial the info.plist has a key with name HDMI, my info.plist has not this key I dont know if i did good adding my device id, here is my info.plist In red is what i did <?xml version="1.0" encoding="UTF-8"?> CFBundleDevelopmentRegion English CFBundleExecutable VoodooHDA CFBundleIdentifier org.voodoo.driver.VoodooHDA CFBundleInfoDictionaryVersion 6.0 CFBundleName VoodooHDA CFBundlePackageType KEXT CFBundleShortVersionString 2.7.4 CFBundleSignature ???? CFBundleVersion 2.7.4 IOKitPersonalities VoodooHDA CFBundleIdentifier org.voodoo.driver.VoodooHDA IOClass VoodooHDADevice IOMatchCategory VoodooHDADevice IOPCIPrimaryMatch 0x1e208086 <----- onboard 0x0bee10de <----- HDMI IOProviderClass IOPCIDevice IOUserClientClass VoodooHDAUserClient InhibitCache MixerValues iGain 90 iMix 0 NodesToPatch Noise 0 Vectorize VoodooHDAEnableHalfMicVolumeFix VoodooHDAEnableHalfVolumeFix VoodooHDAEnableMuteFix VoodooHDAEnableVolumeChangeFix VoodooHDAVerboseLevel 0 OSBundleLibraries com.apple.iokit.IOAudioFamily 1.1fc9 com.apple.iokit.IOPCIFamily 2.1 com.apple.kpi.iokit 9.0.0 com.apple.kpi.libkern 9.0.0 com.apple.kpi.mach 9.0.0 com.apple.kpi.unsupported 9.0.0 Greetings
pernacabeluda Posted January 3, 2013 Posted January 3, 2013 Hello, you must add the entire HDMI key. <?xml version="1.0" encoding="UTF-8"?> CFBundleDevelopmentRegion English CFBundleExecutable VoodooHDA CFBundleIdentifier org.voodoo.driver.VoodooHDA CFBundleInfoDictionaryVersion 6.0 CFBundleName VoodooHDA CFBundlePackageType KEXT CFBundleShortVersionString 2.7.4 CFBundleSignature ???? CFBundleVersion 2.7.4 IOKitPersonalities VoodooHDA CFBundleIdentifier org.voodoo.driver.VoodooHDA IOClass VoodooHDADevice IOMatchCategory VoodooHDADevice IOPCIPrimaryMatch 0x1e208086 IOProviderClass IOPCIDevice IOUserClientClass VoodooHDAUserClient InhibitCache MixerValues iGain 90 iMix 0 NodesToPatch Noise 0 Vectorize VoodooHDAEnableHalfMicVolumeFix VoodooHDAEnableHalfVolumeFix VoodooHDAEnableMuteFix VoodooHDAEnableVolumeChangeFix VoodooHDAVerboseLevel 0 [color=#FF0000]HDMI CFBundleIdentifier org.voodoo.driver.VoodooHDA IOClass VoodooHDADevice IOMatchCategory VoodooHDADevice IOPCIPrimaryMatch 0x0bee10de IOProviderClass IOPCIDevice IOUserClientClass VoodooHDAUserClient NodesToPatch VoodooHDAVerboseLevel 0 [/color] OSBundleLibraries com.apple.iokit.IOAudioFamily 1.1fc9 com.apple.iokit.IOPCIFamily 2.1 com.apple.kpi.iokit 9.0.0 com.apple.kpi.libkern 9.0.0 com.apple.kpi.mach 9.0.0 com.apple.kpi.unsupported 9.0.0 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
java_lava Posted January 4, 2013 Posted January 4, 2013 Thanks pernacabeluda, works perfectly Now i need fix the inputs and outputs, don't show in sound preferences. I hope understand guide at the start of this thread, for me is basic Chinese Grettings
romaincs Posted January 12, 2013 Posted January 12, 2013 Hello all, I try to make my X-Fi titanium fully working with 2.8.1 kext compiled from sourceforge svn lastest sources. I have sound working with no mod from green back/front output, with headphone detection. My problem is the mic that do not work. Which way should I take to troubleshoot a port that does not work ? Thanks for reading. I also post my dump if you want to have a look to : Found a device of class VoodooHDADevice: IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/NPE5@5/IOPCI2PCIBridge/pci-bridge@0/IOPCI2PCIBridge/pci-bridge@4/IOPCI2PCIBridge/pci1002,aa50@0,1/VoodooHDADevice Probing codec #0... HDA Codec #0: ATI R6xx HDMI HDA Codec ID: 0x1002aa01 Vendor: 0x1002 Device: 0xaa01 Revision: 0x02 Stepping: 0x00 PCI Subvendor: 0xaa501002 startNode=1 endNode=2 Found audio FG nid=1 startNode=2 endNode=4 total=2 Processing audio FG cad=0 nid=1... Powering up... Parsing audio FG... GPIO: 0x00000000 NumGPIO=0 NumGPO=0 NumGPI=0 GPIWake=0 GPIUnsol=0 nid 3 0x18560010 as 1 seq 0 Digital-out Jack jack 6 loc 24 color Unknown misc 0 Parsing vendor patch... VHDevice NID=2 Config=00000000 Type=00000000 Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=3 Config=18560010 Type=00000004 Cap=00000094 Ctrl=00000040 -- Conns: 0=2 Disabling nonaudio... Disabling useless... Patched pins configuration: nid 3 0x18560010 as 1 seq 0 Digital-out Jack jack 6 loc 24 color Unknown misc 0 Parsing pin associations... 1 associations found: Association 0 (1) out: Pin nid=3 seq=0 Redir type=-1 jack=0 def=0 Building AFG tree... Tracing association 0 (1) Tracing pin 3 with min nid 0 tracing via nid 3 tracing via nid 2 nid 2 returned 2 nid 3 returned 2 Pin 3 traced to DAC 2 Association 0 (1) trace succeeded Tracing input monitor Tracing other input monitors Tracing beeper Disabling unassociated widgets... Disabling nonselected inputs... Disabling useless... Disabling crossassociated connections... Disabling useless... Binding associations to channels... Assigning names to signal sources... Parsing Ctls... Assigning mixers to the tree... Preparing pin controls... AFG commit... Creating PCM devices... pcmAttach: HDA ATI R6xx HDMI PCM #0 HDMI at cad 0 nid 1 +--------------------------------------+ | DUMPING PCM Playback/Record Channels | +--------------------------------------+ Playback: Stream cap: 0x00000005 AC3 PCM PCM cap: 0x00020070 16 bits, 32 44 48 KHz DAC: 2 +-------------------------------+ | DUMPING Playback/Record Paths | +-------------------------------+ Playback: nid=3 [pin: Digital-out (HDMI)] | + <- nid=2 [audio output] [src: pcm] bindSeq=00000001 +-------------------------+ | DUMPING Volume Controls | +-------------------------+ OSS mixer initialization... Registering PCM channels... FG config/quirks: forcestereo ivref50 ivref80 ivref100 ivref HP switch init... +-------------------+ | DUMPING HDA NODES | +-------------------+ Default Parameter ----------------- Stream cap: 0x00000001 PCM PCM cap: 0x00020070 16 bits, 32 44 48 KHz IN amp: 0x00000000 OUT amp: 0x00000000 nid: 2 Name: audio output Widget cap: 0x00000201 DIGITAL STEREO Association: 0 (0x00000001) OSS: pcm (pcm) Stream cap: 0x00000001 PCM PCM cap: 0x00020070 16 bits, 32 44 48 KHz nid: 3 Name: pin: Digital-out (HDMI) Widget cap: 0x00400381 DIGITAL UNSOL STEREO Association: 0 (0x00000001) Pin cap: 0x00000094 PDC OUT HDMI Pin config: 0x18560010 Pin control: 0x00000040 OUT connections: 1 enabled 1 | + <- nid=2 [audio output] Found a device of class VoodooHDADevice: IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/NPE7@7/IOPCI2PCIBridge/pci1102,b@0/VoodooHDADevice Probing codec #1... HDA Codec #1: Creative X-Fi Extreme D HDA Codec ID: 0x1102000d Vendor: 0x1102 Device: 0x000d Revision: 0x00 Stepping: 0x00 PCI Subvendor: 0x00431102 startNode=1 endNode=2 Found audio FG nid=1 startNode=2 endNode=25 total=23 Processing audio FG cad=1 nid=1... Powering up... Parsing audio FG... GPIO: 0x00000000 NumGPIO=0 NumGPO=0 NumGPI=0 GPIWake=0 GPIUnsol=0 nid 13 0x01014010 as 1 seq 0 Line-out Jack jack 1 loc 1 color Green misc 0 nid 14 0x01016011 as 1 seq 1 Line-out Jack jack 1 loc 1 color Orange misc 0 nid 15 0x01011012 as 1 seq 2 Line-out Jack jack 1 loc 1 color Black misc 0 nid 16 0x01012014 as 1 seq 4 Line-out Jack jack 1 loc 1 color Grey misc 0 nid 17 0x0221401f as 1 seq 15 Headphones Jack jack 1 loc 2 color Green misc 0 nid 18 0x01452130 as 3 seq 0 SPDIF-out Jack jack 5 loc 1 color Grey misc 1 nid 19 0x01813040 as 4 seq 0 Line-in Jack jack 1 loc 1 color Blue misc 0 nid 20 0x02a19050 as 5 seq 0 Microphone Jack jack 1 loc 2 color Pink misc 0 nid 21 0x41811060 as 6 seq 0 Line-in None jack 1 loc 1 color Black misc 0 nid 22 0x41911070 as 7 seq 0 AUX None jack 1 loc 1 color Black misc 0 nid 23 0x01c51180 as 8 seq 0 SPDIF-in Jack jack 5 loc 1 color Black misc 1 Parsing vendor patch... VHDevice NID=2 Config=00000000 Type=00000000 Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=3 Config=00000000 Type=00000000 Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=4 Config=00000000 Type=00000000 Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=5 Config=00000000 Type=00000000 Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=6 Config=00000000 Type=0000000f Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=7 Config=00000000 Type=00000000 Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=8 Config=00000000 Type=00000001 Cap=00000000 Ctrl=00000000 -- Conns: 0=19 VHDevice NID=9 Config=00000000 Type=00000001 Cap=00000000 Ctrl=00000000 -- Conns: 0=20 VHDevice NID=10 Config=00000000 Type=00000001 Cap=00000000 Ctrl=00000000 -- Conns: 0=21 VHDevice NID=11 Config=00000000 Type=00000001 Cap=00000000 Ctrl=00000000 -- Conns: 0=22 VHDevice NID=12 Config=00000000 Type=00000001 Cap=00000000 Ctrl=00000000 -- Conns: 0=23 VHDevice NID=13 Config=01014010 Type=00000004 Cap=00000014 Ctrl=000000c0 -- Conns: 0=2 VHDevice NID=14 Config=01016011 Type=00000004 Cap=00000014 Ctrl=000000c0 -- Conns: 0=3 VHDevice NID=15 Config=01011012 Type=00000004 Cap=00000014 Ctrl=000000c0 -- Conns: 0=4 VHDevice NID=16 Config=01012014 Type=00000004 Cap=00000014 Ctrl=000000c0 -- Conns: 0=5 VHDevice NID=17 Config=0221401f Type=00000004 Cap=0000001c Ctrl=000000c0 -- Conns: 0=2 VHDevice NID=18 Config=01452130 Type=00000004 Cap=00000010 Ctrl=000000c0 -- Conns: 0=7 VHDevice NID=19 Config=01813040 Type=00000004 Cap=00000024 Ctrl=000000a0 -- Conns: VHDevice NID=20 Config=02a19050 Type=00000004 Cap=00000024 Ctrl=000000a0 -- Conns: VHDevice NID=21 Config=41811060 Type=00000004 Cap=00000026 Ctrl=000000a0 -- Conns: VHDevice NID=22 Config=41911070 Type=00000004 Cap=00000026 Ctrl=000000a0 -- Conns: VHDevice NID=23 Config=01c51180 Type=00000004 Cap=00000020 Ctrl=000000a0 -- Conns: VHDevice NID=24 Config=00000000 Type=0000000f Cap=00000000 Ctrl=00000000 -- Conns: Disabling nonaudio... Disabling useless... Disabling nid 10 connection 0 due to disabled child widget. Disabling nid 11 connection 0 due to disabled child widget. Patched pins configuration: nid 13 0x01014010 as 1 seq 0 Line-out Jack jack 1 loc 1 color Green misc 0 nid 14 0x01016011 as 1 seq 1 Line-out Jack jack 1 loc 1 color Orange misc 0 nid 15 0x01011012 as 1 seq 2 Line-out Jack jack 1 loc 1 color Black misc 0 nid 16 0x01012014 as 1 seq 4 Line-out Jack jack 1 loc 1 color Grey misc 0 nid 17 0x0221401f as 1 seq 15 Headphones Jack jack 1 loc 2 color Green misc 0 nid 18 0x01452130 as 3 seq 0 SPDIF-out Jack jack 5 loc 1 color Grey misc 1 nid 19 0x01813040 as 4 seq 0 Line-in Jack jack 1 loc 1 color Blue misc 0 nid 20 0x02a19050 as 5 seq 0 Microphone Jack jack 1 loc 2 color Pink misc 0 nid 21 0x41811060 as 6 seq 0 Line-in None jack 1 loc 1 color Black misc 0 [DISABLED] nid 22 0x41911070 as 7 seq 0 AUX None jack 1 loc 1 color Black misc 0 [DISABLED] nid 23 0x01c51180 as 8 seq 0 SPDIF-in Jack jack 5 loc 1 color Black misc 1 Parsing pin associations... 5 associations found: Association 0 (1) out: Pin nid=13 seq=0 Pin nid=14 seq=1 Pin nid=15 seq=2 Pin nid=16 seq=4 Pin nid=17 seq=15 Redir type=0 jack=15 def=0 Association 1 (3) out: Pin nid=18 seq=0 Redir type=-1 jack=-1 def=0 Association 2 (4) in: Pin nid=19 seq=0 Redir type=-1 jack=0 def=0 Association 3 (5) in: Pin nid=20 seq=0 Redir type=-1 jack=0 def=0 Association 4 (8) in: Pin nid=23 seq=0 Redir type=-1 jack=-1 def=0 Building AFG tree... Tracing association 0 (1) Tracing pin 13 with min nid 0 tracing via nid 13 tracing via nid 2 nid 2 returned 2 nid 13 returned 2 Pin 13 traced to DAC 2 Tracing pin 14 with min nid 0 tracing via nid 14 tracing via nid 3 nid 3 returned 3 nid 14 returned 3 Pin 14 traced to DAC 3 Tracing pin 15 with min nid 0 tracing via nid 15 tracing via nid 4 nid 4 returned 4 nid 15 returned 4 Pin 15 traced to DAC 4 Tracing pin 16 with min nid 0 tracing via nid 16 tracing via nid 5 nid 5 returned 5 nid 16 returned 5 Pin 16 traced to DAC 5 Tracing pin 17 with min nid 0 and hpredir 0 tracing via nid 17 tracing via nid 2 nid 2 returned 2 nid 17 returned 2 Pin 17 traced to DAC 2 and hpredir 0 Association 0 (1) trace succeeded Tracing association 1 (3) Tracing pin 18 with min nid 0 tracing via nid 18 tracing via nid 7 nid 7 returned 7 nid 18 returned 7 Pin 18 traced to DAC 7 Association 1 (3) trace succeeded Tracing association 2 (4) Tracing pin 19 to ADC 8 tracing via nid 19 tracing via nid 8 nid 8 returned 1 nid 19 returned 1 Pin 19 traced to ADC 8 Association 2 (4) trace succeeded Tracing association 3 (5) Tracing pin 20 to ADC 9 tracing via nid 20 tracing via nid 9 nid 9 returned 1 nid 20 returned 1 Pin 20 traced to ADC 9 Association 3 (5) trace succeeded Tracing association 4 (8) Tracing pin 23 to ADC 10 tracing via nid 23 tracing via nid 12 nid 12 returned 0 nid 23 returned 0 Unable to trace pin 23 to ADC 10, undo traces Tracing pin 23 to ADC 11 tracing via nid 23 tracing via nid 12 nid 12 returned 0 nid 23 returned 0 Unable to trace pin 23 to ADC 11, undo traces Tracing pin 23 to ADC 12 tracing via nid 23 tracing via nid 12 nid 12 returned 1 nid 23 returned 1 Pin 23 traced to ADC 12 Association 4 (8) trace succeeded Tracing input monitor Tracing other input monitors Tracing nid 19 to out tracing via nid 19 tracing via nid 8 nid 8 busy by input association 2 nid 19 returned 0 Tracing nid 20 to out tracing via nid 20 tracing via nid 9 nid 9 busy by input association 3 nid 20 returned 0 Tracing nid 23 to out tracing via nid 23 tracing via nid 12 nid 12 busy by input association 4 nid 23 returned 0 Tracing beeper Disabling unassociated widgets... Disabling nonselected inputs... Disabling useless... Disabling crossassociated connections... Disabling useless... Binding associations to channels... Assigning names to signal sources... Parsing Ctls... Assigning mixers to the tree... Preparing pin controls... AFG commit... Creating PCM devices... pcmAttach: HDA Creative X-Fi Extreme D PCM #0 Analog at cad 1 nid 1 +--------------------------------------+ | DUMPING PCM Playback/Record Channels | +--------------------------------------+ Playback: Stream cap: 0x00000001 PCM PCM cap: 0x000a0160 16 24 bits, 44 48 96 KHz DAC: 2 3 4 5 Record: Stream cap: 0x00000001 PCM PCM cap: 0x000a0160 16 24 bits, 44 48 96 KHz ADC: 8 +-------------------------------+ | DUMPING Playback/Record Paths | +-------------------------------+ Playback: nid=13 [pin: Line-out (Green Rear)] | + <- nid=2 [audio output] [src: pcm] bindSeq=00008001 nid=14 [pin: Line-out (Orange Rear)] | + <- nid=3 [audio output] [src: pcm] bindSeq=00000002 nid=15 [pin: Line-out (Black Rear)] | + <- nid=4 [audio output] [src: pcm] bindSeq=00000004 nid=16 [pin: Line-out (Grey Rear)] | + <- nid=5 [audio output] [src: pcm] bindSeq=00000010 nid=17 [pin: Headphones (Green Front)] | + <- nid=2 [audio output] [src: pcm] bindSeq=00008001 Record: nid=8 [audio input] | + <- nid=19 [pin: Line-in (Blue Rear)] [src: line] bindSeq=00000001 +-------------------------+ | DUMPING Volume Controls | +-------------------------+ Master Volume (OSS: vol) | +- control 1 (nid 2 out): dir - out oss: vol, pcm -51/+0dB (104 steps) + mute +- control 2 (nid 3 out): dir - out oss: vol, pcm -51/+0dB (104 steps) + mute +- control 3 (nid 4 out): dir - out oss: vol, pcm -51/+0dB (104 steps) + mute +- control 4 (nid 5 out): dir - out oss: vol, pcm -51/+0dB (104 steps) + mute PCM Volume (OSS: pcm) | +- control 1 (nid 2 out): dir - out oss: vol, pcm -51/+0dB (104 steps) + mute +- control 2 (nid 3 out): dir - out oss: vol, pcm -51/+0dB (104 steps) + mute +- control 3 (nid 4 out): dir - out oss: vol, pcm -51/+0dB (104 steps) + mute +- control 4 (nid 5 out): dir - out oss: vol, pcm -51/+0dB (104 steps) + mute Line-in Volume (OSS: line) | +- control 6 (nid 8 in 0): dir - in oss: line, rec -51/+6dB (116 steps) + mute Recording Level (OSS: rec) | +- control 6 (nid 8 in 0): dir - in oss: line, rec -51/+6dB (116 steps) + mute OSS mixer initialization... Registering PCM channels... pcmAttach: HDA Creative X-Fi Extreme D PCM #1 Digital at cad 1 nid 1 +--------------------------------------+ | DUMPING PCM Playback/Record Channels | +--------------------------------------+ Playback: Stream cap: 0x00000005 AC3 PCM PCM cap: 0x000a0160 16 24 bits, 44 48 96 KHz DAC: 7 Record: Stream cap: 0x00000005 AC3 PCM PCM cap: 0x000a0160 16 24 bits, 44 48 96 KHz ADC: 12 +-------------------------------+ | DUMPING Playback/Record Paths | +-------------------------------+ Playback: nid=18 [pin: SPDIF-out (Grey Rear)] | + <- nid=7 [audio output] [src: pcm] bindSeq=00000001 Record: nid=12 [audio input] | + <- nid=23 [pin: SPDIF-in (Black Rear)] [src: dig1] bindSeq=00000001 +-------------------------+ | DUMPING Volume Controls | +-------------------------+ Master Volume (OSS: vol) | +- control 5 (nid 7 out): dir - out oss: vol, pcm -51/+0dB (104 steps) + mute PCM Volume (OSS: pcm) | +- control 5 (nid 7 out): dir - out oss: vol, pcm -51/+0dB (104 steps) + mute Recording Level (OSS: rec) | +- control 8 (nid 12 in 0): dir - in oss: rec, dig1 -51/+6dB (116 steps) + mute Unknown Ctl (OSS: dig1) | +- control 8 (nid 12 in 0): dir - in oss: rec, dig1 -51/+6dB (116 steps) + mute OSS mixer initialization... Registering PCM channels... pcmAttach: HDA Creative X-Fi Extreme D PCM #2 Analog at cad 1 nid 1 +--------------------------------------+ | DUMPING PCM Playback/Record Channels | +--------------------------------------+ Record: Stream cap: 0x00000001 PCM PCM cap: 0x000a0160 16 24 bits, 44 48 96 KHz ADC: 9 +-------------------------------+ | DUMPING Playback/Record Paths | +-------------------------------+ Record: nid=9 [audio input] | + <- nid=20 [pin: Microphone (Pink Front)] [src: mic] bindSeq=00000001 +-------------------------+ | DUMPING Volume Controls | +-------------------------+ Microphone Volume (OSS: mic) | +- control 7 (nid 9 in 0): dir - in oss: mic, rec -51/+12dB (128 steps) + mute Recording Level (OSS: rec) | +- control 7 (nid 9 in 0): dir - in oss: mic, rec -51/+12dB (128 steps) + mute OSS mixer initialization... Registering PCM channels... FG config/quirks: forcestereo ivref50 ivref80 ivref100 ivref HP switch init... +-------------------+ | DUMPING HDA NODES | +-------------------+ Default Parameter ----------------- Stream cap: 0x00000001 PCM PCM cap: 0x000a0160 16 24 bits, 44 48 96 KHz IN amp: 0x80017367 OUT amp: 0x80016767 nid: 2 Name: audio output Widget cap: 0x00000005 STEREO Association: 0 (0x00008001) OSS: pcm (pcm) Stream cap: 0x00000001 PCM PCM cap: 0x000a0160 16 24 bits, 44 48 96 KHz Output amp: 0x80016767 mute=1 step=103 size=1 offset=103 Output val: [0x4A 0x4A] nid: 3 Name: audio output Widget cap: 0x00000005 STEREO Association: 0 (0x00000002) OSS: pcm (pcm) Stream cap: 0x00000001 PCM PCM cap: 0x000a0160 16 24 bits, 44 48 96 KHz Output amp: 0x80016767 mute=1 step=103 size=1 offset=103 Output val: [0x4A 0x4A] nid: 4 Name: audio output Widget cap: 0x00000005 STEREO Association: 0 (0x00000004) OSS: pcm (pcm) Stream cap: 0x00000001 PCM PCM cap: 0x000a0160 16 24 bits, 44 48 96 KHz Output amp: 0x80016767 mute=1 step=103 size=1 offset=103 Output val: [0x4A 0x4A] nid: 5 Name: audio output Widget cap: 0x00000005 STEREO Association: 0 (0x00000010) OSS: pcm (pcm) Stream cap: 0x00000001 PCM PCM cap: 0x000a0160 16 24 bits, 44 48 96 KHz Output amp: 0x80016767 mute=1 step=103 size=1 offset=103 Output val: [0x4A 0x4A] nid: 6 [DISABLED] Name: vendor widget Widget cap: 0x00f0001d STEREO Output amp: 0x80017f67 mute=1 step=127 size=1 offset=103 Output val: [0x67 0x67] nid: 7 Name: audio output Widget cap: 0x00000205 DIGITAL STEREO Association: 1 (0x00000001) OSS: pcm (pcm) Stream cap: 0x00000001 PCM PCM cap: 0x000a0160 16 24 bits, 44 48 96 KHz Output amp: 0x80016767 mute=1 step=103 size=1 offset=103 Output val: [0x4A 0x4A] nid: 8 Name: audio input Widget cap: 0x00100103 STEREO Association: 2 (0x00000001) Stream cap: 0x00000001 PCM PCM cap: 0x000a0160 16 24 bits, 44 48 96 KHz Input amp: 0x80017367 mute=1 step=115 size=1 offset=103 Input val: [0x3C 0x3C] connections: 1 enabled 1 | + <- nid=19 [pin: Line-in (Blue Rear)] nid: 9 Name: audio input Widget cap: 0x0010010b STEREO Association: 3 (0x00000001) Stream cap: 0x00000001 PCM PCM cap: 0x000a0160 16 24 bits, 44 48 96 KHz Input amp: 0x80017f67 mute=1 step=127 size=1 offset=103 Input val: [0x2C 0x2C] connections: 1 enabled 1 | + <- nid=20 [pin: Microphone (Pink Front)] nid: 10 [DISABLED] Name: audio input Widget cap: 0x0010011b STEREO Stream cap: 0x00000001 PCM PCM cap: 0x000a0560 16 24 bits, 44 48 96 192 KHz Input amp: 0x80017f67 mute=1 step=127 size=1 offset=103 Input val: [0x67 0x67] connections: 1 enabled 0 | + [DISABLED] <- nid=21 [pin: Line-in (None)] [DISABLED] nid: 11 [DISABLED] Name: audio input Widget cap: 0x0010011b STEREO Stream cap: 0x00000001 PCM PCM cap: 0x000a0560 16 24 bits, 44 48 96 192 KHz Input amp: 0x80017f67 mute=1 step=127 size=1 offset=103 Input val: [0x67 0x67] connections: 1 enabled 0 | + [DISABLED] <- nid=22 [pin: AUX (None)] [DISABLED] nid: 12 Name: audio input Widget cap: 0x00100303 DIGITAL STEREO Association: 4 (0x00000001) Stream cap: 0x00000001 PCM PCM cap: 0x000a0160 16 24 bits, 44 48 96 KHz Input amp: 0x80017367 mute=1 step=115 size=1 offset=103 Input val: [0x08 0x08] connections: 1 enabled 1 | + <- nid=23 [pin: SPDIF-in (Black Rear)] nid: 13 Name: pin: Line-out (Green Rear) Widget cap: 0x00400189 UNSOL STEREO Association: 0 (0x00000001) Pin cap: 0x00000014 PDC OUT Pin config: 0x01014010 Pin control: 0x00000040 OUT connections: 1 enabled 1 | + <- nid=2 [audio output] nid: 14 Name: pin: Line-out (Orange Rear) Widget cap: 0x00400189 UNSOL STEREO Association: 0 (0x00000002) Pin cap: 0x00000014 PDC OUT Pin config: 0x01016011 Pin control: 0x00000040 OUT connections: 1 enabled 1 | + <- nid=3 [audio output] nid: 15 Name: pin: Line-out (Black Rear) Widget cap: 0x00400189 UNSOL STEREO Association: 0 (0x00000004) Pin cap: 0x00000014 PDC OUT Pin config: 0x01011012 Pin control: 0x00000040 OUT connections: 1 enabled 1 | + <- nid=4 [audio output] nid: 16 Name: pin: Line-out (Grey Rear) Widget cap: 0x00400189 UNSOL STEREO Association: 0 (0x00000010) Pin cap: 0x00000014 PDC OUT Pin config: 0x01012014 Pin control: 0x00000040 OUT connections: 1 enabled 1 | + <- nid=5 [audio output] nid: 17 Name: pin: Headphones (Green Front) Widget cap: 0x00400189 UNSOL STEREO Association: 0 (0x00008000) Pin cap: 0x0000001c PDC HP OUT Pin config: 0x0221401f Pin control: 0x000000c0 HP OUT connections: 1 enabled 1 | + <- nid=2 [audio output] nid: 18 Name: pin: SPDIF-out (Grey Rear) Widget cap: 0x00400389 DIGITAL UNSOL STEREO Association: 1 (0x00000001) Pin cap: 0x00000010 OUT Pin config: 0x01452130 Pin control: 0x00000040 OUT connections: 1 enabled 1 | + <- nid=7 [audio output] nid: 19 Name: pin: Line-in (Blue Rear) Widget cap: 0x00400089 UNSOL STEREO Association: 2 (0x00000001) OSS: line (line) Pin cap: 0x00000024 PDC IN Pin config: 0x01813040 Pin control: 0x00000020 IN nid: 20 Name: pin: Microphone (Pink Front) Widget cap: 0x00400089 UNSOL STEREO Association: 3 (0x00000001) OSS: mic (mic) Pin cap: 0x00000024 PDC IN Pin config: 0x02a19050 Pin control: 0x00000020 IN nid: 21 [DISABLED] Name: pin: Line-in (None) Widget cap: 0x0040008b UNSOL STEREO Pin cap: 0x00000026 TRQD PDC IN Pin config: 0x41811060 Pin control: 0x00000000 nid: 22 [DISABLED] Name: pin: AUX (None) Widget cap: 0x0040008b UNSOL STEREO Pin cap: 0x00000026 TRQD PDC IN Pin config: 0x41911070 Pin control: 0x00000000 nid: 23 Name: pin: SPDIF-in (Black Rear) Widget cap: 0x00400289 DIGITAL UNSOL STEREO Association: 4 (0x00000001) OSS: dig1 (dig1) Pin cap: 0x00000020 IN Pin config: 0x01c51180 Pin control: 0x00000020 IN nid: 24 [DISABLED] Name: vendor widget Widget cap: 0x00f00080 UNSOL
brividomortale Posted February 4, 2013 Posted February 4, 2013 Please , I need Help Because if you boot with Clover in UEFI mode the audio suffers the disorder Effect Laser, and if I boot with Chameleon audio is Ok ?
rictec Posted February 28, 2013 Posted February 28, 2013 i have to Thank Cassio for providing that kexts it works on my hp laptop thanks Rictec
rictec Posted February 28, 2013 Posted February 28, 2013 Try this, it's the one I use (2.7.2 already edited)http://www.sendspace.com/file/j2avzz this is the post i read and the file i used it works perfectly on my hp pro book 4320s with ml 10.8.2 thank you Cassio looking for it and only got KP Rictec
dm4n Posted April 24, 2013 Posted April 24, 2013 Hi, I'm using VoodooHDA 2.7.4 on Dell Optiplex 755 running OS X 10.8.3 and GPU is ATI Radeon 5670 Everything seems to be ok- a little crackling using headphones. Not using HDMI. Generally all very good, thanks to devs! Couple of questions- Would it be worthwhile upgrading to latest pkg? And, I haven't removed AppleHDA - is it necessary and what are the options eg complete removal, or I did read about a HDA disable kext? I do get occasional KP's, but usually fine after reboot. Generally very stable system- for about a year now, using Lion then Mountain Lion. Cheers Desktop: OS X 10.14.6 Dell Precision T3500 Xeon 3503 5 * 2GB DDR3 1066MHz RAM ATI Radeon 5670 GPU Samsung EVO 250Gb SSD Laptop: macOS 10.15.7, Dell 7580, intel i7 8565, intel 620 iGPU, Samsung 860 EVO 1tb SSD
garegin Posted July 4, 2013 Posted July 4, 2013 Hi guys. I have a stupid problem. The jack on the macbook has broken so that it forces the output to digital audio. Hardware fixes won't work. Is there a way to hack voodoohda to just disable this devil away! and output it to normal speakers. I know it can be done, but I can't contact the voodoohda devs for help
shasoosh Posted August 2, 2013 Posted August 2, 2013 I got a weird problem using VoodooHDA. I won't hear anything until I'll remove the Orange rear jack from the computer. After some research I've found that My orange and green are on the same line-out and after restart ML detects the orange one what leads me to not hear sound. This is how my Audio devices look like: If i'll push the Orange jack in it will take the green one place : And I won't be able to hear anything. How can I completely disable the orange line-out? (I still want to keep the jack in for my Windows gaming OS) Found a device of class VoodooHDADevice: IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/P0P2@1/IOPCI2PCIBridge/pci10de,e0a@0,1/VoodooHDADevice Probing codec #0... HDA Codec #0: NVidia (Unknown) HDA Codec ID: 0x10de0040 Vendor: 0x10de Device: 0x0040 Revision: 0x01 Stepping: 0x00 PCI Subvendor: 0x36091458 startNode=1 endNode=2 Found audio FG nid=1 startNode=4 endNode=12 total=8 Processing audio FG cad=0 nid=1... Powering up... Parsing audio FG... GPIO: 0x00000000 NumGPIO=0 NumGPO=0 NumGPI=0 GPIWake=0 GPIUnsol=0 nid 4 0x185600f0 as 15 seq 0 Digital-out Jack Digital Special Internal Unknown misc 0 nid 5 0x185600f0 as 15 seq 0 Digital-out Jack Digital Special Internal Unknown misc 0 nid 6 0x185600f0 as 15 seq 0 Digital-out Jack Digital Special Internal Unknown misc 0 nid 7 0x185600f0 as 15 seq 0 Digital-out Jack Digital Special Internal Unknown misc 0 Parsing vendor patch... VHDevice NID= 4 Config=185600f0 (pin: Digital-o) Cap=09000094 Ctrl=00000000 -- Conns: 0=8 1=9 2=10 3=11 VHDevice NID= 5 Config=185600f0 (pin: Digital-o) Cap=09000094 Ctrl=00000000 -- Conns: 0=8 1=9 2=10 3=11 VHDevice NID= 6 Config=185600f0 (pin: Digital-o) Cap=09000094 Ctrl=00000000 -- Conns: 0=8 1=9 2=10 3=11 VHDevice NID= 7 Config=185600f0 (pin: Digital-o) Cap=09000094 Ctrl=00000000 -- Conns: 0=8 1=9 2=10 3=11 VHDevice NID= 8 Config=00000000 (audio output ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID= 9 Config=00000000 (audio output ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=10 Config=00000000 (audio output ) Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=11 Config=00000000 (audio output ) Cap=00000000 Ctrl=00000000 -- Conns: Disabling nonaudio... Disabling useless... Patched pins configuration: nid 4 0x185600f0 as 15 seq 0 Digital-out Jack Digital Special Internal Unknown misc 0 nid 5 0x185600f0 as 15 seq 0 Digital-out Jack Digital Special Internal Unknown misc 0 nid 6 0x185600f0 as 15 seq 0 Digital-out Jack Digital Special Internal Unknown misc 0 nid 7 0x185600f0 as 15 seq 0 Digital-out Jack Digital Special Internal Unknown misc 0 Parsing pin associations... 4 associations found: Association 0 (15) out: Pin nid=4 seq=0 Redir type=-1 jack=0 def=-1 Association 1 (15) out: Pin nid=5 seq=0 Redir type=-1 jack=0 def=-1 Association 2 (15) out: Pin nid=6 seq=0 Redir type=-1 jack=0 def=-1 Association 3 (15) out: Pin nid=7 seq=0 Redir type=-1 jack=0 def=-1 Building AFG tree... Tracing association 0 (15) Tracing pin 4 with min nid 0 tracing via nid 4 tracing via nid 8 nid 8 returned 8 tracing via nid 9 nid 9 returned 9 tracing via nid 10 nid 10 returned 10 tracing via nid 11 nid 11 returned 11 nid 4 returned 8 Pin 4 traced to DAC 8 Association 0 (15) trace succeeded Tracing association 1 (15) Tracing pin 5 with min nid 0 tracing via nid 5 tracing via nid 8 nid 8 busy by association 0 tracing via nid 9 nid 9 returned 9 tracing via nid 10 nid 10 returned 10 tracing via nid 11 nid 11 returned 11 nid 5 returned 9 Pin 5 traced to DAC 9 Association 1 (15) trace succeeded Tracing association 2 (15) Tracing pin 6 with min nid 0 tracing via nid 6 tracing via nid 8 nid 8 busy by association 0 tracing via nid 9 nid 9 busy by association 1 tracing via nid 10 nid 10 returned 10 tracing via nid 11 nid 11 returned 11 nid 6 returned 10 Pin 6 traced to DAC 10 Association 2 (15) trace succeeded Tracing association 3 (15) Tracing pin 7 with min nid 0 tracing via nid 7 tracing via nid 8 nid 8 busy by association 0 tracing via nid 9 nid 9 busy by association 1 tracing via nid 10 nid 10 busy by association 2 tracing via nid 11 nid 11 returned 11 nid 7 returned 11 Pin 7 traced to DAC 11 Association 3 (15) trace succeeded Tracing input monitor Tracing other input monitors Tracing beeper Disabling unassociated widgets... Disabling nonselected inputs... Disabling useless... Disabling crossassociated connections... Disabling useless... Binding associations to channels... Assigning names to signal sources... Parsing Ctls... Assigning mixers to the tree... Preparing pin controls... AFG commit... Creating PCM devices... pcmAttach: HDA NVidia (Unknown) PCM #0 DisplayPort at cad 0 nid 1 +--------------------------------------+ | DUMPING PCM Playback/Record Channels | +--------------------------------------+ Playback: Stream cap: 0x00000005 AC3 PCM PCM cap: 0x000e07f0 16 20 24 bits, 32 44 48 88 96 176 192 KHz DAC: 8 +-------------------------------+ | DUMPING Playback/Record Paths | +-------------------------------+ Playback: nid=4 [pin: Digital-out (HDMI)] | + <- nid=8 [audio output] [src: pcm] bindSeq=00000001 +-------------------------+ | DUMPING Volume Controls | +-------------------------+ OSS mixer initialization... Registering PCM channels... pcmAttach: HDA NVidia (Unknown) PCM #1 DisplayPort at cad 0 nid 1 +--------------------------------------+ | DUMPING PCM Playback/Record Channels | +--------------------------------------+ Playback: Stream cap: 0x00000005 AC3 PCM PCM cap: 0x000e07f0 16 20 24 bits, 32 44 48 88 96 176 192 KHz DAC: 9 +-------------------------------+ | DUMPING Playback/Record Paths | +-------------------------------+ Playback: nid=5 [pin: Digital-out (HDMI)] | + <- nid=9 [audio output] [src: pcm] bindSeq=00000001 +-------------------------+ | DUMPING Volume Controls | +-------------------------+ OSS mixer initialization... Registering PCM channels... pcmAttach: HDA NVidia (Unknown) PCM #2 DisplayPort at cad 0 nid 1 +--------------------------------------+ | DUMPING PCM Playback/Record Channels | +--------------------------------------+ Playback: Stream cap: 0x00000005 AC3 PCM PCM cap: 0x000e07f0 16 20 24 bits, 32 44 48 88 96 176 192 KHz DAC: 10 +-------------------------------+ | DUMPING Playback/Record Paths | +-------------------------------+ Playback: nid=6 [pin: Digital-out (HDMI)] | + <- nid=10 [audio output] [src: pcm] bindSeq=00000001 +-------------------------+ | DUMPING Volume Controls | +-------------------------+ OSS mixer initialization... Registering PCM channels... pcmAttach: HDA NVidia (Unknown) PCM #3 DisplayPort at cad 0 nid 1 +--------------------------------------+ | DUMPING PCM Playback/Record Channels | +--------------------------------------+ Playback: Stream cap: 0x00000005 AC3 PCM PCM cap: 0x000e07f0 16 20 24 bits, 32 44 48 88 96 176 192 KHz DAC: 11 +-------------------------------+ | DUMPING Playback/Record Paths | +-------------------------------+ Playback: nid=7 [pin: Digital-out (HDMI)] | + <- nid=11 [audio output] [src: pcm] bindSeq=00000001 +-------------------------+ | DUMPING Volume Controls | +-------------------------+ OSS mixer initialization... Registering PCM channels... FG config/quirks: forcestereo ivref50 ivref80 ivref100 ivref HP switch init... +-------------------+ | DUMPING HDA NODES | +-------------------+ Default Parameter ----------------- IN amp: 0x00000000 OUT amp: 0x00000000 nid: 4 Name: pin: Digital-out (HDMI) Widget cap: 0x00407381 DIGITAL UNSOL 8CH Association: 0 (0x00000001) Pin cap: 0x09000094 PDC OUT HDMI DP HBR Pin config: 0x185600f0 Pin control: 0x00000040 OUT connections: 4 enabled 1 | + <- nid=8 [audio output] (selected) + [DISABLED] <- nid=9 [audio output] + [DISABLED] <- nid=10 [audio output] + [DISABLED] <- nid=11 [audio output] nid: 5 Name: pin: Digital-out (HDMI) Widget cap: 0x00407381 DIGITAL UNSOL 8CH Association: 1 (0x00000001) Pin cap: 0x09000094 PDC OUT HDMI DP HBR Pin config: 0x185600f0 Pin control: 0x00000040 OUT connections: 4 enabled 1 | + [DISABLED] <- nid=8 [audio output] + <- nid=9 [audio output] (selected) + [DISABLED] <- nid=10 [audio output] + [DISABLED] <- nid=11 [audio output] nid: 6 Name: pin: Digital-out (HDMI) Widget cap: 0x00407381 DIGITAL UNSOL 8CH Association: 2 (0x00000001) Pin cap: 0x09000094 PDC OUT HDMI DP HBR Pin config: 0x185600f0 Pin control: 0x00000040 OUT connections: 4 enabled 1 | + [DISABLED] <- nid=8 [audio output] + [DISABLED] <- nid=9 [audio output] + <- nid=10 [audio output] (selected) + [DISABLED] <- nid=11 [audio output] nid: 7 Name: pin: Digital-out (HDMI) Widget cap: 0x00407381 DIGITAL UNSOL 8CH Association: 3 (0x00000001) Pin cap: 0x09000094 PDC OUT HDMI DP HBR Pin config: 0x185600f0 Pin control: 0x00000040 OUT connections: 4 enabled 1 | + [DISABLED] <- nid=8 [audio output] + [DISABLED] <- nid=9 [audio output] + [DISABLED] <- nid=10 [audio output] + <- nid=11 [audio output] (selected) nid: 8 Name: audio output Widget cap: 0x000062b1 DIGITAL UNSOL STRIPE 8CH Association: 0 (0x00000001) OSS: pcm (pcm) Stream cap: 0x00000005 AC3 PCM PCM cap: 0x000e07f0 16 20 24 bits, 32 44 48 88 96 176 192 KHz nid: 9 Name: audio output Widget cap: 0x000062b1 DIGITAL UNSOL STRIPE 8CH Association: 1 (0x00000001) OSS: pcm (pcm) Stream cap: 0x00000005 AC3 PCM PCM cap: 0x000e07f0 16 20 24 bits, 32 44 48 88 96 176 192 KHz nid: 10 Name: audio output Widget cap: 0x000062b1 DIGITAL UNSOL STRIPE 8CH Association: 2 (0x00000001) OSS: pcm (pcm) Stream cap: 0x00000005 AC3 PCM PCM cap: 0x000e07f0 16 20 24 bits, 32 44 48 88 96 176 192 KHz nid: 11 Name: audio output Widget cap: 0x000062b1 DIGITAL UNSOL STRIPE 8CH Association: 3 (0x00000001) OSS: pcm (pcm) Stream cap: 0x00000005 AC3 PCM PCM cap: 0x000e07f0 16 20 24 bits, 32 44 48 88 96 176 192 KHz logout Thanks
snj12341 Posted August 2, 2013 Posted August 2, 2013 Hi, i have been trying to patch my plist file but i dont know how to edit. I used PlistEdit pro but every time i save it i get error message. I never had any experience editing the files on a mac, only Windows. I know it's works like regedit on windows but i dont know how to use it so can anyone help and edit my file? I will have the necessary files below: Archive.zip
pernacabeluda Posted August 3, 2013 Posted August 3, 2013 I got a weird problem using VoodooHDA. I won't hear anything until I'll remove the Orange rear jack from the computer. After some research I've found that My orange and green are on the same line-out and after restart ML detects the orange one what leads me to not hear sound. Post a codec dump of your motherboard audio, you posted the nVidia HDMI one. Configure IOPCIPrimaryMatch with mobo audio ID, restart and run getDump again. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
dc31 Posted August 12, 2013 Posted August 12, 2013 Hope someone can help me I have a Lenovo G480 NoteBook, I have install osx 10.8.2. I can play the sound via Headphone and Int. speaker. Buy my problem is I need to connect some usb device for my audio out, such as "Matrix USB SPDIF". I have edit the info.plist. I have change and add both of "IOPCIPrimaryMatch" to my Audio Control and my Display Device ID. But when I connect the USB device, If just can show out 3 device in my output session "Speaker, Head phone and Digital Out(HDMI)". At Windows 7, I connect the USB device, It will show out a new speaker device. When I try to use the HDMI cable connect to my TV to play the movie it also haven't any sound out. I have patch my Dsdt use the HDEF method, cause from my start I try to mod the applehda.kext. Now I use the VoodooHDA.kext 2.8.4 Lion PKG, do I need to remove the HDEF in my DSDT file ? I really want to use the USB device, could someone can help me? Info.plist.zip Codec dump .zip
teras Posted September 13, 2013 Posted September 13, 2013 I was updated to 10.8.5 and suddenely my sound card doesn't work any more. I tried to use latest VoodooHDA but the volume is too low. I tried the VoodooHDAEnableHalfVolumeFix but with no luck Attached you will find my dump of my card. Any ideas? dump.txt.zip
win123vn Posted October 14, 2013 Posted October 14, 2013 hi guys I am using ML 10.8.5 and my system is . I have 2 soundcards: one is onboard and another is Omega ht claro plus. I wonder with those sollution, whether I can fix my Omega card? my onboard card is ok now. many thanks
PimentelX86 Posted October 14, 2013 Posted October 14, 2013 Hello. Do you try read the guide? There said Problem: kext doesn't work (usually when there's more than one audio card or the video card has HDMI audio).Solution: use solution 2 for kernel panic problem above. If you want to use both cards, create one entry for each card in IOKitPersonalities. So only follow it. Good Luck!
acik84 Posted October 30, 2013 Posted October 30, 2013 successfully edit info.plist and sound is working, but in order to do that kernel flags -f needed on every boot. I tried installing voodoohda.kext using kext helper and kext beast but there's an error saying voodoohda was not properly installed. tried already chown 775 command/clearing the cache/use kernel cache but nothing works. i edit info.plist outside(desktop), after adding 0x1c208086, overwrite it back inside voodoohda. should i chown info.plist? attach file if someone could fix it. thank guys Installed on mavericks. VoodooHDA.kext.zip
erbas Posted May 30, 2014 Posted May 30, 2014 Oi Amigo vim pedir sua ajuda pois tenho problema de audio da minha placa mãe codec via VT1708s.Estou tentando usar uma saida HDMI da minha placa de video GF 210 mais não injetar HDMI. Estou tentando usar VoodooHDA 2.8.5 para Mavericks mais o som HDMI só funciona 2 segundos e para e esta com atraso.Se poderem mim ajudar por onde começar ficarei grato. Hi Friend come to ask your help because I have problem with my motherboard audio codec via VT1708s.Estou trying to use the HDMI output of my video card GF 210 more misfires HDMI. I'm trying to use VoodooHDA 2.8.5 for Mavericks over HDMI sound only works for 2 seconds and with this atraso.Se can help me where to start I will be grateful.Desculpa my english
Loyd Posted June 26, 2014 Posted June 26, 2014 Hi guys, First off all thanks for this topic ! I installed two days ago VoodooHDA 2.8.5 and since I do not have KP, which is a big change compared to the old VoodooHDA I used! Thank you for the good work! However, since, I'm facing three problems not included in those listed in the first post: The first is that I lost sound systems (eg when a file is copied / deleted, etc. I do not have the usual sounds). How to get them back ? The second problem is that every startup if the speakers (Green Rear) are connected I have a very loud and deafening sound due to default settings of VoodooHDA inputgain who are in their maximum before launching VoodoohdaSetting loader!) How to lower their level of codec ? The last problem is that the internal microphone does not work. How to enable it ? Otherwise everything else is OK! Here are the specifics of my sound card: ALC663 info Codec: Realtek ALC663 Address: 0 Vendor Id: 0x10ec0663 Subsystem Id: 0x104315a7 Revision Id: 0x100002 and this is what I get with getdump: Found a device of class VoodooHDADevice: IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/HDAC@1B/VoodooHDADevice Probing codec #0... HDA Codec #0: Realtek ALC663 HDA Codec ID: 0x10ec0663 Vendor: 0x10ec Device: 0x0663 Revision: 0x00 Stepping: 0x01 PCI Subvendor: 0x14c31043 startNode=1 endNode=2 Found audio FG nid=1 startNode=2 endNode=36 total=34 Processing audio FG cad=0 nid=1... Powering up... Parsing audio FG... GPIO: 0x40000002 NumGPIO=2 NumGPO=0 NumGPI=0 GPIWake=0 GPIUnsol=1 nid 17 0x411111f0 as 15 seq 0 Speaker None jack 1 loc 1 color Black misc 1 nid 18 0x411111f0 as 15 seq 0 Speaker None jack 1 loc 1 color Black misc 1 nid 19 0x411111f0 as 15 seq 0 Speaker None jack 1 loc 1 color Black misc 1 nid 20 0x99130110 as 1 seq 0 Speaker Fixed jack 3 loc 25 color Unknown misc 1 nid 21 0x0121401f as 1 seq 15 Headphones Jack jack 1 loc 1 color Green misc 0 nid 22 0x411111f0 as 15 seq 0 Speaker None jack 1 loc 1 color Black misc 1 nid 23 0x411111f0 as 15 seq 0 Speaker None jack 1 loc 1 color Black misc 1 nid 24 0x01a19840 as 4 seq 0 Microphone Jack jack 1 loc 1 color Pink misc 8 nid 25 0x99a3094f as 4 seq 15 Microphone Fixed jack 3 loc 25 color Unknown misc 9 nid 26 0x411111f0 as 15 seq 0 Speaker None jack 1 loc 1 color Black misc 1 nid 27 0x411111f0 as 15 seq 0 Speaker None jack 1 loc 1 color Black misc 1 nid 29 0x598301f0 as 15 seq 0 Line-in None jack 3 loc 25 color Unknown misc 1 nid 30 0x99430130 as 3 seq 0 SPDIF-out Fixed jack 3 loc 25 color Unknown misc 1 nid 33 0x01211020 as 2 seq 0 Headphones Jack jack 1 loc 1 color Black misc 0 Parsing vendor patch... VHDevice NID=2 Config=00000000 Type=00000000 Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=3 Config=00000000 Type=00000000 Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=4 Config=00000000 Type=00000000 Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=5 Config=00000000 Type=0000000f Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=6 Config=00000000 Type=00000000 Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=7 Config=00000000 Type=0000000f Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=8 Config=00000000 Type=00000001 Cap=00000000 Ctrl=00000000 -- Conns: 0=35 VHDevice NID=9 Config=00000000 Type=00000001 Cap=00000000 Ctrl=00000000 -- Conns: 0=34 VHDevice NID=10 Config=00000000 Type=0000000f Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=11 Config=00000000 Type=00000002 Cap=00000000 Ctrl=00000000 -- Conns: 0=24 1=25 2=26 3=27 4=29 5=20 6=21 7=22 VHDevice NID=12 Config=00000000 Type=00000002 Cap=00000000 Ctrl=00000000 -- Conns: 0=2 1=11 VHDevice NID=13 Config=00000000 Type=00000002 Cap=00000000 Ctrl=00000000 -- Conns: 0=3 1=11 VHDevice NID=14 Config=00000000 Type=00000002 Cap=00000000 Ctrl=00000000 -- Conns: 0=4 1=11 VHDevice NID=15 Config=00000000 Type=00000002 Cap=00000000 Ctrl=00000000 -- Conns: 0=2 1=11 VHDevice NID=16 Config=00000000 Type=00000000 Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=17 Config=411111f0 Type=00000004 Cap=00000010 Ctrl=00000040 -- Conns: 0=16 VHDevice NID=18 Config=411111f0 Type=00000004 Cap=00000020 Ctrl=00000000 -- Conns: VHDevice NID=19 Config=411111f0 Type=00000004 Cap=00000020 Ctrl=00000000 -- Conns: VHDevice NID=20 Config=99130110 Type=00000004 Cap=0001003c Ctrl=00000020 -- Conns: 0=12 1=13 VHDevice NID=21 Config=0121401f Type=00000004 Cap=0001003c Ctrl=00000020 -- Conns: 0=12 1=13 VHDevice NID=22 Config=411111f0 Type=00000004 Cap=00000034 Ctrl=00000020 -- Conns: 0=14 VHDevice NID=23 Config=411111f0 Type=00000004 Cap=00000010 Ctrl=00000000 -- Conns: 0=15 VHDevice NID=24 Config=01a19840 Type=00000004 Cap=00001734 Ctrl=00000020 -- Conns: 0=14 VHDevice NID=25 Config=99a3094f Type=00000004 Cap=0000173c Ctrl=00000020 -- Conns: 0=12 1=13 2=14 VHDevice NID=26 Config=411111f0 Type=00000004 Cap=00001734 Ctrl=00000020 -- Conns: 0=13 VHDevice NID=27 Config=411111f0 Type=00000004 Cap=0000173c Ctrl=00000020 -- Conns: 0=12 1=13 2=14 VHDevice NID=28 Config=00000000 Type=0000000f Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=29 Config=598301f0 Type=00000004 Cap=00000020 Ctrl=00000020 -- Conns: VHDevice NID=30 Config=99430130 Type=00000004 Cap=00000014 Ctrl=00000040 -- Conns: 0=6 VHDevice NID=31 Config=00000000 Type=0000000f Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=32 Config=00000000 Type=0000000f Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=33 Config=01211020 Type=00000004 Cap=0000001c Ctrl=00000000 -- Conns: 0=12 1=13 2=14 VHDevice NID=34 Config=00000000 Type=00000002 Cap=00000000 Ctrl=00000000 -- Conns: 0=24 1=25 2=26 3=27 4=29 5=20 6=21 7=22 8=11 9=18 VHDevice NID=35 Config=00000000 Type=00000002 Cap=00000000 Ctrl=00000000 -- Conns: 0=24 1=25 2=26 3=27 4=29 5=20 6=21 7=22 8=11 9=19 Disabling nonaudio... Disabling useless... Disabling pin nid 17 due to None connectivity. Disabling pin nid 18 due to None connectivity. Disabling pin nid 19 due to None connectivity. Disabling pin nid 22 due to None connectivity. Disabling pin nid 23 due to None connectivity. Disabling pin nid 26 due to None connectivity. Disabling pin nid 27 due to None connectivity. Disabling pin nid 29 due to None connectivity. Disabling nid 11 connection 2 due to disabled child widget. Disabling nid 11 connection 3 due to disabled child widget. Disabling nid 11 connection 4 due to disabled child widget. Disabling nid 11 connection 7 due to disabled child widget. Disabling nid 15 due to all it's consumers disabled. Disabling nid 34 connection 2 due to disabled child widget. Disabling nid 34 connection 3 due to disabled child widget. Disabling nid 34 connection 4 due to disabled child widget. Disabling nid 34 connection 7 due to disabled child widget. Disabling nid 34 connection 9 due to disabled child widget. Disabling nid 35 connection 2 due to disabled child widget. Disabling nid 35 connection 3 due to disabled child widget. Disabling nid 35 connection 4 due to disabled child widget. Disabling nid 35 connection 7 due to disabled child widget. Disabling nid 35 connection 9 due to disabled child widget. Patched pins configuration: nid 17 0x411111f0 as 15 seq 0 Speaker None jack 1 loc 1 color Black misc 1 [DISABLED] nid 18 0x411111f0 as 15 seq 0 Speaker None jack 1 loc 1 color Black misc 1 [DISABLED] nid 19 0x411111f0 as 15 seq 0 Speaker None jack 1 loc 1 color Black misc 1 [DISABLED] nid 20 0x99130110 as 1 seq 0 Speaker Fixed jack 3 loc 25 color Unknown misc 1 nid 21 0x0121401f as 1 seq 15 Headphones Jack jack 1 loc 1 color Green misc 0 nid 22 0x411111f0 as 15 seq 0 Speaker None jack 1 loc 1 color Black misc 1 [DISABLED] nid 23 0x411111f0 as 15 seq 0 Speaker None jack 1 loc 1 color Black misc 1 [DISABLED] nid 24 0x01a19840 as 4 seq 0 Microphone Jack jack 1 loc 1 color Pink misc 8 nid 25 0x99a3094f as 4 seq 15 Microphone Fixed jack 3 loc 25 color Unknown misc 9 nid 26 0x411111f0 as 15 seq 0 Speaker None jack 1 loc 1 color Black misc 1 [DISABLED] nid 27 0x411111f0 as 15 seq 0 Speaker None jack 1 loc 1 color Black misc 1 [DISABLED] nid 29 0x598301f0 as 15 seq 0 Line-in None jack 3 loc 25 color Unknown misc 1 [DISABLED] nid 30 0x99430130 as 3 seq 0 SPDIF-out Fixed jack 3 loc 25 color Unknown misc 1 nid 33 0x01211020 as 2 seq 0 Headphones Jack jack 1 loc 1 color Black misc 0 Parsing pin associations... 4 associations found: Association 0 (1) out: Pin nid=20 seq=0 Pin nid=21 seq=15 Redir type=0 jack=15 def=0 Association 1 (2) out: Pin nid=33 seq=0 Redir type=-1 jack=0 def=0 Association 2 (3) out: Pin nid=30 seq=0 Redir type=-1 jack=-1 def=0 Association 3 (4) in: Pin nid=24 seq=0 Pin nid=25 seq=15 Redir type=0 jack=0 def=15 Building AFG tree... Tracing association 0 (1) Tracing pin 20 with min nid 0 tracing via nid 20 tracing via nid 12 tracing via nid 2 nid 2 returned 2 tracing via nid 11 tracing via nid 24 tracing via nid 25 tracing via nid 20 tracing via nid 21 nid 12 returned 2 tracing via nid 13 tracing via nid 3 nid 3 returned 3 tracing via nid 11 tracing via nid 24 tracing via nid 25 tracing via nid 20 tracing via nid 21 nid 13 returned 3 nid 20 returned 2 Pin 20 traced to DAC 2 Tracing pin 21 with min nid 0 and hpredir 0 tracing via nid 21 tracing via nid 12 tracing via nid 2 nid 2 returned 2 nid 12 returned 2 nid 21 returned 2 Pin 21 traced to DAC 2 and hpredir 0 Association 0 (1) trace succeeded Tracing association 1 (2) Tracing pin 33 with min nid 0 tracing via nid 33 tracing via nid 12 nid 12 busy by association 0 tracing via nid 13 tracing via nid 3 nid 3 returned 3 tracing via nid 11 tracing via nid 24 tracing via nid 25 tracing via nid 20 nid 20 busy by association 0 tracing via nid 21 nid 21 busy by association 0 nid 13 returned 3 tracing via nid 14 tracing via nid 4 nid 4 returned 4 tracing via nid 11 tracing via nid 24 tracing via nid 25 tracing via nid 20 nid 20 busy by association 0 tracing via nid 21 nid 21 busy by association 0 nid 14 returned 4 nid 33 returned 3 Pin 33 traced to DAC 3 Association 1 (2) trace succeeded Tracing association 2 (3) Tracing pin 30 with min nid 0 tracing via nid 30 tracing via nid 6 nid 6 returned 6 nid 30 returned 6 Pin 30 traced to DAC 6 Association 2 (3) trace succeeded Tracing association 3 (4) Tracing pin 24 to ADC 8 tracing via nid 24 tracing via nid 11 tracing via nid 12 nid 12 busy by association 0 tracing via nid 13 nid 13 busy by association 1 tracing via nid 14 tracing via nid 24 nid 24 returned 0 tracing via nid 25 nid 25 returned 0 tracing via nid 33 nid 33 busy by association 1 nid 14 returned 0 tracing via nid 34 tracing via nid 9 nid 9 returned 0 nid 34 returned 0 tracing via nid 35 tracing via nid 8 nid 8 returned 1 nid 35 returned 1 nid 11 returned 1 tracing via nid 34 tracing via nid 9 nid 9 returned 0 nid 34 returned 0 tracing via nid 35 tracing via nid 8 nid 8 returned 1 nid 35 returned 1 nid 24 returned 1 Pin 24 traced to ADC 8 Tracing pin 25 to ADC 8 tracing via nid 25 tracing via nid 11 tracing via nid 12 nid 12 busy by association 0 tracing via nid 13 nid 13 busy by association 1 tracing via nid 14 tracing via nid 24 nid 24 returned 0 tracing via nid 25 nid 25 returned 0 tracing via nid 33 nid 33 busy by association 1 nid 14 returned 0 tracing via nid 34 tracing via nid 9 nid 9 returned 0 nid 34 returned 0 tracing via nid 35 tracing via nid 8 nid 8 returned 1 nid 35 returned 1 nid 11 returned 1 tracing via nid 34 tracing via nid 9 nid 9 returned 0 nid 34 returned 0 tracing via nid 35 tracing via nid 8 nid 8 returned 1 nid 35 returned 1 nid 25 returned 1 Pin 25 traced to ADC 8 Association 3 (4) trace succeeded Tracing input monitor Tracing nid 11 to out tracing via nid 11 tracing via nid 12 nid 12 found output association 0 tracing via nid 13 nid 13 found output association 1 tracing via nid 14 tracing via nid 24 nid 24 busy by input association 3 tracing via nid 25 nid 25 busy by input association 3 tracing via nid 33 nid 33 found output association 1 nid 14 returned 1 tracing via nid 34 tracing via nid 9 nid 9 returned 0 nid 34 returned 0 tracing via nid 35 nid 35 busy by input association 3 nid 11 returned 1 nid 11 is input monitor Tracing nid 35 to out tracing via nid 35 tracing via nid 8 nid 8 busy by input association 3 nid 35 returned 0 Tracing other input monitors Tracing nid 24 to out tracing via nid 24 tracing via nid 11 nid 11 busy by input association 3 tracing via nid 34 tracing via nid 9 nid 9 returned 0 nid 34 returned 0 tracing via nid 35 nid 35 busy by input association 3 nid 24 returned 0 Tracing nid 25 to out tracing via nid 25 tracing via nid 11 nid 11 busy by input association 3 tracing via nid 34 tracing via nid 9 nid 9 returned 0 nid 34 returned 0 tracing via nid 35 nid 35 busy by input association 3 nid 25 returned 0 Tracing beeper Disabling unassociated widgets... Disabling unassociated nid 4. Disabling unassociated nid 5. Disabling unassociated nid 7. Disabling unassociated nid 9. Disabling unassociated nid 10. Disabling unassociated nid 16. Disabling unassociated nid 28. Disabling unassociated nid 31. Disabling unassociated nid 32. Disabling unassociated nid 34. Disabling connection from output pin nid 11 conn 5 cnid 20. Disabling connection from output pin nid 35 conn 5 cnid 20. Disabling connection from output pin nid 11 conn 6 cnid 21. Disabling connection from output pin nid 35 conn 6 cnid 21. Disabling connection to input pin nid 24 conn 0. Disabling connection to input pin nid 25 conn 0. Disabling connection to input pin nid 25 conn 1. Disabling connection to input pin nid 25 conn 2. Disabling nonselected inputs... Disabling unselected connection nid 20 conn 1. Disabling unselected connection nid 21 conn 1. Disabling unselected connection nid 33 conn 0. Disabling unselected connection nid 33 conn 2. Disabling useless... Disabling nid 14 connection 0 due to disabled child widget. Disabling nid 14 due to all it's consumers disabled. Disabling crossassociated connections... Disabling useless... Binding associations to channels... Assigning names to signal sources... Parsing Ctls... Ctl overflow! Assigning mixers to the tree... Preparing pin controls... AFG commit... Creating PCM devices... pcmAttach: HDA Realtek ALC663 PCM #0 Analog at cad 0 nid 1 +--------------------------------------+ | DUMPING PCM Playback/Record Channels | +--------------------------------------+ Playback: Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz DAC: 2 Record: Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz ADC: 8 +-------------------------------+ | DUMPING Playback/Record Paths | +-------------------------------+ Playback: nid=20 [pin: Speaker (ATAPI)] | + <- nid=12 [audio mixer] nid=21 [pin: Headphones (Green Rear)] | + <- nid=12 [audio mixer] Record: nid=8 [audio input] | + <- nid=35 [audio mixer] [src: mix] bindSeq=00008001 | + <- nid=24 [pin: Microphone (Pink Rear)] [src: mic] bindSeq=00000001 + <- nid=25 [pin: Microphone (ATAPI)] [src: monitor] bindSeq=00008000 + <- nid=11 [audio mixer] Input Mix: nid=35 [audio mixer] | + <- nid=24 [pin: Microphone (Pink Rear)] [src: mic] bindSeq=00000001 + <- nid=25 [pin: Microphone (ATAPI)] [src: monitor] bindSeq=00008000 + <- nid=11 [audio mixer] +-------------------------+ | DUMPING Volume Controls | +-------------------------+ Master Volume (OSS: vol) | +- control 1 (nid 2 out): dir - out oss: vol, pcm -64/+0dB (65 steps) +- control 8 (nid 12 in 0): dir - out oss: vol, pcm mute +- control 9 (nid 12 in 1): dir - out oss: vol, igain mute +- control 12 (nid 20 out): dir - out oss: vol mute +- control 13 (nid 21 out): dir - out oss: vol mute PCM Volume (OSS: pcm) | +- control 1 (nid 2 out): dir - out oss: vol, pcm -64/+0dB (65 steps) +- control 8 (nid 12 in 0): dir - out oss: vol, pcm mute Microphone Volume (OSS: mic) | +- control 15 (nid 24 in 0): dir - in oss: mic +0/+30dB (4 steps) +- control 19 (nid 35 in 0): dir - in oss: mic, rec mute Microphone2 Volume (OSS: monitor) | +- control 17 (nid 25 in 0): dir - in oss: monitor +0/+30dB (4 steps) +- control 20 (nid 35 in 1): dir - in oss: rec, monitor mute Recording Level (OSS: rec) | +- control 3 (nid 8 in 0): dir - in oss: mix, rec -16/+30dB (32 steps) + mute +- control 19 (nid 35 in 0): dir - in oss: mic, rec mute +- control 20 (nid 35 in 1): dir - in oss: rec, monitor mute +- control 23 (nid 35 in 8): dir - in oss: rec mute Input Mix Level (OSS: mix) | +- control 3 (nid 8 in 0): dir - in oss: mix, rec -16/+30dB (32 steps) + mute Input Monitoring Level (OSS: igain) | +- control 4 (nid 11 in 0): dir - in oss: igain -34/+12dB (32 steps) + mute +- control 5 (nid 11 in 1): dir - in oss: igain -34/+12dB (32 steps) + mute +- control 9 (nid 12 in 1): dir - out oss: vol, igain mute OSS mixer initialization... Registering PCM channels... pcmAttach: HDA Realtek ALC663 PCM #1 Analog at cad 0 nid 1 +--------------------------------------+ | DUMPING PCM Playback/Record Channels | +--------------------------------------+ Playback: Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz DAC: 3 +-------------------------------+ | DUMPING Playback/Record Paths | +-------------------------------+ Playback: nid=33 [pin: Headphones (Black Rear)] | + <- nid=13 [audio mixer] +-------------------------+ | DUMPING Volume Controls | +-------------------------+ Master Volume (OSS: vol) | +- control 2 (nid 3 out): dir - out oss: vol, pcm -64/+0dB (65 steps) +- control 10 (nid 13 in 0): dir - out oss: vol, pcm mute +- control 11 (nid 13 in 1): dir - out oss: vol, igain mute +- control 18 (nid 33 out): dir - out oss: vol mute PCM Volume (OSS: pcm) | +- control 2 (nid 3 out): dir - out oss: vol, pcm -64/+0dB (65 steps) +- control 10 (nid 13 in 0): dir - out oss: vol, pcm mute Input Monitoring Level (OSS: igain) | +- control 11 (nid 13 in 1): dir - out oss: vol, igain mute OSS mixer initialization... Registering PCM channels... pcmAttach: HDA Realtek ALC663 PCM #2 Digital at cad 0 nid 1 +--------------------------------------+ | DUMPING PCM Playback/Record Channels | +--------------------------------------+ Playback: Stream cap: 0x00000005 AC3 PCM PCM cap: 0x000e05e0 16 20 24 bits, 44 48 88 96 192 KHz DAC: 6 +-------------------------------+ | DUMPING Playback/Record Paths | +-------------------------------+ Playback: nid=30 [pin: SPDIF-out (ATAPI)] | + <- nid=6 [audio output] [src: pcm] bindSeq=00000001 +-------------------------+ | DUMPING Volume Controls | +-------------------------+ OSS mixer initialization... Registering PCM channels... FG config/quirks: forcestereo ivref50 ivref80 ivref100 ivref HP switch init... +-------------------+ | DUMPING HDA NODES | +-------------------+ Default Parameter ----------------- Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz IN amp: 0x00000000 OUT amp: 0x00000000 nid: 2 Name: audio output Widget cap: 0x0000041d PWR STEREO Association: 0 (0x00008001) OSS: pcm (pcm) Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz Output amp: 0x00034040 mute=0 step=64 size=3 offset=64 Output val: [0x2E 0x2E] nid: 3 Name: audio output Widget cap: 0x0000041d PWR STEREO Association: 1 (0x00000001) OSS: pcm (pcm) Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz Output amp: 0x00034040 mute=0 step=64 size=3 offset=64 Output val: [0x2E 0x2E] nid: 4 [DISABLED] Name: audio output Widget cap: 0x0000041d PWR STEREO Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz Output amp: 0x00034040 mute=0 step=64 size=3 offset=64 Output val: [0x40 0x40] nid: 5 [DISABLED] Name: vendor widget Widget cap: 0x00f00000 nid: 6 Name: audio output Widget cap: 0x00000611 PWR DIGITAL STEREO Association: 2 (0x00000001) OSS: pcm (pcm) Stream cap: 0x00000001 PCM PCM cap: 0x000e05e0 16 20 24 bits, 44 48 88 96 192 KHz nid: 7 [DISABLED] Name: vendor widget Widget cap: 0x00f00000 nid: 8 Name: audio input Widget cap: 0x0010051b PWR STEREO Association: 3 (0x00008001) Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz Input amp: 0x80051f0b mute=1 step=31 size=5 offset=11 Input val: [0x80 0x80] connections: 1 enabled 1 | + <- nid=35 [audio mixer] nid: 9 [DISABLED] Name: audio input Widget cap: 0x0010051b PWR STEREO Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz Input amp: 0x80051f0b mute=1 step=31 size=5 offset=11 Input val: [0x8B 0x8B] connections: 1 enabled 1 | + <- nid=34 [audio mixer] [DISABLED] nid: 10 [DISABLED] Name: vendor widget Widget cap: 0x00f00000 nid: 11 Name: audio mixer Widget cap: 0x0020010b STEREO Association: 3 (0x00008001) OSS: (igain) Input amp: 0x80051f17 mute=1 step=31 size=5 offset=23 Input val: [0x1C 0x1C] [0x1C 0x1C] [0x97 0x97] [0x97 0x97] [0x97 0x97] [0x17 0x17] [0x17 0x17] [0x97 0x97] connections: 8 enabled 2 | + <- nid=24 [pin: Microphone (Pink Rear)] + <- nid=25 [pin: Microphone (ATAPI)] + [DISABLED] <- nid=26 [pin: Speaker (None)] [DISABLED] + [DISABLED] <- nid=27 [pin: Speaker (None)] [DISABLED] + [DISABLED] <- nid=29 [pin: Line-in (ATAPI)] [DISABLED] + [DISABLED] <- nid=20 [pin: Speaker (ATAPI)] + [DISABLED] <- nid=21 [pin: Headphones (Green Rear)] + [DISABLED] <- nid=22 [pin: Speaker (None)] [DISABLED] nid: 12 Name: audio mixer Widget cap: 0x0020010b STEREO Association: 0 (0x00008001) OSS: (igain) Input amp: 0x80000000 mute=1 step=0 size=0 offset=0 Input val: [0x00 0x00] [0x00 0x00] connections: 2 enabled 2 | + <- nid=2 [audio output] + <- nid=11 [audio mixer] nid: 13 Name: audio mixer Widget cap: 0x0020010b STEREO Association: 1 (0x00000001) OSS: (igain) Input amp: 0x80000000 mute=1 step=0 size=0 offset=0 Input val: [0x00 0x00] [0x00 0x00] connections: 2 enabled 2 | + <- nid=3 [audio output] + <- nid=11 [audio mixer] nid: 14 [DISABLED] Name: audio mixer Widget cap: 0x0020010b STEREO Association: -2 (0x00000000) Input amp: 0x80000000 mute=1 step=0 size=0 offset=0 Input val: [0x00 0x00] [0x80 0x80] connections: 2 enabled 1 | + [DISABLED] <- nid=4 [audio output] [DISABLED] + <- nid=11 [audio mixer] nid: 15 [DISABLED] Name: audio mixer Widget cap: 0x0020010a Input amp: 0x80000000 mute=1 step=0 size=0 offset=0 Input val: [0x00 0x00] [0x80 0x80] connections: 2 enabled 2 | + <- nid=2 [audio output] + <- nid=11 [audio mixer] nid: 16 [DISABLED] Name: audio output Widget cap: 0x00000611 PWR DIGITAL STEREO Stream cap: 0x00000001 PCM PCM cap: 0x000e05e0 16 20 24 bits, 44 48 88 96 192 KHz nid: 17 [DISABLED] Name: pin: Speaker (None) Widget cap: 0x00400700 PWR DIGITAL Pin cap: 0x00000010 OUT Pin config: 0x411111f0 Pin control: 0x00000000 connections: 1 enabled 1 | + <- nid=16 [audio output] [DISABLED] nid: 18 [DISABLED] Name: pin: Speaker (None) Widget cap: 0x00400401 PWR STEREO Pin cap: 0x00000020 IN Pin config: 0x411111f0 Pin control: 0x00000000 nid: 19 [DISABLED] Name: pin: Speaker (None) Widget cap: 0x00400401 PWR STEREO Pin cap: 0x00000020 IN Pin config: 0x411111f0 Pin control: 0x00000000 nid: 20 Name: pin: Speaker (ATAPI) Widget cap: 0x0040058d PWR UNSOL STEREO Association: 0 (0x00000001) Pin cap: 0x0001003c PDC HP OUT IN EAPD Pin config: 0x99130110 Pin control: 0x00000040 OUT EAPD: 0x00000002 Output amp: 0x80000000 mute=1 step=0 size=0 offset=0 Output val: [0x00 0x00] connections: 2 enabled 1 | + <- nid=12 [audio mixer] (selected) + [DISABLED] <- nid=13 [audio mixer] nid: 21 Name: pin: Headphones (Green Rear) Widget cap: 0x0040058d PWR UNSOL STEREO Association: 0 (0x00008000) Pin cap: 0x0001003c PDC HP OUT IN EAPD Pin config: 0x0121401f Pin control: 0x000000c0 HP OUT EAPD: 0x00000002 Output amp: 0x80000000 mute=1 step=0 size=0 offset=0 Output val: [0x00 0x00] connections: 2 enabled 1 | + <- nid=12 [audio mixer] (selected) + [DISABLED] <- nid=13 [audio mixer] nid: 22 [DISABLED] Name: pin: Speaker (None) Widget cap: 0x0040058d PWR UNSOL STEREO Pin cap: 0x00000034 PDC OUT IN Pin config: 0x411111f0 Pin control: 0x00000000 Output amp: 0x80000000 mute=1 step=0 size=0 offset=0 Output val: [0x80 0x80] connections: 1 enabled 1 | + <- nid=14 [audio mixer] [DISABLED] nid: 23 [DISABLED] Name: pin: Speaker (None) Widget cap: 0x0040050c PWR Pin cap: 0x00000010 OUT Pin config: 0x411111f0 Pin control: 0x00000000 Output amp: 0x80000000 mute=1 step=0 size=0 offset=0 Output val: [0x80 0x80] connections: 1 enabled 1 | + <- nid=15 [audio mixer] [DISABLED] nid: 24 Name: pin: Microphone (Pink Rear) Widget cap: 0x0040058f PWR UNSOL STEREO Association: 3 (0x00000001) OSS: mic (mic) Pin cap: 0x00001734 PDC OUT IN VREF[ 50 80 GROUND HIZ ] Pin config: 0x01a19840 Pin control: 0x00000024 IN VREFs Output amp: 0x80000000 mute=1 step=0 size=0 offset=0 Output val: [0x00 0x00] Input amp: 0x00270300 mute=0 step=3 size=39 offset=0 Input val: [0x02 0x02] connections: 1 enabled 0 | + [DISABLED] <- nid=14 [audio mixer] [DISABLED] nid: 25 Name: pin: Microphone (ATAPI) Widget cap: 0x0040058f PWR UNSOL STEREO Association: 3 (0x00008000) OSS: monitor (monitor) Pin cap: 0x0000173c PDC HP OUT IN VREF[ 50 80 GROUND HIZ ] Pin config: 0x99a3094f Pin control: 0x00000024 IN VREFs Output amp: 0x80000000 mute=1 step=0 size=0 offset=0 Output val: [0x00 0x00] Input amp: 0x00270300 mute=0 step=3 size=39 offset=0 Input val: [0x02 0x02] [0x00 0x00] [0x00 0x00] connections: 3 enabled 0 | + [DISABLED] <- nid=12 [audio mixer] (selected) + [DISABLED] <- nid=13 [audio mixer] + [DISABLED] <- nid=14 [audio mixer] [DISABLED] nid: 26 [DISABLED] Name: pin: Speaker (None) Widget cap: 0x0040058f PWR UNSOL STEREO Pin cap: 0x00001734 PDC OUT IN VREF[ 50 80 GROUND HIZ ] Pin config: 0x411111f0 Pin control: 0x00000000 Output amp: 0x80000000 mute=1 step=0 size=0 offset=0 Output val: [0x80 0x80] Input amp: 0x00270300 mute=0 step=3 size=39 offset=0 Input val: [0x00 0x00] connections: 1 enabled 1 | + <- nid=13 [audio mixer] nid: 27 [DISABLED] Name: pin: Speaker (None) Widget cap: 0x0040058f PWR UNSOL STEREO Pin cap: 0x0000173c PDC HP OUT IN VREF[ 50 80 GROUND HIZ ] Pin config: 0x411111f0 Pin control: 0x00000000 Output amp: 0x80000000 mute=1 step=0 size=0 offset=0 Output val: [0x80 0x80] Input amp: 0x00270300 mute=0 step=3 size=39 offset=0 Input val: [0x00 0x00] [0x00 0x00] [0x00 0x00] connections: 3 enabled 3 | + <- nid=12 [audio mixer] (selected) + <- nid=13 [audio mixer] + <- nid=14 [audio mixer] [DISABLED] nid: 28 [DISABLED] Name: vendor widget Widget cap: 0x00f00000 nid: 29 [DISABLED] Name: pin: Line-in (ATAPI) Widget cap: 0x00400400 PWR Pin cap: 0x00000020 IN Pin config: 0x598301f0 Pin control: 0x00000000 nid: 30 Name: pin: SPDIF-out (ATAPI) Widget cap: 0x00400780 PWR DIGITAL UNSOL Association: 2 (0x00000001) Pin cap: 0x00000014 PDC OUT Pin config: 0x99430130 Pin control: 0x00000040 OUT connections: 1 enabled 1 | + <- nid=6 [audio output] nid: 31 [DISABLED] Name: vendor widget Widget cap: 0x00f00000 nid: 32 [DISABLED] Name: vendor widget Widget cap: 0x00f00040 PROC nid: 33 Name: pin: Headphones (Black Rear) Widget cap: 0x0040058d PWR UNSOL STEREO Association: 1 (0x00000001) Pin cap: 0x0000001c PDC HP OUT Pin config: 0x01211020 Pin control: 0x000000c0 HP OUT Output amp: 0x80000000 mute=1 step=0 size=0 offset=0 Output val: [0x00 0x00] connections: 3 enabled 1 | + [DISABLED] <- nid=12 [audio mixer] + <- nid=13 [audio mixer] (selected) + [DISABLED] <- nid=14 [audio mixer] [DISABLED] nid: 34 [DISABLED] Name: audio mixer Widget cap: 0x0020010b STEREO Input amp: 0x80000000 mute=1 step=0 size=0 offset=0 Input val: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] connections: 10 enabled 5 | + <- nid=24 [pin: Microphone (Pink Rear)] + <- nid=25 [pin: Microphone (ATAPI)] + [DISABLED] <- nid=26 [pin: Speaker (None)] [DISABLED] + [DISABLED] <- nid=27 [pin: Speaker (None)] [DISABLED] + [DISABLED] <- nid=29 [pin: Line-in (ATAPI)] [DISABLED] + <- nid=20 [pin: Speaker (ATAPI)] + <- nid=21 [pin: Headphones (Green Rear)] + [DISABLED] <- nid=22 [pin: Speaker (None)] [DISABLED] + <- nid=11 [audio mixer] + [DISABLED] <- nid=18 [pin: Speaker (None)] [DISABLED] nid: 35 Name: audio mixer Widget cap: 0x0020010b STEREO Association: 3 (0x00008001) OSS: mix (mix) Input amp: 0x80000000 mute=1 step=0 size=0 offset=0 Input val: [0x00 0x00] [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x00 0x00] [0x00 0x00] [0x80 0x80] [0x00 0x00] [0x80 0x80] connections: 10 enabled 3 | + <- nid=24 [pin: Microphone (Pink Rear)] + <- nid=25 [pin: Microphone (ATAPI)] + [DISABLED] <- nid=26 [pin: Speaker (None)] [DISABLED] + [DISABLED] <- nid=27 [pin: Speaker (None)] [DISABLED] + [DISABLED] <- nid=29 [pin: Line-in (ATAPI)] [DISABLED] + [DISABLED] <- nid=20 [pin: Speaker (ATAPI)] + [DISABLED] <- nid=21 [pin: Headphones (Green Rear)] + [DISABLED] <- nid=22 [pin: Speaker (None)] [DISABLED] + <- nid=11 [audio mixer] + [DISABLED] <- nid=19 [pin: Speaker (None)] [DISABLED] Probing codec #1... HDA Codec #1: Lucent/Agere Systems (Unknown) HDA Codec ID: 0x11c11040 Vendor: 0x11c1 Device: 0x1040 Revision: 0x02 Stepping: 0x00 PCI Subvendor: 0x14c31043 startNode=1 endNode=2 Found modem FG nid=1 startNode=2 endNode=127 total=125 Processing modem FG cad=1 nid=1... Powering down... Probing codec #2... HDA Codec #2: NVidia MCP78 HDMI HDA Codec ID: 0x10de0006 Vendor: 0x10de Device: 0x0006 Revision: 0x00 Stepping: 0x00 PCI Subvendor: 0x14c31043 startNode=1 endNode=2 Found audio FG nid=1 startNode=4 endNode=14 total=10 Processing audio FG cad=2 nid=1... Powering up... Parsing audio FG... GPIO: 0x00000000 NumGPIO=0 NumGPO=0 NumGPI=0 GPIWake=0 GPIUnsol=0 nid 5 0x18560110 as 1 seq 0 Digital-out Jack jack 6 loc 24 color Unknown misc 1 nid 7 0x58560121 as 2 seq 1 Digital-out None jack 6 loc 24 color Unknown misc 1 nid 9 0x58560122 as 2 seq 2 Digital-out None jack 6 loc 24 color Unknown misc 1 nid 11 0x58560123 as 2 seq 3 Digital-out None jack 6 loc 24 color Unknown misc 1 nid 13 0x58560124 as 2 seq 4 Digital-out None jack 6 loc 24 color Unknown misc 1 Parsing vendor patch... VHDevice NID=4 Config=00000000 Type=00000000 Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=5 Config=18560110 Type=00000004 Cap=00000014 Ctrl=00000000 -- Conns: 0=4 VHDevice NID=6 Config=00000000 Type=00000000 Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=7 Config=58560121 Type=00000004 Cap=00000014 Ctrl=00000000 -- Conns: 0=6 VHDevice NID=8 Config=00000000 Type=00000000 Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=9 Config=58560122 Type=00000004 Cap=00000014 Ctrl=00000000 -- Conns: 0=8 VHDevice NID=10 Config=00000000 Type=00000000 Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=11 Config=58560123 Type=00000004 Cap=00000014 Ctrl=00000000 -- Conns: 0=10 VHDevice NID=12 Config=00000000 Type=00000000 Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=13 Config=58560124 Type=00000004 Cap=00000014 Ctrl=00000000 -- Conns: 0=12 Disabling nonaudio... Disabling useless... Disabling pin nid 7 due to None connectivity. Disabling pin nid 9 due to None connectivity. Disabling pin nid 11 due to None connectivity. Disabling pin nid 13 due to None connectivity. Patched pins configuration: nid 5 0x18560110 as 1 seq 0 Digital-out Jack jack 6 loc 24 color Unknown misc 1 nid 7 0x58560121 as 2 seq 1 Digital-out None jack 6 loc 24 color Unknown misc 1 [DISABLED] nid 9 0x58560122 as 2 seq 2 Digital-out None jack 6 loc 24 color Unknown misc 1 [DISABLED] nid 11 0x58560123 as 2 seq 3 Digital-out None jack 6 loc 24 color Unknown misc 1 [DISABLED] nid 13 0x58560124 as 2 seq 4 Digital-out None jack 6 loc 24 color Unknown misc 1 [DISABLED] Parsing pin associations... 1 associations found: Association 0 (1) out: Pin nid=5 seq=0 Redir type=-1 jack=-1 def=0 Building AFG tree... Tracing association 0 (1) Tracing pin 5 with min nid 0 tracing via nid 5 tracing via nid 4 nid 4 returned 4 nid 5 returned 4 Pin 5 traced to DAC 4 Association 0 (1) trace succeeded Tracing input monitor Tracing other input monitors Tracing beeper Disabling unassociated widgets... Disabling unassociated nid 6. Disabling unassociated nid 8. Disabling unassociated nid 10. Disabling unassociated nid 12. Disabling nonselected inputs... Disabling useless... Disabling crossassociated connections... Disabling useless... Binding associations to channels... Assigning names to signal sources... Parsing Ctls... Assigning mixers to the tree... Preparing pin controls... AFG commit... Creating PCM devices... pcmAttach: HDA NVidia MCP78 HDMI PCM #0 Digital at cad 2 nid 1 +--------------------------------------+ | DUMPING PCM Playback/Record Channels | +--------------------------------------+ Playback: Stream cap: 0x00000005 AC3 PCM PCM cap: 0x000f00c0 8 16 20 24 bits, 48 88 KHz DAC: 4 +-------------------------------+ | DUMPING Playback/Record Paths | +-------------------------------+ Playback: nid=5 [pin: Digital-out (HDMI)] | + <- nid=4 [audio output] [src: pcm] bindSeq=00000001 +-------------------------+ | DUMPING Volume Controls | +-------------------------+ OSS mixer initialization... Registering PCM channels... FG config/quirks: forcestereo ivref50 ivref80 ivref100 ivref HP switch init... +-------------------+ | DUMPING HDA NODES | +-------------------+ Default Parameter ----------------- IN amp: 0x00000000 OUT amp: 0x00000000 nid: 4 Name: audio output Widget cap: 0x00000211 DIGITAL STEREO Association: 0 (0x00000001) OSS: pcm (pcm) Stream cap: 0x00000001 PCM PCM cap: 0x000f00c0 8 16 20 24 bits, 48 88 KHz nid: 5 Name: pin: Digital-out (HDMI) Widget cap: 0x00400381 DIGITAL UNSOL STEREO Association: 0 (0x00000001) Pin cap: 0x00000014 PDC OUT Pin config: 0x18560110 Pin control: 0x00000040 OUT connections: 1 enabled 1 | + <- nid=4 [audio output] nid: 6 [DISABLED] Name: audio output Widget cap: 0x00000211 DIGITAL STEREO Stream cap: 0x00000001 PCM PCM cap: 0x000f00c0 8 16 20 24 bits, 48 88 KHz nid: 7 [DISABLED] Name: pin: Digital-out (HDMI) Widget cap: 0x00400381 DIGITAL UNSOL STEREO Pin cap: 0x00000014 PDC OUT Pin config: 0x58560121 Pin control: 0x00000000 connections: 1 enabled 1 | + <- nid=6 [audio output] [DISABLED] nid: 8 [DISABLED] Name: audio output Widget cap: 0x00000211 DIGITAL STEREO Stream cap: 0x00000001 PCM PCM cap: 0x000f00c0 8 16 20 24 bits, 48 88 KHz nid: 9 [DISABLED] Name: pin: Digital-out (HDMI) Widget cap: 0x00400381 DIGITAL UNSOL STEREO Pin cap: 0x00000014 PDC OUT Pin config: 0x58560122 Pin control: 0x00000000 connections: 1 enabled 1 | + <- nid=8 [audio output] [DISABLED] nid: 10 [DISABLED] Name: audio output Widget cap: 0x00000211 DIGITAL STEREO Stream cap: 0x00000001 PCM PCM cap: 0x000f00c0 8 16 20 24 bits, 48 88 KHz nid: 11 [DISABLED] Name: pin: Digital-out (HDMI) Widget cap: 0x00400381 DIGITAL UNSOL STEREO Pin cap: 0x00000014 PDC OUT Pin config: 0x58560123 Pin control: 0x00000000 connections: 1 enabled 1 | + <- nid=10 [audio output] [DISABLED] nid: 12 [DISABLED] Name: audio output Widget cap: 0x00000211 DIGITAL STEREO Stream cap: 0x00000001 PCM PCM cap: 0x000f00c0 8 16 20 24 bits, 48 88 KHz nid: 13 [DISABLED] Name: pin: Digital-out (HDMI) Widget cap: 0x00400381 DIGITAL UNSOL STEREO Pin cap: 0x00000014 PDC OUT Pin config: 0x58560124 Pin control: 0x00000000 connections: 1 enabled 1 | + <- nid=12 [audio output] [DISABLED] Great thanks in advance for any help on these three points
pernacabeluda Posted June 27, 2014 Posted June 27, 2014 Edit Info.plist and set MixerValues instead of using VoodooHdaSettingsLoader. Try this and check if mic works <key>NodesToPatch</key> <array> <dict> <key>Codec</key> <integer>0</integer> <key>Config</key> <string>0x99a30950</string> <key>Node</key> <integer>25</integer> </dict> </array> -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Loyd Posted June 27, 2014 Posted June 27, 2014 Great thanks ! I Manage to overcome the problem of the very loud sound at start up, using your suggestion ! For the mic, I can not insert your code snippet in plist. I always get an error when I want to save. I knew how to do it before with VoodooHDA 2.8.2 but with 2.8.5 no success. Here is my plist before : <?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> <plist version="1.0"> <dict> <key>BuildMachineOSBuild</key> <string>13C64</string> <key>CFBundleDevelopmentRegion</key> <string>English</string> <key>CFBundleExecutable</key> <string>VoodooHDA</string> <key>CFBundleIdentifier</key> <string>org.voodoo.driver.VoodooHDA</string> <key>CFBundleInfoDictionaryVersion</key> <string>6.0</string> <key>CFBundleName</key> <string>VoodooHDA</string> <key>CFBundlePackageType</key> <string>KEXT</string> <key>CFBundleShortVersionString</key> <string>2.8.5</string> <key>CFBundleSignature</key> <string>????</string> <key>CFBundleVersion</key> <string>2.8.5</string> <key>DTCompiler</key> <string>com.apple.compilers.llvm.clang.1_0</string> <key>DTPlatformBuild</key> <string>5A2053</string> <key>DTPlatformVersion</key> <string>GM</string> <key>DTSDKBuild</key> <string>13A595</string> <key>DTSDKName</key> <string>macosx10.9</string> <key>DTXcode</key> <string>0501</string> <key>DTXcodeBuild</key> <string>5A2053</string> <key>IOKitPersonalities</key> <dict> <key>VoodooHDA</key> <dict> <key>CFBundleIdentifier</key> <string>org.voodoo.driver.VoodooHDA</string> <key>IOClass</key> <string>VoodooHDADevice</string> <key>IOMatchCategory</key> <string>VoodooHDADevice</string> <key>IOPCIClassMatch</key> <string>0x04020000&0xfffe0000</string> <key>IOProviderClass</key> <string>IOPCIDevice</string> <key>IOUserClientClass</key> <string>VoodooHDAUserClient</string> <key>InhibitCache</key> <true/> <key>MixerValues</key> <dict> <key>PCM</key> <string>90</string> <key>Rec</key> <string>70</string> <key>iGain</key> <string>10</string> <key>iMix</key> <string>0</string> </dict> <key>NodesToPatch</key> <array/> <key>Noise</key> <integer>0</integer> <key>Vectorize</key> <false/> <key>VoodooHDAEnableHalfMicVolumeFix</key> <true/> <key>VoodooHDAEnableHalfVolumeFix</key> <false/> <key>VoodooHDAEnableMuteFix</key> <false/> <key>VoodooHDAEnableVolumeChangeFix</key> <false/> <key>VoodooHDAVerboseLevel</key> <integer>0</integer> </dict> </dict> <key>OSBundleLibraries</key> <dict> <key>com.apple.iokit.IOAudioFamily</key> <string>1.1fc9</string> <key>com.apple.iokit.IOPCIFamily</key> <string>2.1</string> <key>com.apple.kpi.iokit</key> <string>9.0.0</string> <key>com.apple.kpi.libkern</key> <string>9.0.0</string> <key>com.apple.kpi.mach</key> <string>9.0.0</string> <key>com.apple.kpi.unsupported</key> <string>9.0.0</string> </dict> </dict> </plist> and my plist when I insert the code snippet: <?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> <plist version="1.0"> <dict> <key>BuildMachineOSBuild</key> <string>13C64</string> <key>CFBundleDevelopmentRegion</key> <string>English</string> <key>CFBundleExecutable</key> <string>VoodooHDA</string> <key>CFBundleIdentifier</key> <string>org.voodoo.driver.VoodooHDA</string> <key>CFBundleInfoDictionaryVersion</key> <string>6.0</string> <key>CFBundleName</key> <string>VoodooHDA</string> <key>CFBundlePackageType</key> <string>KEXT</string> <key>CFBundleShortVersionString</key> <string>2.8.5</string> <key>CFBundleSignature</key> <string>????</string> <key>CFBundleVersion</key> <string>2.8.5</string> <key>DTCompiler</key> <string>com.apple.compilers.llvm.clang.1_0</string> <key>DTPlatformBuild</key> <string>5A2053</string> <key>DTPlatformVersion</key> <string>GM</string> <key>DTSDKBuild</key> <string>13A595</string> <key>DTSDKName</key> <string>macosx10.9</string> <key>DTXcode</key> <string>0501</string> <key>DTXcodeBuild</key> <string>5A2053</string> <key>IOKitPersonalities</key> <dict> <key>VoodooHDA</key> <dict> <key>CFBundleIdentifier</key> <string>org.voodoo.driver.VoodooHDA</string> <key>IOClass</key> <string>VoodooHDADevice</string> <key>IOMatchCategory</key> <string>VoodooHDADevice</string> <key>IOPCIClassMatch</key> <string>0x04020000&0xfffe0000</string> <key>IOProviderClass</key> <string>IOPCIDevice</string> <key>IOUserClientClass</key> <string>VoodooHDAUserClient</string> <key>InhibitCache</key> <true/> <key>MixerValues</key> <dict> <key>PCM</key> <string>90</string> <key>Rec</key> <string>70</string> <key>iGain</key> <string>10</string> <key>iMix</key> <string>0</string> </dict> <key>NodesToPatch</key> <array> <dict> <key>Codec</key> <integer>0</integer> <key>Config</key> <string>0x99a30950</string> <key>Node</key> <integer>25</integer> </dict> </array> <key>Noise</key> <integer>0</integer> <key>Vectorize</key> <false/> <key>VoodooHDAEnableHalfMicVolumeFix</key> <true/> <key>VoodooHDAEnableHalfVolumeFix</key> <false/> <key>VoodooHDAEnableMuteFix</key> <false/> <key>VoodooHDAEnableVolumeChangeFix</key> <false/> <key>VoodooHDAVerboseLevel</key> <integer>0</integer> </dict> </dict> <key>OSBundleLibraries</key> <dict> <key>com.apple.iokit.IOAudioFamily</key> <string>1.1fc9</string> <key>com.apple.iokit.IOPCIFamily</key> <string>2.1</string> <key>com.apple.kpi.iokit</key> <string>9.0.0</string> <key>com.apple.kpi.libkern</key> <string>9.0.0</string> <key>com.apple.kpi.mach</key> <string>9.0.0</string> <key>com.apple.kpi.unsupported</key> <string>9.0.0</string> </dict> </dict> </plist> I am missing something ? Thanks again for your time.
pernacabeluda Posted June 28, 2014 Posted June 28, 2014 I can't see an error there. About the mic issue, try playing with Mic and iMix values in prefPane. Maybe you need to change Monitor value instead of iGain to get rid of the loud sound problem (probably audio feedback?). -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
erbas Posted June 28, 2014 Posted June 28, 2014 I can't see an error there. About the mic issue, try playing with Mic and iMix values in prefPane. Maybe you need to change Monitor value instead of iGain to get rid of the loud sound problem (probably audio feedback?). Leg maybe that's the problem Codec key> Is not in the correct position should be more or less well below the y
