oldnapalm Posted September 13, 2011 Share Posted September 13, 2011 Official thread: http://www.projectosx.com/forum/index.php?showtopic=355 Download: http://sourceforge.net/projects/voodoohda/files/ Problem: kernel panic. Solution 1: remove AppleHDA and restart the system before installing VoodooHDA (or use AppleHDADisabler). Solution 2: edit Info.plist, replace the key IOPCIClassMatch by IOPCIPrimaryMatch and put the PCI ID of your audio card in string. Before <key>IOPCIClassMatch</key> <string>0x04030000&0xffff0000</string> After <key>IOPCIPrimaryMatch</key> <string>0x3b568086</string> 0xDeviceIDVendorID Problem: kext doesn't work (usually when there's more than one audio card or the video card has HDMI audio). Solution: use solution 2 for kernel panic problem above. If you want to use both cards, create one entry for each card in IOKitPersonalities. Problem: sound crackles. Solution 1: change output format in Applications - Utilities - Audio MIDI Setup Solution 2: check "Use SSE2" in VoodooHDA prefPane You can also enable Vectorize in Info.plist <key>Vectorize</key> <true/> Problem: volume control (slider) doesn't work. Solution: enable VoodooHDAEnableVolumeChangeFix in Info.plist <key>VoodooHDAEnableVolumeChangeFix</key> <true/> Problem: volume too low. Solution: enable VoodooHDAEnableHalfVolumeFix in Info.plist <key>VoodooHDAEnableHalfVolumeFix</key> <true/> Problem: audio feedback (Larsen effect), sound loop between input (microphone) and output (speakers). Solution: mute iGain and increase iMix or Mic if microphone dosn't work <key>iGain</key> <string>0</string> It can also be done in the prefPane. In some cases you may need to mute Monitor instead of iGain. Problem: audio delay. If you change volume, for example, it takes 1 or 2 seconds to play the test sound. Solution 1: delete com.apple.audio.DeviceSettings.plist and com.apple.audio.SystemSettings.plist from /Library/Preferences/Audio and reboot. Solution 2: use SoundFlower. Problem: inputs or outputs don't show in sound preferences. Solution 1: look for a kext patched for your codec. For VT1708S http://www.insanelymac.com/forum/index.php?showtopic=231508 For AD1988B http://www.insanelymac.com/forum/index.php?showtopic=267898 Solution 2: add NodesToPatch basead on getDump output (download in official thread). Example <key>NodesToPatch</key> <array> <dict> <key>Codec</key> <integer>2</integer> <key>Config</key> <string>0x90a70120</string> <key>Node</key> <integer>12</integer> </dict> </array> Config (PinDefault) is made up of the last 2 digits of each codec verb, but in the opposite order 0x[color=#FF0000]01[/color][color=#008000]01[/color][color=#0000FF]44[/color][color=#8000FF]10[/color] = 21471c[color=#8000FF]10[/color] 21471d[color=#0000FF]44[/color] 21471e[color=#008000]01[/color] 21471f[color=#FF0000]01[/color] |||||||+- [color=#8000FF]Sequence[/color] ||||||+-- [color=#8000FF]Default Association[/color] |||||+--- [color=#0000FF]Misc[/color] ||||+---- [color=#0000FF]Color[/color] |||+----- [color=#008000]Connection Type[/color] ||+------ [color=#008000]Default Device[/color] |+------- [color=#FF0000]Location[/color] +-------- [color=#FF0000]Port Connectivity[/color] More detailed example http://Olarila.com/forum/viewtopic.php?f=18&t=604 Info about codec verbs Source: http://www.projectosx.com/forum/index.php?showtopic=465 For each input/output there is a sequence of 4 verbs. Jack Color Description Node PinDefault Original Verbs -------------------------------------------------------------------------------------------------------- 1/8 Green Line Out at Ext Rear 20 0x14 0x01014410 21471c10 21471d44 21471e01 21471f01 Its about NodeID(NID) 0x14 in hex, 20 in decimal. The default verbs for it: 21471c10 21471d44 21471e01 21471f01 CAd (Codec Adress)NID (NodeID)Verb CommandVerb Data 71cXY X=Default Association Y=Sequence Default Association and Sequence are used together by software to group Pin Complexes (and therefore jacks) together into functional blocks to support multichannel operation. Software may assume that all jacks with the same association number are intended to be grouped together, for instance to provide six channel analog output. The Default Association can also be used by software to prioritize resource allocation in constrained situations. Lower Default Association values would be higher in priority for resources such as processing nodes or Input and Output Converters. Note that this is the default association only, and software can override this value if required, in particular if the user provides additional information about the particular system configuration. A value of 0000b is reserved and should not be used. Software may interpret this value to indicate that the Pin Configuration data has not been properly initialized. A value of 1111b is a special value indicating that the Association has the lowest priority. Multiple different Pin Complexes may share this value, and each is intended to be exposed as independent devices. Sequence indicates the order of the jacks in the association group. The lowest numbered jack in the association group should be assigned the lowest numbered channels in the stream, etc. The numbers need not be sequential within the group, only the order matters. Sequence numbers within a set of Default Associations must be unique. *My notes for this, if you look on the vanilla codec verb(no matter what codec) you will see that Sequence is always 0. Why that, and why for us on our codec verbs is different? Simple b/c Apple dosen't have multichannel analog out! so you must change it to 0. *About Default Association, Keep the default one, in order, and on those that are the same replace them with new one that dosen't exist already in the dump... the values you can use are: 1, 2, 3, 4, 5, 6, 7, 8, 9, a, b, c, d and f.(see what does verbit if you still don't understand) 71dXY X=Color Y=Misc Color indicates the color of the physical jack for use by software. Unknown 0 Black 1 Grey 2 Blue 3 Green 4 Red 5 Orange 6 Yellow 7 Purple 8 Pink 9 Reserved A-D White E Other F Misc is a bit field used to indicate other information about the jack. Currently, only bit 0 is defined. If bit 0 is set, it indicates that the jack has no presence detect capability, so even if a Pin Complex indicates that the codec hardware supports the presence detect functionality on the jack, the external circuitry is not capable of supporting the functionality. Reserved 3 Reserved 2 Reserved 1 Jack Detect Override 0 *Use 0 for Jack Detect - External Device(e.g. Headphones Mic etc) Use 1 for Jack Detect Disabled - Internal Device(e.g. Internal speakers, Internal mic) 71eXY X=Default Device Y=Connection Type Default Device indicates the intended use of the jack or device. This can indicate either the label on the jack or the device that is hardwired to the port, as with integrated speakers and the like. Line Out 0 Speaker 1 HP Out 2 CD 3 SPDIF Out 4 Digital Other Out 5 Modem Line Side 6 Modem Handset Side 7 Line In 8 AUX 9 Mic In A Telephony B SPDIF In C Digital Other In D Reserved E Other F Connection Type indicates the type of physical connection, such as a 1/8-inch stereo jack or an optical digital connector, etc. Software can use this information to provide helpful user interface descriptions to the user or to modify reported codec capabilities based on the capabilities of the physical transport external to the codec. Unknown 0 1/8" stereo/mono 1 1/4" stereo/mono 2 ATAPI internal 3 RCA 4 Optical 5 Other Digital 6 Other Analog 7 Multichannel Analog (DIN) 8 XLR/Professional 9 RJ-11 (Modem) A Combination B Other F 71fXY X=Port Connectivity Y=Location Port Connectivity indicates the external connectivity of the Pin Complex. Software can use this value to know what Pin Complexes are connected to jacks, internal devices, or not connected at all. 00b - The Port Complex is connected to a jack (1/8", ATAPI, etc.). 01b - No physical connection for Port. 10b - A fixed function device (integrated speaker, integrated mic, etc.) is attached. 11b - Both a jack and an internal device are attached. The Information provided in all other fields refers to the integrated device. The PD pin will reflect the status of the jack; the user will need to be queried to figure out what it is. Location indicates the physical location of the jack or device to which the pin complex is connected. This allows software to indicate, for instance, that the device is the “Front Panel Headphone Jack” as opposed to rear panel connections. *Details: Convert the 2 digit hex number to binary. Pad the front with zero's to make it 8 dgits. Example: 0x02 = binary 10 = 00000010 8 digit binary Reading the bits from left to right: Port Connectivity bits 7:6 ----------------------------------------------------------- 00 - Port is connected to a Jack 01 - No External Port -or- No physical connection for Port 10 - Fixed Function/Built In Device (integrated speaker, mic, etc) 11 - Jack and Internal device are attached Location Part 1 - bits 5:4 ----------------------------------------------------------- 00 - External on primary chassis 01 - Internal 10 - Separate chassis 11 - Other Location Part 2 - bits 3:0 ----------------------------------------------------------- The meaning depends on Location Part 1 00 0000 N/A 00 0001 Rear 00 0010 Front 00 0011 Left 00 0100 Right 00 0101 Top 00 0110 Bottom 00 0111 Special (Rear panel) 00 1000 Special (Drive bay) 01 0000 N/A 01 0111 Special (Riser) 01 1000 HDMI 01 1001 ATAPI 10 0000 N/A 10 0001 Rear 10 0010 Front 10 0011 Left 10 0100 Right 10 0101 Top 10 0110 Bottom 11 0000 N/A 11 0110 ? 11 0111 Inside Mobile Lid (example: mic) 11 1000 Outside Mobile Lid Bits Hex 76 54 3210 ------------------- 71f01 = 00 00 0001 - Port has a jack - It is External - Rear Location 71f02 = 00 00 0010 - Port has a jack - It is External - Front Panel Location 71f59 = 01 01 1001 - No External Port - ATAPI 71f18 = 00 01 1000 - Port has a jack - External - HDMI 71f90 = 10 01 0000 - Built In Device - Internal - N/A | | |||| | | |--------- Location part 2 | |------------ Location part 1 |--------------- Port Connectivity Link to comment Share on other sites More sharing options...
frantisek.nesveda Posted September 14, 2011 Share Posted September 14, 2011 If you want to use both cards, create one entry for each card in IOKitPersonalities. Hi, how exactly should one have two entries? Am I doing it right? <key>IOKitPersonalities</key> <dict> <key>VoodooHDA</key> <dict> ... <key>IOPCIPrimaryMatch</key> <string>0x1c208086</string> ... </dict> </dict> <dict> <key>VoodooHDA 2</key> <dict> ... <key>IOPCIPrimaryMatch</key> <string>0x01268086</string> ... </dict> </dict> Link to comment Share on other sites More sharing options...
oldnapalm Posted September 14, 2011 Author Share Posted September 14, 2011 Yes, that's it. There's a complete example in the official thread (trick 4) IOKitPersonalities SoundCard CFBundleIdentifier org.voodoo.driver.VoodooHDA IOClass VoodooHDADevice IOMatchCategory VoodooHDADevice [color=#ff0000][b]IOPCIPrimaryMatch 0x284b8086 -- place here deviceID of your sound card (Chipset HDA device, not a codecID!)[/b][/color] IOProviderClass IOPCIDevice IOUserClientClass VoodooHDAUserClient NodesToPatch VoodooHDAVerboseLevel 1 HDMI CFBundleIdentifier org.voodoo.driver.VoodooHDA IOClass VoodooHDADevice IOMatchCategory VoodooHDADevice [color=#ff0000][b]IOPCIPrimaryMatch 0x033f1002 -- place here deviceID of your HDMI device on video card[/b][/color] IOProviderClass IOPCIDevice IOUserClientClass VoodooHDAUserClient NodesToPatch VoodooHDAVerboseLevel 1 Link to comment Share on other sites More sharing options...
cafeamr Posted January 29, 2012 Share Posted January 29, 2012 guys microphone not working why i use snow leopard and voodoohda 0.2.2 my motherboard is GA-G41MT-S2P rev1.3 GIGABYTE - Motherboard - Socket 775 - GA-G41MT-S2P (rev. 1.3) http://www.gigabyte.com/products/product-page.aspx?pid=3743#sp my sound onboard VIA VT2021 this video i make it to see wt happen testing mic - YouTube http://www.youtube.com/watch?v=R-p70LbhmrM&list=UU3uNHIp8f350yxX79b48lRA&index=1&feature=plcp plz eny one help me plz i need mic to make course web design Link to comment Share on other sites More sharing options...
Cassio Posted January 29, 2012 Share Posted January 29, 2012 Use newer VoodooHDA and post a getDump. -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
Zambo27 Posted January 31, 2012 Share Posted January 31, 2012 hi guys, i really need your help to get my alc269 work on lion 10.7.2 i have tried a lot of different kext and at last i've read this guide, i have the same id vendor and the other id but again it don't want to work i have a acer aspire timelinex 5820tg, intel i3 350m, 4gb ddr3, hd5470m, alc269(intel high definition audio) lion work very well, it don't work fine with battery(use it but don't show how much energy left) no multitouch and no audio what can i try if also put my alc's id in the kext doesn't work? Link to comment Share on other sites More sharing options...
Cassio Posted January 31, 2012 Share Posted January 31, 2012 It's not the ALC (codec) ID you have to put in the kext, but the PCI ID. Show what you changed in the plist. -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
Zambo27 Posted February 1, 2012 Share Posted February 1, 2012 <?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> <plist version="1.0"> <dict> <key>BuildMachineOSBuild</key> <string>11A511</string> <key>CFBundleDevelopmentRegion</key> <string>English</string> <key>CFBundleExecutable</key> <string>VoodooHDA</string> <key>CFBundleIdentifier</key> <string>org.voodoo.driver.VoodooHDA</string> <key>CFBundleInfoDictionaryVersion</key> <string>6.0</string> <key>CFBundleName</key> <string>VoodooHDA</string> <key>CFBundlePackageType</key> <string>KEXT</string> <key>CFBundleShortVersionString</key> <string>2.7.3</string> <key>CFBundleSignature</key> <string>????</string> <key>CFBundleVersion</key> <string>2.7.3</string> <key>DTCompiler</key> <string>4.2</string> <key>DTPlatformBuild</key> <string>4B110</string> <key>DTPlatformVersion</key> <string>GM</string> <key>DTSDKBuild</key> <string>10J567</string> <key>DTSDKName</key> <string>macosx10.6</string> <key>DTXcode</key> <string>0410</string> <key>DTXcodeBuild</key> <string>4B110</string> <key>IOKitPersonalities</key> <dict> <key>VoodooHDA</key> <dict> <key>CFBundleIdentifier</key> <string>org.voodoo.driver.VoodooHDA</string> <key>IOClass</key> <string>VoodooHDADevice</string> <key>IOMatchCategory</key> <string>VoodooHDADevice</string> <key>IOPCIPrimaryMatch</key> <string>0x3b568086</string> <key>IOProviderClass</key> <string>IOPCIDevice</string> <key>IOUserClientClass</key> <string>VoodooHDAUserClient</string> <key>InhibitCache</key> <true/> <key>MixerValues</key> <dict> <key>iGain</key> <string>90</string> <key>iMix</key> <string>0</string> </dict> <key>NodesToPatch</key> <array/> <key>Noise</key> <integer>2</integer> <key>Vectorize</key> <false/> <key>VoodooHDAEnableHalfMicVolumeFix</key> <false/> <key>VoodooHDAEnableHalfVolumeFix</key> <false/> <key>VoodooHDAEnableMuteFix</key> <false/> <key>VoodooHDAEnableVolumeChangeFix</key> <false/> <key>VoodooHDAVerboseLevel</key> <integer>0</integer> </dict> </dict> <key>OSBundleLibraries</key> <dict> <key>com.apple.iokit.IOAudioFamily</key> <string>1.1fc9</string> <key>com.apple.iokit.IOPCIFamily</key> <string>2.1</string> <key>com.apple.kpi.iokit</key> <string>9.0.0</string> <key>com.apple.kpi.libkern</key> <string>9.0.0</string> <key>com.apple.kpi.mach</key> <string>9.0.0</string> <key>com.apple.kpi.unsupported</key> <string>9.0.0</string> </dict> </dict> </plist> this is the plist, i have modified only this <key>IOPCIPrimaryMatch</key> <string>0x3b568086</string> like it is showed in this guide, i have the same ID edit: i have tried different PCI ID but it didn't work, wich one i have to use? in the jpeg file, you can see all the ID, you can tell me wich one i have to put in info.plist? (the "blue" one is the alc269) Link to comment Share on other sites More sharing options...
Cassio Posted February 1, 2012 Share Posted February 1, 2012 You did it right, it should work. Please post a getDump. -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
Zambo27 Posted February 1, 2012 Share Posted February 1, 2012 mmh.... what is "getDump"? xD Last login: Wed Feb 1 16:04:25 on console Macbook-Pro-di-Daniele:~ Daniele$ /Users/Daniele/Downloads/getdump ; exit; error: IORegistryEntryGetPath returned 0x10000003 logout [Processo completato] ok searched on google and founded a program, hope it is the right one Link to comment Share on other sites More sharing options...
Cassio Posted February 1, 2012 Share Posted February 1, 2012 VoodooHDA must be loaded before you run getdump. Remove AppleHDA, install VoodooHDA, reboot, then run getdump. -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
Zambo27 Posted February 1, 2012 Share Posted February 1, 2012 no applehda, reinstalled voodoohda with champlist, caches rebuilded, permission repaired with disk utility, reboot and get the same message with getdump maybe champlist fails with voodoohda? with all the other kext work very well Link to comment Share on other sites More sharing options...
Cassio Posted February 1, 2012 Share Posted February 1, 2012 Never used it. Try Kext Wizard, install to /S/L/E. -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
Zambo27 Posted February 1, 2012 Share Posted February 1, 2012 same output, but it enable multitouch O_O Link to comment Share on other sites More sharing options...
Cassio Posted February 1, 2012 Share Posted February 1, 2012 Try loading it via terminal sudo kextload /System/Library/Extensions/VoodooHDA.kext If it fails, use kextutil instead of kextload and post output. -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
Zambo27 Posted February 1, 2012 Share Posted February 1, 2012 /System/Library/Extensions/VoodooHDA.kext - no dependency found for com.apple.iokit.IOAudioFamily. /System/Library/Extensions/VoodooHDA.kext - no dependency found for com.apple.iokit.IOAudioFamily. /System/Library/Extensions/VoodooHDA.kext - no dependency found for com.apple.iokit.IOAudioFamily. Diagnostics for /System/Library/Extensions/VoodooHDA.kext: Dependency Resolution Failures: No kexts found for these libraries: com.apple.iokit.IOAudioFamily from kextutil Link to comment Share on other sites More sharing options...
Cassio Posted February 1, 2012 Share Posted February 1, 2012 You need IOAudioFamily.kext, you must have deleted it somehow, re-install it. -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
Zambo27 Posted February 1, 2012 Share Posted February 1, 2012 founded and installed, now my pc is trying to talk xD, but i can hear only a noise now i will try with untouched voodoohda, maybe it do nothing but i will try Link to comment Share on other sites More sharing options...
Cassio Posted February 1, 2012 Share Posted February 1, 2012 Read first post, there are some things you can do to fix it. -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
Zambo27 Posted February 1, 2012 Share Posted February 1, 2012 ok noise erased with voodoohda panel, input gain at minimun, but there is no sound and it don't save that modification here the getdump if can help Found a device of class VoodooHDADevice: IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/HDEF@1B/VoodooHDADevice Probing codec #0... HDA Codec #0: Realtek ALC269 HDA Codec ID: 0x10ec0269 Vendor: 0x10ec Device: 0x0269 Revision: 0x01 Stepping: 0x00 PCI Subvendor: 0x035d1025 startNode=1 endNode=2 Found audio FG nid=1 startNode=2 endNode=36 total=34 Processing audio FG cad=0 nid=1... Powering up... Parsing audio FG... GPIO: 0x40000002 NumGPIO=2 NumGPO=0 NumGPI=0 GPIWake=0 GPIUnsol=1 nid 18 0x99a30930 as 3 seq 0 Microphone Fixed jack 3 loc 25 color Unknown misc 9 nid 20 0x99130110 as 1 seq 0 Speaker Fixed jack 3 loc 25 color Unknown misc 1 nid 23 0x411111f0 as 15 seq 0 Speaker None jack 1 loc 1 color Black misc 1 nid 24 0x03a19840 as 4 seq 0 Microphone Jack jack 1 loc 3 color Pink misc 8 nid 25 0x411111f0 as 15 seq 0 Speaker None jack 1 loc 1 color Black misc 1 nid 26 0x411111f0 as 15 seq 0 Speaker None jack 1 loc 1 color Black misc 1 nid 27 0x411111f0 as 15 seq 0 Speaker None jack 1 loc 1 color Black misc 1 nid 29 0x4017992d as 2 seq 13 Speaker None jack 7 loc 0 color Pink misc 9 nid 30 0x03451120 as 2 seq 0 SPDIF-out Jack jack 5 loc 3 color Black misc 1 nid 33 0x0321101f as 1 seq 15 Headphones Jack jack 1 loc 3 color Black misc 0 Parsing vendor patch... VHDevice NID=2 Config=00000000 Type=00000000 Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=3 Config=00000000 Type=00000000 Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=4 Config=00000000 Type=0000000f Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=5 Config=00000000 Type=0000000f Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=6 Config=00000000 Type=00000000 Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=7 Config=00000000 Type=0000000f Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=8 Config=00000000 Type=00000001 Cap=00000000 Ctrl=00000000 -- Conns: 0=35 VHDevice NID=9 Config=00000000 Type=00000001 Cap=00000000 Ctrl=00000000 -- Conns: 0=34 VHDevice NID=10 Config=00000000 Type=0000000f Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=11 Config=00000000 Type=00000002 Cap=00000000 Ctrl=00000000 -- Conns: 0=24 1=25 2=26 3=27 4=29 VHDevice NID=12 Config=00000000 Type=00000002 Cap=00000000 Ctrl=00000000 -- Conns: 0=2 1=11 VHDevice NID=13 Config=00000000 Type=00000002 Cap=00000000 Ctrl=00000000 -- Conns: 0=3 1=11 VHDevice NID=14 Config=00000000 Type=0000000f Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=15 Config=00000000 Type=00000002 Cap=00000000 Ctrl=00000000 -- Conns: 0=2 1=11 VHDevice NID=16 Config=00000000 Type=0000000f Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=17 Config=00000000 Type=0000000f Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=18 Config=99a30930 Type=00000004 Cap=00000020 Ctrl=00000000 -- Conns: VHDevice NID=19 Config=00000000 Type=0000000f Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=20 Config=99130110 Type=00000004 Cap=00010014 Ctrl=00000000 -- Conns: 0=12 1=13 VHDevice NID=21 Config=00000000 Type=0000000f Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=22 Config=00000000 Type=0000000f Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=23 Config=411111f0 Type=00000004 Cap=00000010 Ctrl=00000000 -- Conns: 0=15 VHDevice NID=24 Config=03a19840 Type=00000004 Cap=00001734 Ctrl=00000020 -- Conns: 0=13 VHDevice NID=25 Config=411111f0 Type=00000004 Cap=00001724 Ctrl=00000020 -- Conns: VHDevice NID=26 Config=411111f0 Type=00000004 Cap=0000003c Ctrl=00000020 -- Conns: 0=12 1=13 VHDevice NID=27 Config=411111f0 Type=00000004 Cap=00000034 Ctrl=00000020 -- Conns: 0=12 1=13 VHDevice NID=28 Config=00000000 Type=0000000f Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=29 Config=4017992d Type=00000004 Cap=00000020 Ctrl=00000020 -- Conns: VHDevice NID=30 Config=03451120 Type=00000004 Cap=00000014 Ctrl=00000040 -- Conns: 0=6 VHDevice NID=31 Config=00000000 Type=0000000f Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=32 Config=00000000 Type=0000000f Cap=00000000 Ctrl=00000000 -- Conns: VHDevice NID=33 Config=0321101f Type=00000004 Cap=0000001c Ctrl=00000000 -- Conns: 0=12 1=13 VHDevice NID=34 Config=00000000 Type=00000003 Cap=00000000 Ctrl=00000000 -- Conns: 0=24 1=25 2=26 3=27 4=29 5=11 6=18 VHDevice NID=35 Config=00000000 Type=00000002 Cap=00000000 Ctrl=00000000 -- Conns: 0=24 1=25 2=26 3=27 4=29 5=11 Disabling nonaudio... Disabling useless... Disabling pin nid 23 due to None connectivity. Disabling pin nid 25 due to None connectivity. Disabling pin nid 26 due to None connectivity. Disabling pin nid 27 due to None connectivity. Disabling pin nid 29 due to None connectivity. Disabling nid 11 connection 1 due to disabled child widget. Disabling nid 11 connection 2 due to disabled child widget. Disabling nid 11 connection 3 due to disabled child widget. Disabling nid 11 connection 4 due to disabled child widget. Disabling nid 15 due to all it's consumers disabled. Disabling nid 34 connection 1 due to disabled child widget. Disabling nid 34 connection 2 due to disabled child widget. Disabling nid 34 connection 3 due to disabled child widget. Disabling nid 34 connection 4 due to disabled child widget. Disabling nid 35 connection 1 due to disabled child widget. Disabling nid 35 connection 2 due to disabled child widget. Disabling nid 35 connection 3 due to disabled child widget. Disabling nid 35 connection 4 due to disabled child widget. Patched pins configuration: nid 18 0x99a30930 as 3 seq 0 Microphone Fixed jack 3 loc 25 color Unknown misc 9 nid 20 0x99130110 as 1 seq 0 Speaker Fixed jack 3 loc 25 color Unknown misc 1 nid 23 0x411111f0 as 15 seq 0 Speaker None jack 1 loc 1 color Black misc 1 [DISABLED] nid 24 0x03a19840 as 4 seq 0 Microphone Jack jack 1 loc 3 color Pink misc 8 nid 25 0x411111f0 as 15 seq 0 Speaker None jack 1 loc 1 color Black misc 1 [DISABLED] nid 26 0x411111f0 as 15 seq 0 Speaker None jack 1 loc 1 color Black misc 1 [DISABLED] nid 27 0x411111f0 as 15 seq 0 Speaker None jack 1 loc 1 color Black misc 1 [DISABLED] nid 29 0x4017992d as 2 seq 13 Speaker None jack 7 loc 0 color Pink misc 9 [DISABLED] nid 30 0x03451120 as 2 seq 0 SPDIF-out Jack jack 5 loc 3 color Black misc 1 nid 33 0x0321101f as 1 seq 15 Headphones Jack jack 1 loc 3 color Black misc 0 Parsing pin associations... 4 associations found: Association 0 (1) out: Pin nid=20 seq=0 Pin nid=33 seq=15 Redir type=0 jack=15 def=0 Association 1 (2) out: Pin nid=30 seq=0 Redir type=-1 jack=-1 def=0 Association 2 (3) in: Pin nid=18 seq=0 Redir type=-1 jack=-1 def=0 Association 3 (4) in: Pin nid=24 seq=0 Redir type=-1 jack=0 def=0 Building AFG tree... Tracing association 0 (1) Tracing pin 20 with min nid 0 tracing via nid 20 tracing via nid 12 tracing via nid 2 nid 2 returned 2 tracing via nid 11 tracing via nid 24 nid 12 returned 2 tracing via nid 13 tracing via nid 3 nid 3 returned 3 tracing via nid 11 tracing via nid 24 nid 13 returned 3 nid 20 returned 2 Pin 20 traced to DAC 2 Tracing pin 33 with min nid 0 and hpredir 0 tracing via nid 33 tracing via nid 12 tracing via nid 2 nid 2 returned 2 nid 12 returned 2 nid 33 returned 2 Pin 33 traced to DAC 2 and hpredir 0 Association 0 (1) trace succeeded Tracing association 1 (2) Tracing pin 30 with min nid 0 tracing via nid 30 tracing via nid 6 nid 6 returned 6 nid 30 returned 6 Pin 30 traced to DAC 6 Association 1 (2) trace succeeded Tracing association 2 (3) Tracing pin 18 to ADC 8 tracing via nid 18 tracing via nid 34 tracing via nid 9 nid 9 returned 0 nid 34 returned 0 nid 18 returned 0 Unable to trace pin 18 to ADC 8, undo traces Tracing pin 18 to ADC 9 tracing via nid 18 tracing via nid 34 tracing via nid 9 nid 9 returned 1 nid 34 returned 1 nid 18 returned 1 Pin 18 traced to ADC 9 Association 2 (3) trace succeeded Tracing association 3 (4) Tracing pin 24 to ADC 8 tracing via nid 24 tracing via nid 11 tracing via nid 12 nid 12 busy by association 0 tracing via nid 13 tracing via nid 20 nid 20 busy by association 0 tracing via nid 24 nid 24 returned 0 tracing via nid 33 nid 33 busy by association 0 nid 13 returned 0 tracing via nid 34 nid 34 busy by association 2 tracing via nid 35 tracing via nid 8 nid 8 returned 1 nid 35 returned 1 nid 11 returned 1 tracing via nid 34 nid 34 busy by association 2 tracing via nid 35 tracing via nid 8 nid 8 returned 1 nid 35 returned 1 nid 24 returned 1 Pin 24 traced to ADC 8 Association 3 (4) trace succeeded Tracing input monitor Tracing nid 11 to out tracing via nid 11 tracing via nid 12 nid 12 found output association 0 tracing via nid 13 tracing via nid 20 nid 20 found output association 0 tracing via nid 24 nid 24 busy by input association 3 tracing via nid 33 nid 33 found output association 0 nid 13 returned 1 tracing via nid 34 nid 34 busy by input association 2 tracing via nid 35 nid 35 busy by input association 3 nid 11 returned 1 nid 11 is input monitor Tracing nid 35 to out tracing via nid 35 tracing via nid 8 nid 8 busy by input association 3 nid 35 returned 0 Tracing other input monitors Tracing nid 18 to out tracing via nid 18 tracing via nid 34 nid 34 busy by input association 2 nid 18 returned 0 Tracing nid 24 to out tracing via nid 24 tracing via nid 11 nid 11 busy by input association 3 tracing via nid 34 nid 34 busy by input association 2 tracing via nid 35 nid 35 busy by input association 3 nid 24 returned 0 Tracing beeper Disabling unassociated widgets... Disabling unassociated nid 3. Disabling unassociated nid 4. Disabling unassociated nid 5. Disabling unassociated nid 7. Disabling unassociated nid 10. Disabling unassociated nid 14. Disabling unassociated nid 16. Disabling unassociated nid 17. Disabling unassociated nid 19. Disabling unassociated nid 21. Disabling unassociated nid 22. Disabling unassociated nid 28. Disabling unassociated nid 31. Disabling unassociated nid 32. Disabling connection to input pin nid 24 conn 0. Disabling nonselected inputs... Disabling unselected connection nid 20 conn 1. Disabling unselected connection nid 33 conn 1. Disabling useless... Disabling nid 13 connection 0 due to disabled child widget. Disabling nid 13 due to all it's consumers disabled. Disabling crossassociated connections... Disabling crossassociated connection nid 34 conn 0 cnid 24. Disabling crossassociated connection nid 34 conn 5 cnid 11. Disabling useless... Binding associations to channels... Assigning names to signal sources... Parsing Ctls... Assigning mixers to the tree... Preparing pin controls... AFG commit... GPIO init: data=0x00000000 mask=0x00000000 dir=0x00000000 GPIO commit: data=0x00000001 mask=0x00000001 dir=0x00000001 Creating PCM devices... pcmAttach: HDA Realtek ALC269 PCM #0 Analog at cad 0 nid 1 +--------------------------------------+ | DUMPING PCM Playback/Record Channels | +--------------------------------------+ Playback: Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz DAC: 2 Record: Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz ADC: 9 +-------------------------------+ | DUMPING Playback/Record Paths | +-------------------------------+ Playback: nid=20 [pin: Speaker (ATAPI)] | + <- nid=12 [audio mixer] nid=33 [pin: Headphones (Black Left)] | + <- nid=12 [audio mixer] Record: nid=9 [audio input] | + <- nid=34 [audio selector] [src: monitor] bindSeq=00000001 | + <- nid=18 [pin: Microphone (ATAPI)] [src: monitor] bindSeq=00000001 Input Mix: nid=35 [audio mixer] | + <- nid=24 [pin: Microphone (Pink Left)] [src: mic] bindSeq=00000001 + <- nid=11 [audio mixer] +-------------------------+ | DUMPING Volume Controls | +-------------------------+ Master Volume (OSS: vol) | +- control 1 (nid 2 out): dir - out oss: vol, pcm -65/+0dB (88 steps) +- control 5 (nid 12 in 0): dir - out oss: vol, pcm mute +- control 6 (nid 12 in 1): dir - out oss: vol, igain mute +- control 8 (nid 20 out): dir - out oss: vol mute +- control 11 (nid 33 out): dir - out oss: vol mute PCM Volume (OSS: pcm) | +- control 1 (nid 2 out): dir - out oss: vol, pcm -65/+0dB (88 steps) +- control 5 (nid 12 in 0): dir - out oss: vol, pcm mute Microphone2 Volume (OSS: monitor) | +- control 7 (nid 18 in 0): dir - in oss: monitor +0/+36dB (4 steps) Recording Level (OSS: rec) | +- control 3 (nid 9 in 0): dir - in oss: rec -16/+30dB (32 steps) + mute Input Monitoring Level (OSS: igain) | +- control 6 (nid 12 in 1): dir - out oss: vol, igain mute OSS mixer initialization... Recsel (line, mic, cd, monitor): nid 34 source 6 select Registering PCM channels... pcmAttach: HDA Realtek ALC269 PCM #1 Digital at cad 0 nid 1 +--------------------------------------+ | DUMPING PCM Playback/Record Channels | +--------------------------------------+ Playback: Stream cap: 0x00000005 AC3 PCM PCM cap: 0x000e05e0 16 20 24 bits, 44 48 88 96 192 KHz DAC: 6 +-------------------------------+ | DUMPING Playback/Record Paths | +-------------------------------+ Playback: nid=30 [pin: SPDIF-out (Black Left)] | + <- nid=6 [audio output] [src: pcm] bindSeq=00000001 +-------------------------+ | DUMPING Volume Controls | +-------------------------+ OSS mixer initialization... Registering PCM channels... pcmAttach: HDA Realtek ALC269 PCM #2 Analog at cad 0 nid 1 +--------------------------------------+ | DUMPING PCM Playback/Record Channels | +--------------------------------------+ Record: Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz ADC: 8 +-------------------------------+ | DUMPING Playback/Record Paths | +-------------------------------+ Record: nid=8 [audio input] | + <- nid=35 [audio mixer] [src: mix] bindSeq=00000001 | + <- nid=24 [pin: Microphone (Pink Left)] [src: mic] bindSeq=00000001 + <- nid=11 [audio mixer] +-------------------------+ | DUMPING Volume Controls | +-------------------------+ Microphone Volume (OSS: mic) | +- control 10 (nid 24 in 0): dir - in oss: mic +0/+36dB (4 steps) +- control 12 (nid 35 in 0): dir - in oss: mic, rec mute Recording Level (OSS: rec) | +- control 2 (nid 8 in 0): dir - in oss: mix, rec -16/+30dB (32 steps) + mute +- control 12 (nid 35 in 0): dir - in oss: mic, rec mute +- control 13 (nid 35 in 5): dir - in oss: rec mute Input Mix Level (OSS: mix) | +- control 2 (nid 8 in 0): dir - in oss: mix, rec -16/+30dB (32 steps) + mute Input Monitoring Level (OSS: igain) | +- control 4 (nid 11 in 0): dir - in oss: igain -34/+12dB (32 steps) + mute OSS mixer initialization... Registering PCM channels... FG config/quirks: gpio0 forcestereo ivref50 ivref80 ivref100 ivref HP switch init... +-------------------+ | DUMPING HDA NODES | +-------------------+ Default Parameter ----------------- Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz IN amp: 0x00000000 OUT amp: 0x00000000 nid: 2 Name: audio output Widget cap: 0x0000001d STEREO Association: 0 (0x00008001) OSS: pcm (pcm) Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz Output amp: 0x00025757 mute=0 step=87 size=2 offset=87 Output val: [0x42 0x42] nid: 3 [DISABLED] Name: audio output Widget cap: 0x0000001d STEREO Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz Output amp: 0x00025757 mute=0 step=87 size=2 offset=87 Output val: [0x57 0x57] nid: 4 [DISABLED] Name: vendor widget Widget cap: 0x00f00000 nid: 5 [DISABLED] Name: vendor widget Widget cap: 0x00f00000 nid: 6 Name: audio output Widget cap: 0x00000211 DIGITAL STEREO Association: 1 (0x00000001) OSS: pcm (pcm) Stream cap: 0x00000001 PCM PCM cap: 0x000e05e0 16 20 24 bits, 44 48 88 96 192 KHz nid: 7 [DISABLED] Name: vendor widget Widget cap: 0x00f00000 nid: 8 Name: audio input Widget cap: 0x0010011b STEREO Association: 3 (0x00000001) Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz Input amp: 0x80051f0b mute=1 step=31 size=5 offset=11 Input val: [0x80 0x80] connections: 1 enabled 1 | + <- nid=35 [audio mixer] nid: 9 Name: audio input Widget cap: 0x0010011b STEREO Association: 2 (0x00000001) Stream cap: 0x00000001 PCM PCM cap: 0x000e0560 16 20 24 bits, 44 48 96 192 KHz Input amp: 0x80051f0b mute=1 step=31 size=5 offset=11 Input val: [0x17 0x17] connections: 1 enabled 1 | + <- nid=34 [audio selector] nid: 10 [DISABLED] Name: vendor widget Widget cap: 0x00f00000 nid: 11 Name: audio mixer Widget cap: 0x0020010b STEREO Association: 3 (0x00000001) OSS: (igain) Input amp: 0x80051f17 mute=1 step=31 size=5 offset=23 Input val: [0x1C 0x1C] [0x97 0x97] [0x97 0x97] [0x97 0x97] [0x97 0x97] connections: 5 enabled 1 | + <- nid=24 [pin: Microphone (Pink Left)] + [DISABLED] <- nid=25 [pin: Speaker (None)] [DISABLED] + [DISABLED] <- nid=26 [pin: Speaker (None)] [DISABLED] + [DISABLED] <- nid=27 [pin: Speaker (None)] [DISABLED] + [DISABLED] <- nid=29 [pin: Speaker (None)] [DISABLED] nid: 12 Name: audio mixer Widget cap: 0x0020010b STEREO Association: 0 (0x00008001) OSS: (igain) Input amp: 0x80000000 mute=1 step=0 size=0 offset=0 Input val: [0x00 0x00] [0x00 0x00] connections: 2 enabled 2 | + <- nid=2 [audio output] + <- nid=11 [audio mixer] nid: 13 [DISABLED] Name: audio mixer Widget cap: 0x0020010b STEREO Association: -2 (0x00000000) Input amp: 0x80000000 mute=1 step=0 size=0 offset=0 Input val: [0x00 0x00] [0x80 0x80] connections: 2 enabled 1 | + [DISABLED] <- nid=3 [audio output] [DISABLED] + <- nid=11 [audio mixer] nid: 14 [DISABLED] Name: vendor widget Widget cap: 0x00f00000 nid: 15 [DISABLED] Name: audio mixer Widget cap: 0x0020010a Input amp: 0x80000000 mute=1 step=0 size=0 offset=0 Input val: [0x00 0x00] [0x80 0x80] connections: 2 enabled 2 | + <- nid=2 [audio output] + <- nid=11 [audio mixer] nid: 16 [DISABLED] Name: vendor widget Widget cap: 0x00f00000 nid: 17 [DISABLED] Name: vendor widget Widget cap: 0x00f00000 nid: 18 Name: pin: Microphone (ATAPI) Widget cap: 0x0040000b STEREO Association: 2 (0x00000001) OSS: monitor (monitor) Pin cap: 0x00000020 IN Pin config: 0x99a30930 Pin control: 0x00000020 IN Input amp: 0x002f0300 mute=0 step=3 size=47 offset=0 Input val: nid: 19 [DISABLED] Name: vendor widget Widget cap: 0x00f00000 nid: 20 Name: pin: Speaker (ATAPI) Widget cap: 0x0040018d UNSOL STEREO Association: 0 (0x00000001) Pin cap: 0x00010014 PDC OUT EAPD Pin config: 0x99130110 Pin control: 0x00000040 OUT EAPD: 0x00000002 Output amp: 0x80000000 mute=1 step=0 size=0 offset=0 Output val: [0x00 0x00] connections: 2 enabled 1 | + <- nid=12 [audio mixer] (selected) + [DISABLED] <- nid=13 [audio mixer] [DISABLED] nid: 21 [DISABLED] Name: vendor widget Widget cap: 0x00f00000 nid: 22 [DISABLED] Name: vendor widget Widget cap: 0x00f00000 nid: 23 [DISABLED] Name: pin: Speaker (None) Widget cap: 0x0040010c Pin cap: 0x00000010 OUT Pin config: 0x411111f0 Pin control: 0x00000000 Output amp: 0x80000000 mute=1 step=0 size=0 offset=0 Output val: [0x80 0x80] connections: 1 enabled 1 | + <- nid=15 [audio mixer] [DISABLED] nid: 24 Name: pin: Microphone (Pink Left) Widget cap: 0x0040018f UNSOL STEREO Association: 3 (0x00000001) OSS: mic (mic) Pin cap: 0x00001734 PDC OUT IN VREF[ 50 80 GROUND HIZ ] Pin config: 0x03a19840 Pin control: 0x00000024 IN VREFs Output amp: 0x80000000 mute=1 step=0 size=0 offset=0 Output val: [0x00 0x00] Input amp: 0x002f0300 mute=0 step=3 size=47 offset=0 Input val: [0x02 0x02] connections: 1 enabled 0 | + [DISABLED] <- nid=13 [audio mixer] [DISABLED] nid: 25 [DISABLED] Name: pin: Speaker (None) Widget cap: 0x0040008b UNSOL STEREO Pin cap: 0x00001724 PDC IN VREF[ 50 80 GROUND HIZ ] Pin config: 0x411111f0 Pin control: 0x00000000 Input amp: 0x002f0300 mute=0 step=3 size=47 offset=0 Input val: nid: 26 [DISABLED] Name: pin: Speaker (None) Widget cap: 0x0040018f UNSOL STEREO Pin cap: 0x0000003c PDC HP OUT IN Pin config: 0x411111f0 Pin control: 0x00000000 Output amp: 0x80000000 mute=1 step=0 size=0 offset=0 Output val: [0x80 0x80] Input amp: 0x002f0300 mute=0 step=3 size=47 offset=0 Input val: [0x00 0x00] [0x00 0x00] connections: 2 enabled 2 | + <- nid=12 [audio mixer] (selected) + <- nid=13 [audio mixer] [DISABLED] nid: 27 [DISABLED] Name: pin: Speaker (None) Widget cap: 0x0040018f UNSOL STEREO Pin cap: 0x00000034 PDC OUT IN Pin config: 0x411111f0 Pin control: 0x00000000 Output amp: 0x80000000 mute=1 step=0 size=0 offset=0 Output val: [0x80 0x80] Input amp: 0x002f0300 mute=0 step=3 size=47 offset=0 Input val: [0x00 0x00] [0x00 0x00] connections: 2 enabled 2 | + <- nid=12 [audio mixer] (selected) + <- nid=13 [audio mixer] [DISABLED] nid: 28 [DISABLED] Name: vendor widget Widget cap: 0x00f00000 nid: 29 [DISABLED] Name: pin: Speaker (None) Widget cap: 0x00400000 Pin cap: 0x00000020 IN Pin config: 0x4017992d Pin control: 0x00000000 nid: 30 Name: pin: SPDIF-out (Black Left) Widget cap: 0x00400381 DIGITAL UNSOL STEREO Association: 1 (0x00000001) Pin cap: 0x00000014 PDC OUT Pin config: 0x03451120 Pin control: 0x00000040 OUT connections: 1 enabled 1 | + <- nid=6 [audio output] nid: 31 [DISABLED] Name: vendor widget Widget cap: 0x00f00000 nid: 32 [DISABLED] Name: vendor widget Widget cap: 0x00f00040 PROC nid: 33 Name: pin: Headphones (Black Left) Widget cap: 0x0040018d UNSOL STEREO Association: 0 (0x00008000) Pin cap: 0x0000001c PDC HP OUT Pin config: 0x0321101f Pin control: 0x000000c0 HP OUT Output amp: 0x80000000 mute=1 step=0 size=0 offset=0 Output val: [0x00 0x00] connections: 2 enabled 1 | + <- nid=12 [audio mixer] (selected) + [DISABLED] <- nid=13 [audio mixer] [DISABLED] nid: 34 Name: audio selector Widget cap: 0x0030010b STEREO Association: 2 (0x00000001) OSS: monitor connections: 7 enabled 1 | + [DISABLED] <- nid=24 [pin: Microphone (Pink Left)] + [DISABLED] <- nid=25 [pin: Speaker (None)] [DISABLED] + [DISABLED] <- nid=26 [pin: Speaker (None)] [DISABLED] + [DISABLED] <- nid=27 [pin: Speaker (None)] [DISABLED] + [DISABLED] <- nid=29 [pin: Speaker (None)] [DISABLED] + [DISABLED] <- nid=11 [audio mixer] + <- nid=18 [pin: Microphone (ATAPI)] (selected) nid: 35 Name: audio mixer Widget cap: 0x0020010b STEREO Association: 3 (0x00000001) OSS: mix (mix) Input amp: 0x80000000 mute=1 step=0 size=0 offset=0 Input val: [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x00 0x00] connections: 6 enabled 2 | + <- nid=24 [pin: Microphone (Pink Left)] + [DISABLED] <- nid=25 [pin: Speaker (None)] [DISABLED] + [DISABLED] <- nid=26 [pin: Speaker (None)] [DISABLED] + [DISABLED] <- nid=27 [pin: Speaker (None)] [DISABLED] + [DISABLED] <- nid=29 [pin: Speaker (None)] [DISABLED] + <- nid=11 [audio mixer] Link to comment Share on other sites More sharing options...
Cassio Posted February 1, 2012 Share Posted February 1, 2012 You can set it in MixerValues. You probably need to change other value to have audio after muting iGain, maybe iMix. Play with the sliders in prefPane then edit Info.plist with good values <key>MixerValues</key> <dict> <key>iGain</key> <string>0</string> <key>iMix</key> <string>50</string> </dict> You can also use VoodooHdaSettingsLoader to restore prefPane values at startup (add it to Login Items). -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
Zambo27 Posted February 1, 2012 Share Posted February 1, 2012 i am going to destroy this card in voodoo prefpane i can only set gain, mix and pcm if gain is different from 0 pc start to make noise with speaker and the other 2 are useless, and if i try to change somethings in normal audio prefpane i have to force quit it i think the system begin to see my soundcard but it don't know how to use it, maybe an injector like HDAenabler can help? Link to comment Share on other sites More sharing options...
Cassio Posted February 1, 2012 Share Posted February 1, 2012 Try to set in Info.plist <key>MixerValues</key> <dict> <key>iGain</key> <string>[b]0[/b]</string> <key>iMix</key> <string>[b]30[/b]</string> </dict> and <key>Vectorize</key> <[b]true[/b]/> also set IOPCIPrimaryMatch as you did before (important to avoid conflict with HDMI audio) <key>IOPCIPrimaryMatch</key> <string>0x3b568086</string> It works perfectly on the laptop in my signature, same audio codec. -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
Zambo27 Posted February 2, 2012 Share Posted February 2, 2012 noise disappear, but there is still no sound i notice that volume control on keyboard doesn't work well, first press i see the icon on the screen, fro second press no icon and after some seconds the system lose the audio card, it reconnect only if i open audio menu Link to comment Share on other sites More sharing options...
Cassio Posted February 2, 2012 Share Posted February 2, 2012 Try this, it's the one I use (2.7.2 already edited) http://www.sendspace.com/file/j2avzz -Donations- PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3 PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com Premium Users HERE - Problems with Paypal HERE Link to comment Share on other sites More sharing options...
