pernacabeluda Posted March 10, 2015 Author Posted March 10, 2015 You need to test. If SuspendOverride and/or HaltEnabler in config.plist do not work, try the DSDT patch. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Bruxo Posted March 11, 2015 Posted March 11, 2015 Thank you for your attention pernacabeluda I used SuspendOverride and / or HaltEnabler in Config.plist but have had no effect !!! I decided to use a copilada DSDT and removed all fix in config.plist of Clover and now deslina hardware perfectly !!! Thanks for the explanations DSDT.aml.zip Bootloader - Clover Placa mãe - GA-G31M-S2L Processador - Pentium E5200 - DDR2 800MHZ 2X2 4GB Placa de video - SFX-RADEON-HD5670 - 1GB AppleHDA ALC662 Framebuffer - Uakari - injeção por Cover config HDMI, DP, DVI Yosemite 10.10.2
