Download Yosemite from App Store
http://www.apple.com/osx/
Run this command in terminal to copy installation files to pen drive
sudo /Applications/Install\ OS\ X\ Yosemite.app/Contents/Resources/createinstallmedia --volume /Volumes/[color=#FF0000]"pen drive name"[/color] --applicationpath /Applications/Install\ OS\ X\ Yosemite.app --nointeraction
If you are already using Clover, the following steps are not necessary, just copy the basic kexts to kexts/10.10 and boot the installer with injected kexts (pressing the space bar)
Install Clover in the pen drive
http://sourceforge.net/projects/cloverefiboot/files/Installer/
To use Install for UEFI motherboards the pen drive must be partitioned as GUID and depending on BIOS you may need the driver OsxLowMemFix (Insyde H2O), EmuVariableUefi (Phoenix UEFI) or OsxAptioFixDrv (all others)
To use legacy boot select Install boot0af in MBR under Bootloader and for some BIOS the pen drive must be partitioned as MBR
Select a theme
Copy the basic kexts to EFI/CLOVER/kexts/10.10
http://Olarila.com/files/10.8/HWSensors/FakeSMC.kext.zip
http://Olarila.com/files/10.6/PM/NullCPUPowerManagement.kext.zip
http://Olarila.com/files/10.8/PS2/PS2_Voodoo.zip (only for laptops or if you use PS/2 keyboard and mouse)
Edit the file EFI/CLOVER/config.plist with these basic settings
Boot
Arguments
-v npci=0x2000 kext-dev-mode=1
GUI
Theme
[color=#FF0000]name of the theme you selected[/color]
SystemParameters
InjectKexts
Boot from the pen drive and proceed with the installation
When the installation restarts, boot from the installer again to finish the installation
After the installation restarts for the second time, the HD partition will show in Clover menu
Post install
http://Olarila.com/forum/viewtopic.php?f=28&t=1716
Enable USB ownership fix in Clover options menu.
I tried with move graphics kext also. Still not loading installer . But when I boot with chemelon by pressing 1 , then installer come but stop loading installer after little time.
Note: i installed Previous veroin of Mac from Olarila successfully. But why I can't install 10.10.?
Please help me
This method doesn't work with Chameleon.
You must use this to be able to use Chameleon
http://Olarila.com/forum/viewtopic.php?f=28&t=4632
If you are using the raw image please post here
http://Olarila.com/forum/viewtopic.php?f=9&t=4784
I have downloaded the Olarila image for Yosemite from TPB, and used win32diskimager to copy it onto a USB pendrive. Clover starts up correctly, but no matter what options I choose, I cannot get to the OSX installer. After the "missing bluetooth controller" message appears, there is a small delay, and then the system hangs. I get a circle with a line in the center of the screen, and all the text appears weird. There is also a message "still waiting for root device".
Note that I have to disable graphics injection all the time, otherwise all I get is a black screen.
My laptop is a dell inspiron 5420, corei7-3612QM, Intel hd4000, Nvidia GT-630M, 12 gb RAM. Bios is dell A19.
I have also tried with the graphics kexts deleted from the pendrive. But no matter what I do, the result is the same - the system hangs after the message "Still waiting for root device."
Can somebody help me?
Try to enable USB ownership fix in Clover options menu.
I did that, but getting the same result.
I have also tried booting in legacy as well as UEFI modes, and the results are the same.
Try with Chameleon, boot legacy and press 1.
Did you try other USB ports?
Yes, I tried the other USB ports. By the way, I only have USB 3.0 ports - could that be an issue?
I tried Chameleon as you suggested, but the result is the same - stuck at "Still waiting for root device."
The installer includes GenericUSBXHCI driver, so it should work.
If your chipset is Intel Series 7/Panther Point, try to add -gux_defer_usb2 or -gux_no_idle (or both) in boot-args.
Also check if you have any option to configure USB ports in BIOS setup.
Oh wow, that worked. Yes, I do have a series 7 chipset. What do those two args do?
I was able to enter setup, but now I have another issue. My hard disk was already partitioned by Windows, and I had left 15gb of free space to install OSX. But disk utility cannot format that partition - I get the error "Mediakit reports not enough free space on device". Could this be because the disk was already partitioned with Windows?
(It is partitioned as GUID, the first three partitions are used by Windows, a fourth partition is for storing my data, and the 5th one is left free for OSX.)
I could repartition the whole disk using OSX, but the trouble I had earlier when I did that was that my Windows partition was not aligned properly, and as I understand, that can have a negative impact on the performance and life of an SSD drive.
if the hd is already in gpt (guid)
in windows format the 15 gb .. is low that amount, to fat
then in OS X format it again to hfs+
Actually, I went ahead and repartitioned the whole disk using OSX disk utility. I selected GUID partition table, and made one partition for OSX, and succesfully installed OSX in it.
But now, when I try to install Windows in another partition, Windows says that the disk is MBR, and cannot create any more partitions.
To be certain, I used disk utility again, and I am sure now that my hard disk is GPT. But windows setup tells me the same thing, that my disk is MBR.
It seems that I am unable to install OSX if the disk is partitioned using windows, and unable to install windows if the disk is partitioned using OSX. Can somebody help me out?
take a good read here
http://Olarila.com/forum/viewtopic.php?f=28&t=3405
Hmm, I think I realized my mistake from the first paragraph on that page. I was using disk utility to format all the partitions - and from what I understand, that causes disk utility to make the disk a hybrid one, not pure GPT. Now I followed the suggestion on that page and formatted all partitions as HFS+, and then immediately restarted into the windows bootloader. This time Windows was installed succesfully. Now I'm installing Yosemite on the first partition, and that is also going well.
I think the only remaining trouble would be installing clover with all the right options, to boot into either OS.
Thanks arthur-pt and pernacabeluda for the help!
I'm trying to get it running on on an intel i3 nuc and cannot get to the setup screen. im using the clover yosemite raw image from tpb written to a flash drive.
i have tried enabling usb ownership in clover boot options. when i select boot os x the machine reboots shortly after.
