Hi guys!
I already installed Monterrey using the Olarila image but the only problem is my iGPU, technically my laptop Dell Latitude 7285 is identical to a MacBook "Core i7" 1.4 12" (Mid-2017) Macbook10,1 1.4 GHz Core i7 (I7-7Y75) with Intel HD Graphics 615, the problem is I can not make the graphics acceleration works properly because the system show 21mb VRAM.
I tried editing the OpenCore DeviceProperties adding the framebuffer numbers in config.plist with no luck.
My System Specs:
CPU: Intel® Core™ i5-7Y57 Processor (6M Cache, up to 3.60 GHz)
Graphics: Intel® HD Graphics 615
Sound: Realtek ALC3253 (ALC225)
Display: 12.3 Inch 2880 X 1920 (WUXGA+) 3:2 10 Points Multi Touch
Memory: Micron LPDDR3 16GB 1867MHZ (8GB * 2 Dual Channel)
SSDTOSHIBA KXG60ZMV512G 512GB (2240) (WWAN Slot * 1)
Wireless: Intel
AC 8265 Wi-Fi + BT 4.2 (2x2) Bluetooth.
Battery: 32WHr (Build in) + 22WHr (Keyboard)
Any help will be appreciated and I will upload all the files to help others when system works 100%.
