Basic Information
  • Hardware
    • CPU: AMD Ryzen 5600X
    • MB: AsRock B550M Pro4
    • RAM: Samsung DDR4-3200 32GB x 4 (Total 128GB)
    • GPU: AMD Radeon RX560 4GB
    • Ethernet: Realtek RTL8211
    • Bluetooth: BU-4096 (Broadcom BCM20702A0 Based)
  • Software
    • My EFI setup is based on Dortania's guide (I would use olarila's if I knew before!!)
    • macOS Version: Ventrua (13.4.1)
    • SMBIOS Platform: iMac18,1
    • Kexts
      • AMDRyzenCPUPowerManagement
      • AppleALC
      • AppleMCEReporterDisabler
      • BlueToolFixup
      • BrcmFirmwareData
      • BrcmPatchRAM3
      • Lilu
      • RadeonSonsor
      • RealtekRTL8111
      • RTCMemoryFixup
      • SMCAMDProcessor
      • SMCRadeonGPU
      • USBToolBox
      • UTBMap
      • VirtualSMC
      • WhateverGreen
Problem
Everytime my system reboots / starts after shutdown / sleep, it does not boot at all. I suppose it fails to init (POST) after shutdown. CPU and DRAM Error POST Error LED are lit up on start. CMOS Reset by removing the coin battery (or at least unplugging the AC power cord and waiting 10 ~ 20 seconds) work. Some say it is RTC problem, so I tried to enable DisableRtcChecksum, but it didn't work. Tried RTCMemoryFixup too, but it didn't work. Please help.
Additional information request are welcome. Thanks for reading long post.
inject rtc with these properties and check if work
Quote
 Name (_HID, EisaId ("PNP0B00") /* AT Real-Time Clock */)  // _HID: Hardware ID
        Name (_CRS, ResourceTemplate ()  // _CRS: Current Resource Settings
            IO (Decode16,
                0x0070,             // Range Minimum
                0x0070,             // Range Maximum
                0x00,               // Alignment
                0x02,               // Length
Current RTC0 Device checked with MaciASL is defined as below.
Device (RTC0)
    Name (BUF0, ResourceTemplate ()
        IO (Decode16,
            0x00,               // Alignment
            0x02,               // Length
    Name (BUF1, ResourceTemplate ()
        IO (Decode16,
            0x00,               // Alignment
            0x02,               // Length
        IRQNoFlags ()
            {8}
    Method (_CRS, 0, Serialized)  // _CRS: Current Resource Settings
        If ((HPEN == One))
            Return (BUF0) /* \_SB_.PCI0.SBRG.RTC0.BUF0 */
        Return (BUF1) /* \_SB_.PCI0.SBRG.RTC0.BUF1 */
How should I apply it? Remove the BUF1?
