DSDT request for i5 9400f with generic motherboard and RX 560
Send me iMac 9400f placa mãe WorldPC generica.zip
I attach the "Send me" file here.
I was able to install MacOS Ventura.
I suppose the video is working properly thanks to RX 560 that contains native support.
Just want to generate an DSDT.
The only problem now is when I try to turn off the PC, the screen goes black, but the Hackintosh didn't turn off. I suppose creating the DSDT can fix this problem.
Destkop
Intel 9400f
AMD 560 RX
Generic Motherboard
Notebook
Lenovo Ideapad S145
8130u
EFI.zip
USB Remap https://www.olarila.com/topic/14220-hackintosh-usb-port-mapping-guide-2023/
When I try to turn off my Hackintosh, It works now.
Thank you so much for your help.
Destkop
Intel 9400f
AMD 560 RX
Generic Motherboard
Notebook
Lenovo Ideapad S145
8130u
Hi, just revive this old topic to ask another question. What is the correct way to update a MacOS version. I ask that because when I try to update a MacOS version, I always get a black screen after the update.
I will try to update from Ventura to Sonoma. What is the correct procedures to update a MacOS version using Hackintosh ?
Destkop
Intel 9400f
AMD 560 RX
Generic Motherboard
Notebook
Lenovo Ideapad S145
8130u
Hi @MaLd0n I was able now to install now a new MacOS version, Sonoma. But I need to install from scratch. I try to use the same EFI that you send me for Ventura, but it didn't work even after I update all kexts using OCAT.
Can you generate an EFI folder with a DSDT patch using the files from RunMe.app files below?Send me FabioCunhas-Mac-Pro.zip
Destkop
Intel 9400f
AMD 560 RX
Generic Motherboard
Notebook
Lenovo Ideapad S145
8130u
