-Tutorial USB Port Mapping Guide - Hackintosh BigSur, Monterey and Ventura
-Downloads USBInjectAll Tahoe.zip
Hackintool - https://github.com/headkaze/Hackintool/releases
Credits USBInjectAll: @RehabMan
  • Like 11
  • Thanks 2
Enjoy!
Enjoy, @Josele
10 minutes ago, Josele said:
Can we get the same result by disabling the unused usb in the bios?
u can disable ports one by one in bios/uefi?
14 usb2 ports and 10 usb3 ports?
SOLVED.
Useful for those who have the MSI B460A-Pro.
The motherboard has 6 usb3, 6 usb2 and 6 usb2 (in usb3) total 18 usb ports.
In BIOS you can disable those that are not used or are not connected.
The equivalence with hackintool is as follows.
HS01 = USB2 Port #13
HS02 = USB2 Port #10
HS03 = USB2 Port #9
HS04 = USB2 Port #8
HS05 = USB2 Port #7
HS06 = USB2 Port #6
HS07 = USB2 Port #5
HS08 = USB2 Port #4
HS09 = USB2 Port #3
HS10 = USB2 Port #2
HS11 = USB2 Port #1
HS12 = USB2 Port #0
In my case, the ports that I had to disable at boot were HS08 and HS12 for USB3 to work.
So I have disabled USB2 Port #0 and USB2 Port #4 in BIOS and uia_exclude = HS08; HS12 is no longer needed.
I hope it is useful for everyone
  • Like 2
2 hours ago, rooguima said:
How can I do that if I can't log in on my device? My keyboard and mouse need a bt dongle or usb cable.
use one usbstick with xhciportlimit disable
I'm stuck with just usb 3 ports on my ProArt Z490 creator 10g. I'm running 11.3.1 but just can use Bluetooth keyboard and mouse. My usb 2 keyboard and mouse are not recognized. What I'm doing wrong?
Thanks in advance
check video tutorial. disable xhci patch
now with last hackintool version u can use only usbports.kext
I followed your 30 April 2021 YouTube video. Which step can I skip?
I put XCHI-unsupported.kext into EFI>OC>kexts
Do I still need this?
I have tried several methods of USB port mapping. Using Gigabyte H97-HD3, OpenCore 0.6.9, Big Sur 11.4
Following the 40 April 2021 video exactly, Hackintool displays this (Screenshot 1.02.38pm) :
What's with the EHCI1, EHCI2, PR01, PR12. I tried putting these in uia_exclude and they don't do anything becasue after mapping the USB2.0 devices and rebooting, Hackintosh still displays the same. They are no excluded. Unhighlighted ISB 2.0 are excluded.
Also it is interesting that in the first screenshot, there is an SS01 at the bottom.
So with the first screenshot, I uia_excluded HS07,HS13, HS14 only.
save and reboot:
Now Hackintool displays screenshot 2 (1.22.15 pm):
So only 4 SS (USB 3.0) are identified. My motherboard has 6 USB 3.0, 4 at the rear, and 2 at the front. The 2 front ports uses a header on the motherboard.
So after USB 3.0, I did not exclude any more port. ie. uia_excluded same as before.
Then I generated the SSDT-UIAC followed the video.
It works but of course only 4 USB 3.0 are detected and 2 of the USB 3.0 became USB 2.0 ports.
Anyway to solve this?
Screenshot 2021-05-26 at 1.02.38 PM.png.zip Screenshot 2021-05-26 at 1.22.15 PM.png.zip
u need kill device ehc1 and ehc2
