hello y'all,
i used an ph315-53 for turning my laptop on hackintosh, problem he stay on the apple black screen, somebody can help me?
-i7-10870H (10th gen)
-GeForce® RTX™ 3080/UHD 630
-32G ram
in the zip you can have all reference "acpi/kext"  with my config list
thank you
EFI.7z
https://www.olarila.com/topic/25111-hackintosh-efi-folders-with-opencore-mod/
