Hello,
I am using the digital audio out SPDIF out of my Z170X, it works great but the output is 44kHz, I was wondering if there was a way to change it to 48kHz since this is the setting I use in most of my AV application. Under Mojave I used Thunderbolt to connect my external audio card but I can't make the USB Type-C work so I can't anylonger use my card.
Thanks for your help.
config.plist.zip
