HP 630 - MV 10.9 (10.9.3) and Intel HD 3000 problem
Hello everyone,
After two days spent on this issue, i try to get an help in forum.
I have an HP 630 (hp 630 TPN-F102) that mount an Intel i3, and an Intel HD 3000 graphic card.
I successfully installed and booted Mavericks by moving kexts AppleIntelHD* and AppleIntelSNB* to a backup folder.
I got Wireless working by AtherosWiFiInjector kext.
I got Synaptic Trackpad and keyboard working by PS2_voodoo kexts pack (AppleACPIPS2Num.kext and VoodooPS2Controller.kext).
Of course, i installed FakeSMC and NullCPUPowermanagement kexts.
I edited DSDT removing errors and some problems (i put those DSDT files in this thread).
Now:
I cannot get correct resolution nor graphic accelleration, i tried those ways (and some more):
[url]http://www.osx86.net/topic/16514-intel-hd-graphics-3000-for-1082-not-working-graphic-driver/[/url]
[url]http://www.insanelymac.com/forum/topic/256379-hm65-express-chipset-sandy-bridge-laptops/[/url]
[url]http://www.insanelymac.com/forum/topic/286879-appleintelhdgraphicsfb-fixed-sl-1068/[/url]
[url]http://www.osx86.net/topic/14127-success-enable-vga-and-hdmi-video-for-intel-hd-3000/[/url]
But, i cannot reach the success.
I moved also from ML (10.8.5) to MV (10.9.3) in hope to fix this.
My graphic device have this DevID: 0x0116
What should I do?
DSDT.rar
try with this dsdt
I'm going to try this, but can I know what do you modified (i'm courious)?
UPDATE: I tried that DSDT but i get the same problem: a white screen with bars...
are u sure u need to use dual link ?
what is ur native resolution ?
I don't need to use an external monitor, my native resolution are 1366x768 but I can't get it (i'm stucked on 1024's one) and, without deleting/moving video kexts, i cannot reach graphical enviroment (the problem descibed just before)
ur problem is not read .. when i say read is to read carefully the info..
http://Olarila.com/forum/viewtopic.php?f=28&t=2193
For resolutions greater than 1366x768 it's usually necessary to inject property DualLink in the display device, which can be done with this DSDT patch
use this one
DSDT.zip
use this one
[attachment=0]DSDT.zip[/attachment]
If i try that solution, i get the same error (with or without using og DSDT), so that solution does not work for me.
no solution for now.. u google something about ur specifications...
What is the device ID of your IMEI controller?
You may need this DSDT patch, or patch the framebuffer kext
http://Olarila.com/forum/viewtopic.php?f=3&t=1339&start=160#p35431
