Wifi, Bluetooth and Audio not working ( and several others)
Hi,
so I installed macOs monterey according to the guidelines, but there is something I left out, namely dsdt (because I don't know how to do it).
for wifi I've tried using AirportItlwm and itlwm and both doesn't work (intel dual band wireless-AC 7265).
then for audio, when I open audio codecs it shows up like this
does this have anything to do with me not setting up dsdt yet? if so can you help me?
this is the result of RunMe.app https://easyupload.io/g3ny68
would appreciate any help
Laptop : ASUS UX303LA
CPU: Intel i7 Broadwell 5500U
Graphics: Intel HD 5500 ( and Nvidia 940M but I disabled it)i-Screen-Shoter-20230410113334766.jpg
config.plist.zip
