Legion Y540-15irh - Full installed but bluetooth and GPU not working
Hello,
I'm new here :)
I successfully installed Ventura on my Y540, but I need help about few problems
 - Bluetooth isn't working
 - How to use my nvidia chip GeForce GTX 1600?
 - WiFi module isn't working ( I saw I need to replace the chip)
 - Trackpad's buttons not fully working,
 - And it's possible to map the keyboard as a windows keyboard not as a mac ?
Here my laptop on ventura https://ibb.co/BnXSrdt
Here you can fin my EFI : https://www.mediafire.com/file/8sgbp8d64e5uc15/EFI.zip/file
Here you can find my laptop : https://www.lenovo.com/fr/fr/laptops/legion-laptops/legion-y-series/Lenovo-Legion-Y540-15/p/88GMY501214
Edited by Zane
Full hardware specs like BT, Wifi, etc.
System Manufacturer: LENOVO
System Model: 81SY
BIOS: BHCN42WW (type: UEFI)
Processor: Intel(R) Core(TM) i5-9300H CPU @ 2.40GHz (8 CPUs), ~2.4GHz
Memory: 16384MB RAM
 GPU     Name: NVIDIA GeForce GTX 1650
                Device ID: PCI\VEN_10DE&DEV_1F91&SUBSYS_3FFB17AA&REV_A1\4&1F1FFAD1&0&0008
Sound : Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0257&SUBSYS_17AA3810&REV_1000
Webcam : Manufacturer: Realtek
                  HardwareID: USB\VID_13D3&PID_56A6&REV_1711&MI_00,USB\VID_13D3&PID_56A6&MI_00
Wifi
Quote
Informations générales
Nom de la carte réseau
Intel(R) Wireless-AC 9560 160MHz
Type d'adaptateur
IEEE 802.11 wireless
Connecté
oui
Bande passante montante
866.70 MBits/s
Bande passante descendante
866.70 MBits/s
Adresse IPv4
192.168.1.163
Adresse IPv6
2A01:E0A:A:2000:43FE:94FE:AD7:A31E,2A01:E0A:A:2000:9833:B097:BE42:F700,FE80::B4B0:5AB2:253B:837E
DNS
192.168.1.254
Réseau DHCP
oui
Serveur DHCP
192.168.1.254
MTU
1500
Carte PCI/AGP
Bus/Périphérique/Fonction
0 / 20 / 3
Nom du fabricant
Intel Corporation (Identifiant fabricant: 0x8086)
Nom du périphérique
Cannon Lake PCH CNVi WiFi (Identifiant fabricant: 0x8086,Identifiant modèle: 0xA370)
Nom précis du périphérique
Wireless-AC 9560 (Identifiant sous-vendeur: 0x8086,Identifiant sous-modèle: 0x0034)
Type
Réseau (Classe: 0x02)
Sous-type
réseau (Sous-classe: 0x80)
Identifiant de révision
0x10
Bluetooth
Quote
Nom du pilote
Intel(R) Wireless Bluetooth(R)
Fabricant
Intel Corporation
Version
21.90.2.1
Fichier inf
oem8.inf
Type
bluetooth
Identificateur matériel
USB\VID_8087&PID_0AAA&REV_0002
Driver installé
oui
Problème sur le driver
oui
Périphérique USB
Nom du périphérique
Bluetooth 9460/9560 Jefferson Peak (JfP) (Intel(R) Wireless Bluetooth(R)) (Identifiant modèle: 0x0AAA)
Nom du fabricant
Intel Corp. (Identifiant fabricant: 0x8087)
That's all I found
thank you for the help,
Edit : I download and install it, WiFi can be enable but no network detected, bluetooth is the same, cannot be detected
Edited by Zane
Hello Zane, I hope you have a good day
I nearly have the same laptop (y540 17irh)
can you provide me with any tutorials to install ventura
Is it possible to install it on external SSD?
Hi, i have the exact same laptop that Jane has, i used her EFI along with a offline full image of Ventura 13.5 and its not working. I'm very confused why is it not working when they are the exact same laptops? Pls help
I did that I updated it properly and haven't made any changes to it its the exact same EFI except now I've updated the OC and Kexts like you said and now the fans don't go wild but still it's back to the old issue
I click the install Ventura option> apple logo comes and loads like ~10%> then laptop restarts
Here is the EFI(OC+Kexts updated using OCAT): https://drive.google.com/drive/folders/1gT6Epsh_ARsIZ9Q6hZh45qNzufKk5Sip?usp=sharing
(the EFI folder is inside the EFi Updated folder cause I have multiple EFIs in Google Drive)
Pls help I don't understand why is it not working on my laptop even though they're the same
