Prim0 Posted February 27, 2014 Posted February 27, 2014 Hi i am new to the hackintosh thing but i really wanna hackitosh but there is 1000 of guides, can someone help me my laptop is lenovo g500 with a: Processor 1 ID = 0 Number of cores 2 (max 8) Number of threads 2 (max 16) Name Intel Core i3/i5/i7 Codename Ivy Bridge Specification Intel® Celeron® CPU 1005M @ 1.90GHz Package (platform ID) Socket 988B rPGA (0x4) CPUID 6.A.9 Extended CPUID 6.3A Core Stepping E1/L1 Technology 22 nm TDP Limit 35 Watts Tjmax 105.0 °C Core Speed 1896.8 MHz Multiplier x Bus Speed 19.0 x 99.8 MHz Stock frequency 1900 MHz Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size L2 cache 2 x 256 KBytes, 8-way set associative, 64-byte line size L3 cache 2 MBytes, 8-way set associative, 64-byte line size FID/VID Control yes Turbo Mode not supported Max non-turbo ratio 19x Max turbo ratio 19x Max efficiency ratio 12x Min Power 24 Watts O/C bins none Ratio 1 core 19x Ratio 2 cores 19x Ratio 3 cores 19x Ratio 4 cores 19x TSC 1897.3 MHz APERF 1197.4 MHz MPERF 1895.9 MHz Chipset ------------------------------------------------------------------------- Northbridge Intel Ivy Bridge rev. 09 Southbridge Intel HM70 rev. 04 Memory Type DDR3 Memory Size 6 GBytes Channels Dual Memory Frequency 798.7 MHz (1:6) CAS# latency (CL) 11.0 RAS# to CAS# delay (tRCD) 11 RAS# Precharge (tRP) 11 Cycle Time (tRAS) 28 Command Rate (CR) 1T MCHBAR I/O Base address 0x0FED10000 MCHBAR I/O Size 19456 MCHBAR registers can someone tell is it even possible to run any mac os x, and if it is can you direct me to a tuturial Thank You.
artur-pt Posted February 28, 2014 Posted February 28, 2014 hello i'm sure not snow .. no native support to that cpu.. and u graphics good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
Prim0 Posted March 1, 2014 Author Posted March 1, 2014 hello i'm sure not snow .. no native support to that cpu.. and u graphics good hack do you think that niresh 10.8.5 will work
artur-pt Posted March 1, 2014 Posted March 1, 2014 hello u should ask niresh about that .. here is Olarila.com .. no niresh good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
