Hello I am succes install Hackintosh Monterey with spec hardware
CPU : Ryzen 3 2200g (igpu disabled)
GPU : Sapphire RX 580
Motherboard : MSI B450 A PRO MAX
RAM : Kiev 16 GB Dual channel
already try my video audio its work, but when I want to use my dual monitor my second monitor is network, its just blank screen on my second monitor. its detected but blank screen
Main monitor = DP Port
Second Monitor = HDMI Port.
can anyone help me to fix it ?
Edited by Kazami Hazaki
CSM is disabled?
2 hours ago, MaLd0n said:
CSM is disabled?
Ohh great its work, i forgot it to disable csm. but its always. have 3 beeps code, and then after waiting for some time its will boot to my Mac. but when I am restart again its will repeat the same thing. oh and another one issue my Audio Jack from rear panel not working right now, after using dual monitor. when I try to plug in my speaker to monitor, the voice have annoying sound or not clear
