sidegame Posted February 22, 2014 Posted February 22, 2014 Hi there I have just installed Mac OSX Maverick on my HP laptop using (myhack) as it already installed some of the drivers, but some of the features are missing sorry I am kind of noob in this so any help will be much appreciated. Left side (of the Laptop) their 2 USB port doesn't works, right side does. -My wireless internet adapter isn't working -Sound -Screen Brightness changing (on Keyboard) isn't working. -My GPU (Ati Radeon 6470M) -HP Webcam not detected. What is working: Right USB Port Mouse Keyboard DVD Drive LAPTOP: HP Pavilion g6-1150se CPU: Intel Core i5 Chipset: Sandy Bridge Bios Version: F.24 Motherboard: Hewlett-Packard (model-1670) RAM: 3GB Graphics card:Ati Radeon HD 6470M DSDT.zip
sidegame Posted February 23, 2014 Author Posted February 23, 2014 anyone now how to patch (USB, Sound, Ati, etc...) please
artur-pt Posted February 23, 2014 Posted February 23, 2014 hello there it is DSDT.aml.zip 1 thing DSDT is not GOD... u should read about what u trying to do start here http://Olarila.com/forum/viewtopic.php?f=28&t=1716 http://Olarila.com/forum/viewtopic.php?f=28&t=1703 http://Olarila.com/forum/viewtopic.php?f=28&t=736 http://Olarila.com/forum/viewtopic.php?f=28&t=454 good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
sidegame Posted February 23, 2014 Author Posted February 23, 2014 hello there it is for increasing/decreaing screen brightness is not working; so, anyway to fix it?
sidegame Posted February 23, 2014 Author Posted February 23, 2014 anyone know how to enable screen brightness [increase/decrease] using DSDT patch or .kext to work with keyboard or slider pleazz?
m.gbt Posted February 23, 2014 Posted February 23, 2014 If you keep double posting and screaming for help, nobody will help you anymore. Your brightness slider is the first thing to fix, you use PNLF patch for that. Once it's working, if your keys are still not working you have to look further. Mavericks 10.9.2 Retail When you ask for support, remember to tell the bootloader you use
sidegame Posted February 24, 2014 Author Posted February 24, 2014 If you keep double posting and screaming for help, nobody will help you anymore.Your brightness slider is the first thing to fix, you use PNLF patch for that. Once it's working, if your keys are still not working you have to look further. Thanks, My DSDT have the PNLF patch but still didnt work I read it on some forum that a Patch[FN KEYS] will fix this; but I tried to patch it the Compiler gives me alot of error, so could anyone patch this for me? DSDT.zip
m.gbt Posted February 24, 2014 Posted February 24, 2014 Your brightness slider doesn't work either or just the combination keys? Mavericks 10.9.2 Retail When you ask for support, remember to tell the bootloader you use
sidegame Posted February 24, 2014 Author Posted February 24, 2014 Your brightness slider doesn't work either or just the combination keys? actually the brightness slider does not work so I though if I fix the combination keys than may be i could change the brighness in that way, so overall for now none of them worked [neither Brightness slider nor Combination Keys]
artur-pt Posted February 24, 2014 Posted February 24, 2014 hello u dsdt already have the patch applied .. is not only ur note don't work .. several notes that don't work .. so u must find solutions in google for that problem.. in ur model.. maybe ur graphics is not well enabled good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
m.gbt Posted February 24, 2014 Posted February 24, 2014 actually the brightness slider does not work so I though if I fix the combination keys than may be i could change the brighness in that way, so overall for now none of them worked [neither Brightness slider nor Combination Keys] Your keys won't work if your slider doesn't. Artur said everything, maybe your graphics (internal GPU) are not well enabled, or you'll have to look for other fixes, maybe ACPIBacklight.kext Mavericks 10.9.2 Retail When you ask for support, remember to tell the bootloader you use
