Hardware:
Motherboard: Asus Prime H270-Plus
CPU: Intel Core I3-7100
iGPU: Intel HD630
RAM: 4GB Crucial (upgrade to 16GB soon)
Bios is updated to latest version.
I am following the installation guide but i get black screen and the pc is no longer responsive right after "select language" screen.
I'm sorry, but could you explain in a few words how to add "-igfxvesa bootarg" and where to add it.
I'm new hackintosh and can't find basic information on how to edit the correct files.
All other points are met.
Absolutelly the same problem with Monterey, a second after i see "select language" the pc crashes and no connection to the screen.
