Ventura on Desktop ! Z390 Aourus Master ! CPU I9 /9900K! Radeon RX 580 ! HELP!
Hi
i used your EFI Eios Settings :
Bios Setting with bios version F 11
Boot > CFG Lock > Disabled
Boot > Fast Boot > Disabled
Boot > Windows 8/10 > Windows 8/10
Boot > CSM Support > Disabled
Boot > Secure Boot > Secure Boot Mode > Disabled
Settings > IO Ports > Initial Display Output > PCIe 1 Slot (*)
Settings > IO Ports > Internal Graphics > Disabled (**)
Settings > IO Ports > Aperture Size > 256MB
Settings > IO Ports > Above 4g Decoding > Enabled
Settings > IO Ports > Re-Size BAR Support > Auto (***)
Settings > Miscellaneus > Intel Platform Trust Technology (PTT) >
-Desktop CoffeeLake Download HERE
