Ciclope3160 Posted January 2, 2023 Posted January 2, 2023 Hello guys, I have been able to install MacOS Ventura 13.1 on an Intel Core I5-4210U Haswell laptop, with an Intel 4400HD graphics card which I have patched with OCLP and it works perfectly, the WIFI does not worry me because I work with a TP-Link usb adapter, the setting Medium screen brightness works fine too, but I can't get the sound to work, the audio driver is Reltek ALC283, I've tried several options but I haven't gotten anything. Do you know if this problem with the audio can be solved? Greetings and thanks in advance.
Administrators MaLd0n Posted January 2, 2023 Administrators Posted January 2, 2023 https://www.olarila.com/topic/6074-guide-easy-audio-solution-with-applealc-clover-and-opencore/ 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Ciclope3160 Posted January 6, 2023 Author Posted January 6, 2023 Thanks It works fine, but I had to go back to Big Sur latest version because Unity Hub doesn't work in Monterey or Ventura. 1
borejan2 Posted March 6, 2023 Posted March 6, 2023 Could you upload the EFI for Ventura for this laptop.
