intel open wireless problems
hola all. me again.
now with wifi and bluetooth. have installed few kexts and can see new lines on boot and in dmesg but wifi or bluetooth dont work. my wifi card is intel 3165 and kext that have installed:
- itlwm.kext
- IntelBTPatcher.kext
- IntelBluetoothInjector.kext
- IntelBluetoohtFirmware.kext
- BrcmPatchRAM3.kext
- BrcmFirmwareDate.kext
- BrcmBluetoothInjector.kext
and here is dmesg output:
[  455.122220]: memorystatus: assertion priority 40 overrides priority 30 for HeadphoneSettingsExtension:2366
[  455.122326]: memorystatus: assertion priority 40 overrides priority 0 for HeadphoneSettingsExtension:2366
[  455.925876]: connect() - failed necp_set_socket_domain_attributesconnect() - failed necp_set_socket_domain_attributesconnect() - failed necp_set_socket_domain_attributesconnect() - failed necp_set_socket_domain_attributesSandbox apply: mediaanalysisd[2422] <bytes>connect() - failed necp_set_socket_domain_attributesconnect() - failed necp_set_socket_domain_attributesconnect() - failed necp_set_socket_domain_attributesconnect() - failed necp_set_socket_domain_attributesitlwm: itlwm: end passive scan
[  457.628059]: itlwm: ieee80211_switch_ess
[  457.628064]: itlwm: ieee80211_node_choose_bss
[  457.628071]: itlwm: ieee80211_reset_scan
[  457.628078]: itlwm: ieee80211_reset_scan
[  457.628081]: itlwm: iwm_updateslot
[  457.628083]: itlwm: ieee80211_next_scan 923 nstate=1
[  457.628086]: itlwm: iwm_newstate
[  457.628089]: itlwm: taskq task_add newstate_task add to queue
[  457.628107]: itlwm: iwm_scan
[  457.628603]: itlwm: ieee80211_reset_scan
[  457.628614]: itlwm: iwm_updateslot
[  457.628617]: itlwm: itlwm: SCAN -> SCAN
[  457.628632]: itlwm: ieee80211_set_link_state nstate=2, old_state=2
[  457.969167]: connect() - failed necp_set_socket_domain_attributes3 duplicate reports for Sandbox: Family(2378) deny(1) mach-lookup com.apple.contactsd.persistenceSandbox: dataaccessd(2414) deny(1) file-write-create /Users/t3ch/Library/HTTPStorages/com.apple.dataaccess.dataaccessdSandbox: dataaccessd(2414) deny(1) mach-lookup com.apple.metadata.mdsconnect() - failed necp_set_socket_domain_attributesconnectx() - failed necp_set_socket_domain_attributesSandbox: softwareupdated(274) deny(1) file-issue-extension target:/private/var/db/softwareupdate/Library/Preferences/com.apple.coremedia.plist class:com.apple.cfprefsd.readSandbox: softwareupdated(274) deny(1) file-issue-extension target:/private/var/db/softwareupdate/Library/Preferences/com.apple.CoreGraphics.plist class:com.apple.cfprefsd.readSandbox: softwareupdated(274) deny(1) file-issue-extension target:/private/var/db/softwareupdate/Library/Preferences/com.apple.Accessibility.plist class:com.apple.cfprefsd.readSandbox: softwareupdated(274) deny(1) file-issue-extension target:/private/var/db/softwareupdate/Library/Preferences/com.apple.driver.AppleBluetoothMultitouch.mouse.plist class:com.apple.cfprefsd.readSandbox: dataaccessd(2414) deny(1) file-read-data /private/var/db/mds/messages/501/se_SecurityMessagesconnect() - failed necp_set_socket_domain_attributesSandbox: bluetoothd(1170) deny(1) mach-lookup com.apple.private.corewifi-xpcconnect() - failed necp_set_socket_domain_attributesconnectx() - failed necp_set_socket_domain_attributesconnect() - failed necp_set_socket_domain_attributesconnectx() - failed necp_set_socket_domain_attributesSandbox: Family(2378) deny(1) mach-lookup com.apple.contactsd.persistence3 duplicate reports for Sandbox: Family(2378) deny(1) mach-lookup com.apple.contactsd.persistenceSandbox: Family(2378) deny(1) mach-lookup com.apple.AddressBook.ContactsAccountsServiceSandbox: Family(2378) deny(1) mach-lookup com.apple.contactsd.persistence7 duplicate reports for Sandbox: Family(2378) deny(1) mach-lookup com.apple.contactsd.persistenceSandbox: Family(2378) deny(1) mach-lookup com.apple.AddressBook.ContactsAccountsServiceSandbox: Family(2378) deny(1) mach-lookup com.apple.contactsd.persistenceconnectx() - failed necp_set_socket_domain_attributesconnect() - failed necp_set_socket_domain_attributesitlwm: itlwm: end passive scan
[  462.075007]: itlwm: ieee80211_switch_ess
[  462.075012]: itlwm: ieee80211_node_choose_bss
[  462.075020]: itlwm: ieee80211_reset_scan
[  462.075027]: itlwm: ieee80211_reset_scan
[  462.075029]: itlwm: iwm_updateslot
[  462.075032]: itlwm: ieee80211_next_scan 923 nstate=1
[  462.075035]: itlwm: iwm_newstate
[  462.075038]: itlwm: taskq task_add newstate_task add to queue
[  462.075057]: itlwm: iwm_scan
[  462.075518]: itlwm: ieee80211_reset_scan
[  462.075529]: itlwm: iwm_updateslot
[  462.075532]: itlwm: itlwm: SCAN -> SCAN
[  462.075535]: itlwm: ieee80211_set_link_state nstate=2, old_state=2
[  462.546273]: tx_flush:1241: disk1 xid 224376 tx stats: # 320 finish 314 enter 134 wait 53 142898us close 18874us flush 228778us
[  463.018824]: connect() - failed necp_set_socket_domain_attributesIOConsoleUsers: time(0) 0->0, lin 1, llk 0,
[  463.456448]: IOConsoleUsers: gIOScreenLockState 1, hs 0, bs 0, now 0, sm 0x0
[  463.457323]: Couldn't alloc class "AppleKeyStoreTest"
[  463.903473]: Sandbox apply: passd[2399] <bytes>ALUC:clientDied(PID: 2420), entitled 1
[  464.118071]: ALUC:init(PID: 2424), entitled 1
[  464.118117]: methodSetClientDomain entered
[  464.118124]: registerNotificationPort entered
[  464.152909]: connect() - failed necp_set_socket_domain_attributesIOConsoleUsers: time(0) 0->0, lin 1, llk 0,
[  465.731626]: IOConsoleUsers: gIOScreenLockState 1, hs 0, bs 0, now 0, sm 0x0
[  465.732842]: Couldn't alloc class "AppleKeyStoreTest"
[  466.008395]: 11 duplicate reports for Sandbox: Family(2378) deny(1) mach-lookup com.apple.contactsd.persistenceSandbox: nsattributedstringagent(2325) deny(1) mach-lookup com.apple.audio.AudioComponentRegistrarAppleKeyStore:1918:122: vol-uuid: , portable: 0, res: 0xfffffffd
[  466.019389]: AppleKeyStore:3467:122: user 74bd8ed060f94c7982b336702517c7af unlock successful (0)
[  466.040565]: Sandbox apply: com.apple.WebKit.WebContent[2425] <bytes>Sandbox apply: com.apple.WebKit.Networking[2427] <bytes>Sandbox: com.apple.WebKit.Networking(2427) deny(1) mach-lookup com.apple.analytics
thanks for any advice.
