so, I'm a beginner, and I know that at first Tiger Lake wasn't functional...but I found this EFI (the only one that works), and it was working reasonably well (with mouse trails and some delays in opening menus, no wifi, no sound, no touchpad and no bluetooth) ,...so I decided to try to fix it and I ended up ruining the backup EFI too (I don't remember where I found the EFI) ...the biggest problem started today, I formatted and tested Catalina, Big Sur and Ventura, all work as usual, but all systems started to show crashes in videos (in the browser and outside of it), in addition to not being able to solve the other problems mentioned above.
    I need some kind soul to fix these problems please. If you need to pay for it, no problem.
computer
Tipo de Computador    Acer Aspire A515-56  (Mobile)
Sistema operacional    Microsoft Windows 11 Pro
DirectX    DirectX 12.0
mboard
Tipo de processador    DualCore Intel Core i3-1115G4, 4100 MHz (41 x 100)
Nome da Placa Mãe    Acer Aspire A515-56
Chipset da Placa Mãe    Intel Tiger Point-LP, Intel Tiger Lake-UP3
Memória do Sistema    12067 MB  (DDR4 SDRAM)
Tipo de BIOS    Unknown (10/31/2022)
Monitor
Adaptador gráfico    Intel(R) UHD Graphics  (1 GB)
Monitor    BOEhydis NV156FHM-N48  [15.6" LCD]
media
adapter sound Intel Tiger Point-LP PCH - cAVS (Audio, Voice, Speech)
Dispositivos de entrada
Teclado    Dispositivo de teclado HID
Teclado    Teclado Padrão PS/2
Mouse    ELAN I2C Filter Driver
Mouse    Mouse compatível com HID
internet
Adaptador de Rede    Bluetooth Device (Personal Area Network)
Adaptador de Rede    Hyper-V Virtual Ethernet Adapter
Adaptador de Rede    MediaTek Wi-Fi 6 MT7921 Wireless LAN Card
Adaptador de Rede    Microsoft Wi-Fi Direct Virtual Adapter #3
Adaptador de Rede    Realtek PCIe GbE Family Controller
devices
Impressora    Microsoft Print to PDF
Controladora USB3    Intel Tiger Point-LP PCH - USB 3.2 Gen 2x1 (10 Gb/s) xHCI Host Controller
Dispositivos USB    Dispositivo de Entrada USB
Dispositivos USB    HD User Facing
Dispositivos USB    MediaTek Bluetooth MT7921
Dispositivos USB    USB Composite Device
Dispositivos USB    USB Mass Storage Device
Bateria    Adaptador de CA da Microsoft
Bateria    Bateria de Método de Controle Compatível com ACPI da Microsoft
DMI
Distribuidor da BIOS - DMI    Insyde Corp.
Versão da BIOS - DMI    V1.31
Fabricante do Sistema - DMI    Acer
Nome do Sistema - DMI    Aspire A515-56
Versão do sistema - DMI    V1.31
prints and efi.rar
tiger lake igpu don't have support
i know ,but this one was running fine... and now I don't know if I put files that caused the crash, or if I edited the plist... I used the OCT program and it didn't find errors... if I format it, I'll be able to run it, but I don't know how it was before I made the modifications :(
Just now, Paulo Kruger Vaz said:
capslook, sry
