ScreenResolution and Serial
hola.
got question for resolution how to change it? Option is only 1024x768.
second question is about serial number. have tried to change all numbers in config.plist and restart but looks there is still the same.. :)
Quote
            <dict>
                <data>AAAWGQ==</data>
                <key>framebuffer-fbmem</key>
                <data>AACQAA==</data>
                <data>AQAAAA==</data>
                <data>AAAwAQ==</data>
            </dict>
hey. to add or change this in config.plist ok will try.
but normaly i change anything i stuck on loading with url:
www.apple.com/mac/support
here is script if anyone like to play more.. :)
it change all what is required.. but when i boot like i say always this url.. :x
import xml.etree.ElementTree as ET # https://docs.python.org/3/library/xml.etree.elementtree.html
import json
import re
fromDir = "/Users/t3ch/EFI/EFI/OC/config.plist"
tree    = ET.parse(fromDir) #.getroot()
root    = tree.getroot()
config = [
        "searchKey":"SystemSerialNumber",
        "searchReplace":"C02QHAZZGG7L",
        "searchKey":"SystemUUID",
        "searchReplace":"E9C67D0E-9EC8-436D-947D-C5D6F3202E84",
        "searchKey":"SystemProductName",
        "searchReplace":"iMac17,1",
        "searchKey":"MLB",
        "searchReplace":"C02540306CDGPF71M",
log = []
def match(rgx,txt):
    x = re.match(rgx, txt)
    if x:
        return True
    return False
def searchKey(name):
    global config
    at=-1
    for o in config:
        at+=1
        if o["searchKey"]==name:
            return at
    return False
def doTheJob():
    global config, log, root
    print("\nStarting PART 1")
    cnt    = 0
    checked = [] # for step2
    waiting = [root,]
    # (step1) - Loop trough config.plist and find - modify specific keys - values defined in global config array/object
    while len(waiting):
        #print("Debug len(waiting): {}".format(len(waiting)))
        nextOf = -1
        o      = None
        roots = waiting.pop(0)
        for elm in roots:
            #print("{}.) tag: {} => {}".format( cnt, elm.tag, elm.text ))
            tmp = searchKey( elm.text )
            if tmp >= 0 and tmp is not False:
                o = config[tmp]
                print("{}.) Replacing({}): {} = {}".format( cnt, tmp, o["searchKey"], elm.text ))
                o["keyAt"]    = tmp
                o["cntAt"]    = cnt
                nextOf = cnt
            elif nextOf+1==cnt and o!=None:
                print("{}.) Replacing: {} for {}".format( cnt, elm.text, o["searchReplace"] ))
                log.append( {
                    "searchKey":o["searchKey"],
                    "searchReplace":o["searchReplace"],
                    "modified":elm.text,
                    "keyAt":o["keyAt"],
                    "cntAt":cnt,
                elm.text = o["searchReplace"]
                nextOf = -1
                o      = None
            #elif elm.text is None or elm.text=="":
            #    print("Setting empty on tag: {}".format(elm.tag))
            #    elm.text = ""
            cnt+=1
            waiting.append( elm )
    print("\nStarting PART 2")
    cntof=0
    # (step2) - Loop trough global log aka SEARCH & DESTROY :)
    for elm in log:
        x = elm["modified"] # modified value we search & destroy
        r = elm["searchReplace"] # modified value we search & destroy
        if x not in checked:
            checked.append(x)
            # Loop trough all values and try find and modify strings that contain values that have been replaced.
            print("Searching for value: {}".format(x))
            cnt=0
            waiting = [root,]
            while len(waiting):
                for elm1 in roots:
                    #print("{}/{}.) tag: {} => {}".format( cnt,cntof, elm1.tag, elm1.text ))
                    if match(".*{}.*".format(x),"{}".format(elm1.text)):
                        print("Fixing at {}/{} value {}".format(cnt,cntof,elm1.text))
                        tmp = elm1.text.replace(x,r)
                        elm1.text = tmp
                    waiting.append( elm1 )
                    cnt+=1
            cntof+=1
#print("mem.len: {}".format( len(mem) ))
doTheJob()
print("Displaying log: ")
print(json.dumps( log ))
tree.write("fixed.plist")
#tree.write("fixed.plist",method='html')
man where to add pciroot?
under:
- ACPI
- Booter
- DeviceProperties
- Kernel
- Misc
- NVRAM
- PlatformInfo
- UEFI
under DeviceProperties ok if i will manage this man.. :x :)
so you think this should work:
    <key>DeviceProperties</key>
    <dict>
        <key>Add</key>
        <dict>
            <dict>
            </dict>
        </dict>
        <key>Delete</key>
        <dict/>
    </dict>
have added it and restarted without nvram and it booted good but resolution can not change from 1024 to 1240x...
and maybe this helps
% ./gfxutil
00:00.0 8086:1904 /PCI0@0/MCHC@0 = PciRoot(0x0)/Pci(0x0,0x0)
00:02.0 8086:1916 /PCI0@0/IGPU@2 = PciRoot(0x0)/Pci(0x2,0x0)
00:14.0 8086:9d2f /PCI0@0/XHC@14 = PciRoot(0x0)/Pci(0x14,0x0)
00:14.2 8086:9d31 /PCI0@0/MALD@14,2 = PciRoot(0x0)/Pci(0x14,0x2)
00:16.0 8086:9d3a /PCI0@0/IMEI@16 = PciRoot(0x0)/Pci(0x16,0x0)
00:17.0 8086:9d03 /PCI0@0/SAT0@17 = PciRoot(0x0)/Pci(0x17,0x0)
00:1c.0 8086:9d10 /PCI0@0/RP01@1C = PciRoot(0x0)/Pci(0x1C,0x0)
00:1c.4 8086:9d14 /PCI0@0/RP05@1C,4 = PciRoot(0x0)/Pci(0x1C,0x4)
00:1f.3 8086:9d70 /PCI0@0/HDEF@1F,3 = PciRoot(0x0)/Pci(0x1F,0x3)
00:1c.5 8086:9d15 /PCI0@0/RP06@1C,5 = PciRoot(0x0)/Pci(0x1C,0x5)
00:1d.0 8086:9d18 /PCI0@0/RP09@1D = PciRoot(0x0)/Pci(0x1D,0x0)
00:1f.0 8086:9d48 /PCI0@0/LPCB@1F = PciRoot(0x0)/Pci(0x1F,0x0)
00:1f.2 8086:9d21 /PCI0@0/PPMC@1F,2 = PciRoot(0x0)/Pci(0x1F,0x2)
00:1f.4 8086:9d23 /PCI0@0/SBUS@1F,4 = PciRoot(0x0)/Pci(0x1F,0x4)
01:00.0 1002:6900 /PCI0@0/RP01@1C/GFX0@0 = PciRoot(0x0)/Pci(0x1C,0x0)/Pci(0x0,0x0)
02:00.0 10ec:8168 /PCI0@0/RP05@1C,4/PXSX@0 = PciRoot(0x0)/Pci(0x1C,0x4)/Pci(0x0,0x0)
04:00.0 10ec:522a /PCI0@0/RP09@1D/PXSX@0 = PciRoot(0x0)/Pci(0x1D,0x0)/Pci(0x0,0x0)
03:00.0 8086:3165 /PCI0@0/RP06@1C,5/PXSX@0 = PciRoot(0x0)/Pci(0x1C,0x5)/Pci(0x0,0x0)
Edited by t3ch
checking, noticing soon. Bale this works too. looks if you dont change imacpro 1,1 to imac17,1 works.
so what about screen resolution?
Edited by t3ch
holaaa uuu  have managed screen resolution !!! have went comparing prepared folders and found solution so for me works this:
            <dict>
                <data>AADAhw==</data>
                <key>device-id</key>
                <data>FlkAAA==</data>
                <key>framebuffer-con1-alldata</key>
                <data>AQUJAAAIAACHAQAA</data>
                <key>framebuffer-con2-alldata</key>
                <string>&lt;02040a00 00080000 87010000&gt;</string>
            </dict>
by adding these two args:
igfxonln=1 igfxagdc=0
have fixed hdmi. never was working.. oleee.! :)
and sound works by chaning bootarg alcid from 1 to 3 .. kul man!
man. when you have time. for wifi and what is more interesting FTDIUsb .. thanks man. going to donate soon something more.
FTDI works too. have installed CP210x drivers but probably was bad cable. so wifi left and bluetooth.. when time :) and one question. have noticed in general -> start app on launch there is Mickey1979 APP to start at startup. have removed it but why is there¿?
For ALL important is to disconnect all usb devices when installing or booting. or HDMI. normaly if i have HDMI connected boot dont work.
Another important thing is to disable sleep of disk if not work as should because you will land on black screen when goes to sleep.
and here is something on bootargs what have learned. good for all:
- alcid 1-3                   # Audio
- watchdog 0             # more here: https://developer.toradex.com/linux-bsp/how-to/linux-features/watchdog-linux/
- agdpmod=pikera    # Graphics. more here: https://github.com/acidanthera/bugtracker/issues/1807                      vit9696 # for intel and problems
- dk.e1000=0             # more here: https://www.reddit.com/r/hackintosh/comments/tf4hpy/psa_monterey_123_and_i225v_panics_use_bootarg/    e1000=0 - igfxonln=1                # hdmi, audio?, more here: https://www.tonymacx86.com/threads/screen-sleep-stopped-working-after-update-to-mac-os-catalina-10-15-4.294025/page-3
- igfxagdc=0              # hdmi, audio problems. ( + platform-id only (00001659 or 00001b59) ) more here: https://www.tonymacx86.com/threads/intel-hd-630-not-working.321200/page-3
- uia_exclude=USR1;USR2 # USB3, more here: https://www.insanelymac.com/forum/topic/344719-what-is-the-right-way-to-get-usb-30-working-with-opencore/
AND Recommend for olarila.com to prevent paste of html into posts.*
Edited by t3ch
and nother new thing that have noticed is that i can speak on phone even is not connected trough computer with people.. incredible.!
you need to know people that you are we! and what you like we like. so think again.* love you*
if you like NETFLIX more than Hackintosh then you klnow where you land*** love you all***
