nagar Posted January 2, 2014 Share Posted January 2, 2014 Hello Folks. Recently Installed Mac 10.9.1 Mavericks on my laptop Sony Vaio Model VPCEH1CFX Intel i5 2410 @ 2.30 GHz, nVidia Geforce 410m @1024 VRAM, Intel Chipset 6 series/ C2 00 chipset family. Installed Chameleon Boot loader last version " Chameleon-2.2svn-r2286.pkg " I'm facing many problem to install drivers Kexts, Used many kexts and ways but failed, last trial was using system info.app searching Device ID but can not find that devices in any sites even searching google. here is Device ID Results Here is Kexts Results also I have some error in my bottom right corner of screen cause of display adapter not installed you can see I used multishit 6.0.1 and old version 4.3 to install nVidia but failed This is first time for me to use or Install Mac All What I need is : - Install Touchpad because it's not working - Install Num Lock Key and Scroll Lock key and other function keys -Install nVidia Geforce 410m kext -Install other Missing kext Please some elaboration cause this is first time to use and don't know enough Thanks Guys Link to comment Share on other sites More sharing options...
PimentelX86 Posted January 2, 2014 Share Posted January 2, 2014 Hello We don't give support for tonycrap tools, know why: http://www.insanelymac.com/forum/topic/279450-why-insanelymac-does-not-support-tonycrapx86/ Hack doesn't need only kext, it need configurations. Read in here to know how configure everythings: http://Olarila.com/forum/viewtopic.php?f=28&t=1716 Link to comment Share on other sites More sharing options...
nagar Posted January 2, 2014 Author Share Posted January 2, 2014 Hello Buddy, Thanks for reply, This is first time to use Mac so i don't know well what is supported or what is not. Just I searched the web and got some ideas from web, i don't have deep knowledge about that, by the ways thanks for help , I will try with this links Link to comment Share on other sites More sharing options...
PimentelX86 Posted January 2, 2014 Share Posted January 2, 2014 Hello Thanks for your compreension Make a hack isn't hard if you have a compatible machine, but also isn't easy... Patience is the key Link to comment Share on other sites More sharing options...
m.gbt Posted January 3, 2014 Share Posted January 3, 2014 Try this: Elan's Touchpad Driver My touchpad wasn't working and now it is with those drivers. Should work for you too Pay attention to the install instructions. Cheers Mavericks 10.9.2 Retail When you ask for support, remember to tell the bootloader you use Link to comment Share on other sites More sharing options...
Giatuareg Posted January 4, 2014 Share Posted January 4, 2014 Hi, I suggest you to make slow foots without hurry, i mean just install 1 kext per time so you can easily check what's working and what's not. Also use the command: Kextstat It gives a more complete list of the loaded kexts. All What I need is :- Install Touchpad because it's not working - Install Num Lock Key and Scroll Lock key and other function keys -Install nVidia Geforce 410m kext -Install other Missing kext For the touchpad and keyboard you can eventually try the Voodoo's, which could resolve also your modify keys. I can't help you for the Nvidia Geforce coz I always had ATI's, but from what i've read Nvidias work easily with Vbios loader and the custom resolution chooses. You can easily set this values with Chameleon Wizard. Chameleon Wizard and Kext Wizard are your best friend. Remember every time to rebuild cache and permissions (from kext wiz) or you'll have Kernel Panics even if there kexts are right. Cheers mate Link to comment Share on other sites More sharing options...
