I installed clover_v2k_r2428, after reboot, I can see one more boot option "Mac OS X."
But no matter which one I chose, it always says "Missing Operating System."
MB: ASRock H67M-ITX, UEFI bios v2.20, patched
CPU: intel core i5-2400
NVidia GT 630
OS: Mavericks 10.9.1 raw USB from Olarila
disk: only one, WD 320G 2.5" HDD, GPT
now I can only boot Mavericks from usb installer.
What can I do to fix the boot issue?
Someday I'm gonna buy a real Mac if I won the lottery!
Thanks a lot!
I successfully boot into my Mavericks hdd by following the instructions at the following link.
http://Olarila.com/forum/viewtopic.php?f=28&t=3405&p=33648#p33648
Just copy the EFI folder from Pendrive's EFI partition to my hdd's EFI partition.
Reboot.
In Clover menu, go to Clover Boot Options(the one for SATA) and select Add as UEFI boot option.
I wonder why the Clover UEFI Guide never mentioned that?
http://cloverboot.weebly.com/install-clover-to-usbhdd.html
Configuration aside, I thought installing Clover would be as easy as installing a pkg.
It has also took me some time to set that up and my problem was solved with your solution. Just wanted to say it here to encourage future users with the same problem :)
Mavericks 10.9.2 Retail
When you ask for support, remember to tell the bootloader you use :)
