Using OpenCore, I was able to install macOS Monetary on my i5-6500, GA-Z170X-UD5 system.
Sadly, the 530 iGPU is stuck at only 7MB.
I added the following code to my config file, but this didn't change anything.
            <dict>
                <key>AAPL,GfxYTile</key>
                <data>AQAAAA==</data>
                <data>AAAbGQ==</data>
                <key>framebuffer-fbmem</key>
                <data>AACQAA==</data>
                <integer>1</integer>
                <data>AAAwAQ==</data>
                <key>hda-gfx</key>
                <string>onboard-1</string>
            </dict>
My system is also unable to restart, but I can shutdown without any issues.
When I try to restart my system it halts on IOPlatformHaltRestartAction -> AppleSMC
Here is my EFI folder.
https://drive.google.com/file/d/1dhdkJdcK__n4eMpUaxZJG39p0cYv8Lyo/view?usp=sharing
Edited by Snake_Oil_Salesman
Clarification
Quote
            <dict>
                <key>#framebuffer-patch-enable</key>
                <data>AAASGQ==</data>
                <key>device-id</key>
                <data>EhkAAA==</data>
                <key>framebuffer-unifiedmem</key>
                <data>AADw/w==</data>
            </dict>
remove -igfxvesa from bootarg
igfxonln=1 agdpmod=vit9696 igfxagdc=0
